I have a 50h6sg and I get no picture but I see lines vertical they jump around
My RCA tv picture is jumping
Vertical jumping may have a vertical hold issue, horizontal may have a horizontal hold issue. Most older tv sets will have some knobs or adjustable screws for vertical and horizontal hold. Turn your set on and check for these knobs on the back of your set and adjust until your picture is in as well as you can get it
Aug 21, 2014 | Televison & Video
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
Lg tv lcd screen okay for a little while then jumping and lines goign down screen and then lines and bottom and top jumping - what is the issue please
Are the lines different colors? Are they in the vertical direction? Is each line the width of a row of pixels? If so then this can be the Tcon board or the panel. Can you send me a picture?
Apr 03, 2011 | LG 42LC2D 42 in. LCD HDTV
Television blank , but there is a white line across tube. I can hear audio
Your TV is in what is called "vertical collapse". About 70-80% of the time it is due simply to bad solder joints on the vertical output IC. You can verify this by tapping on the side or top of the TV, the picture may jump back into position. If it comes back it's as simple as re-soldering the vertical IC. If not, the vertical output IC may be shot or it may be missing one of it's supply voltages.
If the picture has been shrinking or had lines at the top that means there are some capacitors in the vertical circuit that were drying out. If it happened all of a sudden I'd bank on it being just bad solder.
Don't run it like that with that bright line for too long or it will burn in on the picture tube. Then if you do get it fixed you will see that line there all the time!
May 24, 2010 | Toshiba 27A33 27" TV
SanyoTV-blk screen w/thin line of light across screen great sound
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
Apr 18, 2009 | Sanyo DS27820 27" TV
Picture jumping
make sure that the resolution on your tv is coordinated with the wii
Jun 07, 2008 | Nintendo Wii Console
Jumping picture
Resolder the vertical output IC and the vertical yoke connections on the main PCB
Mar 16, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Picture jumps or shakes
possible solder connection breaking down when the set is cold.look in and around the horizontal and vertical section for cold solder connections.
Nov 10, 2007 | Hitachi 50UX58B 50" Rear Projection...
Sanyo TV model DS25710 or DS25730
Set has a bad vertical sweep IC. Also This Sanyo has a tendancy , when the IC blows out , to take the fusable resistor in the sweeo supply that feeds the vertical IC. This set should only be serviced by a trained technician because of ther high Voltage that lingers within. This repair should run you antwhere from 85.00 to 150 bucks. Good Luck
Jul 31, 2006 | Sanyo DS24205 24" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
