Question about The Audio Players & Recorders
Have a Detrola model KM837. Need to get front plate off. Do the 2 knobs jfor on/off and stations just pull off?
3 Suggested Answers
SOURCE: need to replace needle or
eat **** muddafuka
Posted on Sep 10, 2008
  • 104 Answers
SOURCE: Need free owner's manual for a Detrola record player Model KM837
unable to follow what is wrong.
are you talking about the tonearm or a lever at the power switch?
Posted on Feb 11, 2009
I cannot open the CD door on my Detrola KM837 4 in 1. I push the open button, sounds are emitted like it wants to work, but does not. Any suggestions?
agree with a small hole trick... but don't leave the drive ever empty. Use i.e. dummy CD media always. When you need it, just replace, spin your DVD, than put DUMMY back in the drive. Don't believe? Just try. :-)
proizvodnja raunara prodaja laptopova popravka kompjutera pc servis...
Sep 26, 2016 | Computers & Internet
Can i use a crosley stylus in my detrola km837 record player
Stylus will only fit into certain cartridges. You have two options here. You can look up the cartridge number and make on your Detrola. It should be on the cartridge somewhere. Then search for the stylus. Or you can remove the Detrola cartridge and fit a new cartridge and stylus. As long as the cartridge will fit into the arm of your deck, plus it's the right type - ie: magnetic if the old cartridge was magnetic! Or ceramic - again if the old cartridge was...
Then you can use any make or model cartridge you want. As the quality of the sound can be improved - albeit paying more money for it - by having a good quality cartridge and stylus, it might be best in the long run to change the cartridge.
Jul 15, 2015 | Crosley Audio Players & Recorders
Need to replace volume knob
Did mine years back - need to find part RV1802 1-418-773-11 ENCODER, ROTARY (MASTER VOLUME)
Volume went up and down turning in one direction. About 2 hour job, pull both knobs off, remove cover and front plate to get to volume switch assembly, replacement part requires desoldering and solder on new part.
Nov 24, 2013 | Sony STR-DE1075 Receiver
I bought a Detrola KM837 second hand for my mom for Christmas, it came with no manual. The turntable I figured out from other posts, haven't tried it but I think that it would work. But my problem is the...
Very often a small belt has fallen off or broken. A look inside should locate it. To find a replacement belt, just measure the diameter of the old one in MM and then put the words "drive belt --MM" into Google. Select the size close to yours.
Oct 27, 2013 | Audio Players & Recorders
Instructions for replacing the spark module on a DCS-305
In order to replace the Spark Module on your DCS-305, do the following:
  • 1
    Unplug the range from the wall outlet prior to servicing.
  • 2
    Remove the burner knobs from the burner switches on the front of the range. To remove the knobs, pull them straight away from the range. If the knobs are difficult to remove, wrap a piece of wire or string behind each knob for extra leverage.
  • 3
    Take off the bezel plate from each knob. Depending on the model of your range, this plate may be secured with screws, or the plate slides into place.
  • 4
    Remove the two screws that secure the valve panel then pull the panel off of the range. The spark module is now accessible for inspection, repair or replacement.
  • Oct 19, 2013 | Kitchen Ranges
    How to remove front panel of dryer
    Be sure to unplug the machine from the mains,
    1.-Remove the top cover of the machine, very straight forward.
    2.-Unclip the universal coupling from the main timer to the back of the knob.
    3.- The whole knob assembly is held in place by a backing plate.
    4.- There are 2 clips at the top of this backing plate raise them and the backing plate and knob can be pulled out.
    5.- there is a plastic clips but be careful not to break it.
    Your ffeed back and ratting are so important for me. thank you
    Was this helpful?
    The knob breaks when it has been turned in the wrong direction several times. It's a safety device so as not to damage the main timer.
    May 20, 2009 | Dryers
    You have probably done this, but I had same problem on one I was given with no manual. I couldn't get the turn table to turn and by accident I move the arm to the right, away from record and it began turning. Hope that helps.
    Feb 22, 2009 | Audio Players & Recorders
    Jan 25, 2009 | Crosley CR248 Turntable
    18 people viewed this question
    Top The Audio Players & Recorders Experts
    isojim
    Level 1 Expert
     Sam R
    Sam R
    Level 1 Expert
    obsteiner
    Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
