Question about Bissell Vacuums
My bissell has no sucking power just stop I was on my last room and I notice it wasn't suking up water any more
    Sergeant:
    Champion:
  • Bissell Expert
  • 357 Answers
It's either too full or if you emptied it maybe you didn't get it back together right and the seals are not in correctly. Double check the assembly
Posted on Jul 03, 2017
  • 25 Answers
SOURCE: no suction
if this is a 9400 series check and make sure the red flap in the lid of the dirty water tank is not closed.
Posted on Apr 04, 2008
reddevil6
  • 1673 Answers
SOURCE: Bissell proheat
First is the smart mix valve turning like it should? If it is then replace the soap dispensor. Also is the gasket on the valve at the bottom of the bottle?
Posted on Jun 01, 2008
nwj2468
  • 76 Answers
SOURCE: my bissell want **** up
somewhere on the unit, there will be a round clear cap. when you find it, unscerw it and clean out the inside.
Posted on Mar 01, 2009
SOURCE: bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Posted on Mar 19, 2009
SOURCE: My bissell carpet cleaner will not suck up the
what could be the problem
Posted on Jul 10, 2010
I have a Bissell ProHeat 2x advance carpet cleaner . It stop sucking up water. How can I fix it?
First check your filters. The Customer User Guide says to clean them after each use. There's two: The Water Tank Cap filter (looks like a screen) remove it, clean and reinstall, and the Flow Indicator: Turn the Flow Indicator Cap counter-clockwise and remove. Remove the rotor and under it is the filter. Remove, clean and reinstall in reverse order. If that didn't do it call Bissell Consumer Care at -1-800-237-7691 Hope that helps.
Feb 13, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell proheat pet will not suck up water
Check the filters. User's Guide has locations. one under water tank cap one under Flow Indicator. They are small but need to be cleaned after each use.
Jul 18, 2014 | Bissell Pro Heat Orginal belts
My carpet shampooer is not sucking up water?
Hey Karen, having no suction when cleaning can be a bummer.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
My bissell upright won't **** up the water, but the attachments will
Hey Maria, sorry to hear about the no suction.
Here's a quick link to troubleshooting steps to assist you.
Feb 02, 2013 | Bissell 8910 ProHeat Clear View Upright...
My bissell proheat 2 x won't spray water
PLEASE GO TO THE PAGE FOR TROUBLESHOOTING AND HELP
http://www.bissell.com/how-to-videos/
God bless you
Jul 23, 2012 | Bissell Vacuums
My bissell proheat turbo 2x hand tools will dispense solution but not water.
  • Fixed it! The check valve on the bottom of the bladder wasn't going deep enough into the recepticle on the base of the unit; the valve wasn't opening, and the pump was sucking from a dead end. (It WOULD pull soap from the small tank, but not the main bladder reservoir.) I cut a 3/4" piece of a disposable ball-point pen cap, to ride over the rod in the center of the recepticle. Long enough to push the valve open, but short enough that the tank assembly sat down on the base. If the rod is too long, it will push the whole tank up, and break the vacuum seal at the forward edge. Evidently this thing was designed to a tight tolerance, and just a little aging/distortion of the plastic reservoir base was just enough to keep the valve from being pushed open!
  • Jan 29, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
    My steam vac stopped sucking the water up
    make sure the lid on the dirty water container is on tight and the tank itself is locked into place, also check to make sure the clear window in the front of the machine is tightened down firmly
    Oct 20, 2009 | Hoover F5858-910 SteamVac Vacuum
    Doesn't return the dirty water to the tank, after apply the water
    My Bissel has been having problems sucking the dirty water back into the tank. It's like it works for half a dozen uses and then just stops working. After I turn it on and off for a couple of hours trying to troubleshoot the issues it just starts working out of the blue again and sucks up the dirty water. I know there is a yellow stopper that goes up and can stop the flow but that's down and not the issue here.
    Sep 21, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
    No suction
    Apr 02, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
    Vacuums Logo
    60 people viewed this question
    Top Bissell Vacuums Experts
    Jim Thurston
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
