Question about Refrigerators
HOW TO OPEN THE FLAPPER OF FRENCH DOOR REFREGRATOR. I NEED TO INSTOL THE MIDDLE HINGE ON THE FLAPPER?
  • 132 Answers
SOURCE: bolts broke on bottom drivers door hinge
a vw wreckers or dealer will sell you the correct hinge bolts with the year model on you
Posted on Nov 09, 2008
SOURCE: flapper door that dispenses ice will not open automatically
the flapper door appears to be broken. how can it be repaired?
Posted on Nov 29, 2008
SOURCE: The top hinge of my neff integrated fridge freezer has broken.
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
Posted on Jun 12, 2010
  • 15941 Answers
SOURCE: My LG LFX25960ST French Door refrigerator had a leaking water problem. When I removed the ice maker to adjust the water the circuit board sstarted to cycel on and off for about 2 minutes now the ice
When you took the i/m out, the motor has put the door out of synch
Posted on Mar 31, 2013
jmoyz28
SOURCE: driver's door hinge noise
It's the door check strap. Roughly a $25 part.
Posted on Dec 31, 2014
How to install spring on french door flapper/divider for Samsung RF266
On mine one end of the spring broke off in the hole on the door. It was on top of the hinge so it looked like a pivot pin. I found that this was the second hole for the spring. I pushed the end of the new spring up under the hinge and popped the broke piece of old spring out. Now I could see the 2 holes. You then need to put the spring into each hole. The hole on the flap also needs a white plastic sleeve if that is missing. that goes on the end of the spring and fits into the flap hole. Then the trick part is understanding how the spring works? If you put both ends of the spring in the holes and shut the flap, it now stays in position to close and be flipped open by the guide that swings it open to seal.
Good Luck.
Feb 03, 2014 | Samsung RF266ABRS Bottom Freezer...
I have an LG model LFX25974ST refrigerator. My issue is the ice flapper that allows the ice to drop will not open.partment and clog up. if i hold the flapper door open manually the ice drops down and
http://c.searspartsdirect.com/lis_png/PLDM/F1107036-00005.png
405A
on diagram Motor,dcPART NUMBER: EAU59551201 $27.41
Back ordered Call Marcone appliance ... Or goto searsparts
but this is the part you need.... To access it take outer door appart
see diagram on searsparts.com
Jan 16, 2014 | LG LFX25960ST Stainless Steel French Door...
French door makes high pitched squeal when I open it
Lube will not help. The door needs adjustment. Look on top of the door where hinges are and try minor adjustment. You will need help to guide you.
Dec 04, 2013 | LG Refrigerators
Left door of the refer isn't closing properly, must manually feed it thru the little channel at the top for it to fold in and close
check the door hinges a in place:
The door latch and lower hinge pin should hold your refrigerator door in place..
Uncover the door by removing the screws.Take the door off and pack bottom hinge with washers and make sure hinge brackets on cabinet are tight.
Check the seal is clean and pliable:
If seal is gapping, one solution is to warm with a hairdryer and pull outwards gently.
Check the refrigerator is properly leveled:
Adjust the middle hinge to straighten the lower portion of the door. Use a level to ensure the door is flush.
After fitting the door back again,check to see if the seal is touching on all sides when the door is closed. If not, you will need a new seal.Refrigerator is properly leveled.and hinges should be properly placed.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 06, 2010 | Amana AFD2535DES French Door Refrigerator
Our French doors aren't shutting right. You have to close the left one first, and then the right one. Even if you don't need to open the right one. It didn't used to do this.
It appears that your door hinges are loose. Open each door, take a close look at hinges at the top and bottom. You may be able to see an outline of where the hinge was and needs to be. Raise / Lower Door by hand until hinge is back in place, and tighten with a screwdriver. Pretty common.
Jun 11, 2010 | Samsung RFG237AABP (226 cu ft) Bottom...
One of the hinges on the door seal has come off and the door will not close properly. Model #KFCS22EVMS This model has the sealing mechanism on the left door where a small panel slides into the body...
Open the little metal screw on the larger hinge that is between the top and bottom hinges. This will allow to pull the seal all the way out. There is wiring behind that middle hinge so watch not to damage it. Then , you can realign the 3 hinges in their place and replace the screw in its position. It takes a little bit of patience to realign the 3 hinges but it's very doable.
Dec 23, 2009 | KitchenAid KFCS22EVMS Stainless Steel ...
Condensation on the strip between the 2 french doors
these fridge have a heater in that black flaper to prevent condensation. It is probably not working or not even plugged...do they removed the doors when they delivered your fridge??? remove the uper left cap of the hinge, the connection is there...... the tech must check that piece if it is well plugged..
Jul 03, 2009 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
May 02, 2008 | Refrigerators
Icemaker problems
Woody, This is one of the easier dispenser assy. to fix. The flapper is pretty simple, it clips on to the hinge assy. The hinge assy. has a spring that closes the flapper. There is a selenoid that pulls the flapper open. You can look up the parts on the net to see what they would cost. Flapper-12562701, hinge assy. 67004119, solenoid-12575401,spring 12565502. I don't know if you need all of them, Im not there to see. But if you have some time on your hands you could save a lot of money doing it yourself. Once fixed, you should be good for a long time. Catriver.
Jul 24, 2007 | Jenn-Air JCD2295HES Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
