Question about HP Office Equipment & Supplies
Fake paper jam message on HP Officejet Pro 8500 Wireless
Even though there is not any paper jam, the message keeps repeating: 'Carriage Jam", Open the print-carriage access door, clear the jam, and then press OK to continue". I restarted 5 times, unplugged the printer, vacuumed inside for any paper etc. Nothing is working.
4 Suggested Answers
rockfixya
  • 679 Answers
SOURCE: HP Officejet 7410 "carriage jam"
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
SOURCE: HP Officejet Pro L7800. Had paper jam, but opened
mine was 2 there was paper stuck in the little white gears
Posted on Jul 17, 2010
  • 26 Answers
SOURCE: Trying to start up HP
The problem is a small gear that is locate in the back left part of the printer. The plastic clip that holds it in place breaks and the gear does not come all the way to the right thus causing an error.
This is not a easy fix. When this happened to me I replaced the complete insides of the printer. If this is a 8500 with the color screen it might be worth fixing but if it is the two line screen then I would just buy a replacement printer online.
If you remove the outer plastic pieces you should be able to see when the gear does not seat properly.
Michael
Perfect Printer Parts
perfectprinterparts@gmail.com
Posted on Dec 02, 2010
Screen reads paper jam even though there never was a paper jammed. I tried turning the printer off and on but the same message still appears. Also the cancel ! keeps flashing even though I cancelled the...
Hello Sande.
Try cancelling the printer job via the control panel in Windows.
Also open covers, including the top flatbed half, to view the paper path.
There may still be a stray piece stuck in there somewhere.
Does this help?
Clive.
Nov 18, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
Had paper jam, removed from back of machine, now display says Carriage Jam Open print carriage access door, clear jam and press ok. I have done this and still flashing up the same msg. There isnt...
If the printer thinks it has a Carriage jam, you might want to try removing the ink cartridges and then putting them back. It's possible they got bumped out of place during the paper jam. Hope you can figure it out!
Feb 28, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Carriage Jam problem. Have gone through complete troubleshooting routine, but the message just won't go away. Says ""Carriage Jam". No debris to left or right of carriage. In fact, the jam was in the paper...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Oct 04, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
My brand new hp 8500 wireless office ink jet printer say open the carriage access door clear the jam. We took the small 2 ink cartiages out and put them in again and this keeps come up.What do we do now?...
Why are you taking out the ink cartridges??
The message says to open the carriage access door and clear the jam. The printer thinks that paper is stuck in the paper path, see if you can find it. I believe that there is also a rear door on that printer, remove it and look inside.
Sep 10, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Error message - carriage jam
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
Sep 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro 8500 has a paper jam. Can't get
Hi! I will be glad to assist you in this issue, here is the link that will fix the issue:
Paper Jam' Message Displays on the All-in-One
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01617494&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
Carriage Jam' Message Displays on the Control Panel Display
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01618201&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
Oct 11, 2009 | HP Office Equipment & Supplies
Ben Johnson
