My washing machine wouldn't turn on after just completing a load. Is there a reset button?
Bob Gemmell
  • 209 Answers
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Posted on Sep 13, 2007
SOURCE: ASKO 6021 washing machine, drawer locked
Reach under the drawer, right side and move the lock mechanism to he left. The drawer will unlock.
Posted on Mar 23, 2009
  • 109 Answers
SOURCE: washing machine will not complete the wash cycle
The timer could be sticking OR: Is the machine empty of water when it stops? This information may help solve your problem?
Posted on Jun 16, 2009
hiltonjug
  • 612 Answers
SOURCE: My Hotpoint washing machine wf340 will not complete a wash cycle
You have a bad printed circuit board (PC board). You will have to replace. I would rate this job a 4 on a hardness scale from 1 to 10. You will need your model number located on the back of the console toward the top. Go to this site and enter your model number. You can order it with a credit card 24/7 http://www.partselect.com/
Please rate this solution if helpful.
Posted on Aug 21, 2009
SOURCE: How do I reset my Frigidaire Affinity Front Load
My Fridgidaire Affinity front load washer has a ERR pause and I can't reset it. How do I clear this
Posted on Nov 02, 2010
Somebody leaned on the buttons of mashine during wash, and it has frozen
Hi Lisa, Before you check out the link below read how To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components.(This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
If that did not solve the problem then it may be the "Lid Switch". Top loading washing machines that have a faulty lid switch will not turn the agitator and the spin cycle will not start. However on some washing machine models it will still agitate but not spin. To properly check this you must remove the lid switch.
How To Fix Washing Machine That Is Not Spinning or Draining
Apr 03, 2016 | Washing Machines
Samsung front loader washing machine power cut out mid load
If by turning off the power you mean you hit the power button .... try unplugging the machine for about 15 seconds and then plug it back in ... this may reset the machine. If not you may want to call Samsung ...
http://www.samsung.com/au/info/contactus.html Hope this helps!
Nov 25, 2013 | Samsung WF337AA Front Load Washer
How do i open my machine?. wash is done but the machine just wont open ???
The usual ways for most front load machines are to try reset of the cycle(using normal reset buttons), completely unplug the machine for 5 min and try again or to turn off machine then press and hold on/off button for 10 sec. Unfortunately this is most often due to a faulty door lock and you will need to have it replaced.
Jul 08, 2013 | Tricity Bendix AW1260W Front Load Washer
MAV4755A Top Load Washer: When I turn the dial to start wash cycle, nothing ...
if press button selection, make sure that no 2 buttons are pressed
Jan 27, 2018 | Maytag MAV4755A Top Load Washer
How do I reset my Frigidaire Affinity Front Load Washing Machine? When I press a button the ERR code comes on and then it turns off.
Jan 17, 2010 | Washing Machines
Error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
Apr 05, 2009 | Bosch Classixx WFO 2866 Front Load Washer
Mar 22, 2009 | Asko W6021 Front Load Washer
Samsung P1053S error code UE
The UE is an onbalanced load fault code.. Unplug the machine to clear the code.. leave it unplugged for about 10 mins and try to run it empty.  If it persists you would be advised to contact a service technician.  Bust of luck
May 26, 2008 | Samsung WF203ANW Front Load Washer
Samsung washing machine reset code
i have samsung
6 kg WA80HAG silver nano
dear'
plz help me to reset washing
machine
thanks
Mar 18, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
