Question about Garden
Cub GT 1554 2006, Had to jump to start and then the when I put the reverse mow button on I lost all forward and reverse motion. Great tractor, 25 miles from repair.
defadad
  • 351 Answers
SOURCE: slow forward motion.
maybe the belt needs tightening
Posted on May 11, 2009
wadembly
  • 513 Answers
SOURCE: Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Posted on Jun 06, 2009
  • 1111 Answers
SOURCE: Cub Cadet engine runs but, also will not go in forward or reverse
you didnt say what model this is, but i assume its hydrostatic because it has a drive shaft. is the hydrostatic unit filled with oil¿ if its ok, check the linkage from the pedal to the rearend (hydrostatic drive) make sure its not broken or loose.. if that l@@ks ok, check both ends of the drive shaft making sure the couplers are not broke and the drive shaft is ok. hope this helps.
Posted on Jul 17, 2009
  • 248 Answers
SOURCE: Tractor will not go in forward gear, only reverse.
Try rocking the mower forward and backward while you try to shift it.
Posted on Aug 22, 2009
Murphybanton
  • 2004 Answers
SOURCE: 1991 735i automatic transmission,no forward drive, has reverse
The transmission has gone bad and all I can say is that you need to replace it.
Good luck.
Posted on Aug 29, 2009
Looking for the sensor schematics for a cub cadet series 1000, LT1050 hydrostatic lawn tractor. anyone help me?
Try looking at the directional lever at the Transmission. The PTO for the deck will shut off when shifting into reverse. You may have to simply disconnect or jumper the reverse switch depending on if it is normally closed or normally open. Try it both ways to see what works. Also check the engine oil level, The low oil level switch will shut the engine down if more than a quart low.
Feb 27, 2018 | Cub Cadet Lawn Mower Deck Drive Belt...
Have a John Deere lawn tractor. It starts and runs fine in forward gears, but when put in reverse it stalls . Any ideas what it may be? Could there be a faulty limit switch of some sort?
does it stall when mowing in reverse?
its supposed to do that
look for an over ride switch or button some the key has to be in reverse position to mow
check owers manual
Sep 24, 2013 | Garden
Gt 245 lawn tractor won't go forward or backward
Check the drive belts first. and make sure the hydro release lever is in the correct position. If it is not- you can push the lawn tractor and have the rear wheels turn. It sometimes doubles as a "Forward" "Neutral" "Reverse" lever on other brands of lawn tractor.
The belts should be in their guides and pulley grooves- check to make sure it does not have a hidden break by having the engine off, and pulling on the belt.
Lastly, check to make sure the hydro itself is not out of oil or low on oil. It uses low viscosity "HyGard" oil. Capacity if you drain the old oil out and refill is 4.6 quarts. Look for a leak if the level is low.
If it still does not move, make sure the levers are set so you are in forward motion positions, and push- if the rear wheels move there is a problem in the hydro unit.
Apr 07, 2012 | Garden
Ok i have a problem with lt 1000 craftsman lawnmower. the tractor starts up runs great just when you put in gear or try to put blades in motion it shuts down can someone plz help
check for a safety switch near your shift handle for the gears . most have a kill switch for when your mowing and go to drive in reverse with the blades on . when you go to do this it puts the shift handle against a metal switch that closes a normally open circut that ends up grounding the coil to kill the engine .. easiest thing to try and dont cost to try . is to unplug this ( temporary ) my mtds have 2 wires not sure if craftsman has these or not . but if so just unplug it and it should work and run like normal if this is what the issue is .
Nov 02, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Model LT1042 (2007) The reverse mode does not function.I turn the switch to reverse mode & push the button for reverse mode and the light does not indicate on and I cannot reverse mow since...
Nearly all lawn tractors on the market are designed to kick the cutting deck out of drive when reverse is engauged.
This is controlled by a simple electronic microswitch which can be disconnected but I would advise to leave it as it is ;)
Oct 11, 2009 | Cub Cadet Garden
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
