Question about Fishing
Penn 4000 Battle. How do I change the direction of the spool?
    New Friend:
    Problem Solver:
  • 7 Answers
Reel only retrieves in one direction. If you turn the anti- reverse button off(lever under spool)You are able to retrieve in reverse.
Posted on Jun 06, 2017
How to fix penn 185 reel?
wekk cut the line and hope it will pull out if not then loosen the side plate a little and try to pull out again
Sep 01, 2014 | Fishing
Tip
Top 10 Best Spinning Reels for 2016 & 2017
Let's face it! It is not easy to find the best Spinning Reel from the market.http://www.topspinningreels.com/ here you find your best spinning reel.When you are looking for a Best Spinning reel, you'll see that numerous brands have a few reels with the same name that come in various sizes (for instance a 100, 200, 400). This is typically in light of the limit of the spool, which directs the general size of the reel.In this video you will see 10 unique models of awesome quality modest turning reels. After quite a while of research, survey and searching for reels data I made my own rundown of main 10 minimal effort turning reels in slideshow design. My rundown incorporates every one of these reels.
Enjoy Our top 10 best spinning reels to buy for the 2016 & 2017 Fishing Season. The Lowest Prices Online!
Visit our website: http://topspinningreels.com/
1. PENN Spinfisher V Spinning Reel
2. Penn Battle II Spinning Reel
3. Daiwa Mini System Minispin Ultralight Spinning Reel
4. Shimano Stradic CI4+ Spinning Reel
5.Okuma Avenger ABF Graphite Bait Feeder Reel
6. Pflueger President Spinning Reel
7. Okuma Trio High Speed Spinning Reel, Black/Orange
8. Abu Garcia BMAX2 Black Max Baitcast Reel
9. Zebco Omega ZO3PRO Spincast Fishing Reel
10.Penn Clash Spinning Reel
on Nov 24, 2016 | Fishing
How do you stop winder from turning backwards
flip the switch that is located under the spool/body.
Jan 11, 2011 | Penn Spinfisher 7500SS Saltwater Spinning...
Drag automatically tightens as line is pulled from spool
Clean and grease the reel. Make sure all washers that belong on inside are installed properly
Oct 31, 2009 | Penn Spinfisher 950SSm Saltwater Spinning...
The Drag on my 750ss does not work what could be the problem?
This happens after you screw the drag too tight so that the plastic washer under the spool is pressed out. The fix is simple: cut excess of that washer and tighten properly.
May 30, 2009 | Penn Spinfisher 7500SS Saltwater Spinning...
My Penn 114H cant't tighten drag,only to 12 lbs ,when I tighten the I can pull the line at 12 lbs
http://www.pennreels.com/
Call customer service.
Your drag is either worn or it is assembled improperly.
When I need parts or service, I call penn directly. They are the best reels out there as far as I'm concerned. And most of them are made in USA and backed by Penn.
It is the only reel that I care to fish with
Apr 21, 2009 | Penn Gt Series Levelwind Reels 330GTi
Penn Spin Reel will not lock after casting
On the front of the spool there is a device to turn to set the drag. Torn it tighter and tighten it until slightly below the breaking point of your fishing line. It isn't a critical adjustment, it just keeps your line from breaking while trying to land a fish.
Nov 29, 2008 | Penn Gt Series Levelwind Reels 330GTi
Correction spool
The feeder spool goes on the pin to the left of the carrier with the sticky side toward where the paper would be. Feed it through the ribbon guide and then attach the other spool on the pin on the right. Be sure both spools are snugly snapped into place - mine kept flying off.
Sep 17, 2008 | Brother SX-4000 Typewriter
Fishing Logo
229 people viewed this question
Top Fishing Experts
ray gallant
Steve P
Steve P
Andrew Taylor
Andrew Taylor
Are you a Fishing Expert? Answer questions, earn points and help others
