KFR-70GW/GX1a what tonage is this unit ?? - Heating & Cooling
SOURCE: We are trying to find out what an E4 on a Celiera
Does anyone know what does that means
Posted on Aug 08, 2010
  • 1796 Answers
SOURCE: How does the Timer and Sleep functions work for
Hi!!
On the timer function, when you press the button, it will ask you the starting time and ending time of when the unit will start and turn off by itself. prior to use this function, the clock on the control has to be set.. On the sleep function, it will give you the option to turn off unit on 30 min. intervals. Just like on a TV.
Posted on Aug 10, 2010
hvac1960
  • 2133 Answers
SOURCE: i have an celestial air
Check temp setting minimum -3 degree than your room temp and also in cool mode. If while settings there any beep sound? If not transmission problem between remote and PCB. Replace batteries and check once again. If beep sound comes and no start, check compressor is working and also with proper gas pressure. Thanks.
Posted on Jan 22, 2011
mpcheeseman1
  • 1400 Answers
SOURCE: my kfr-51gw/gx1a unit is 3 yearrs and is blowing a black like suit out off it
The soot is temporary.Will go away.Check the flue damper is moving freely.
Posted on Nov 22, 2011
Remote control required for airconditioner
Not too many units only work with remote control...try using Bing or Google to find your problem and solution to the answers that you seek.
May 18, 2013 | Heating & Cooling
My kfr-51gw/gx1a unit is 3 yearrs and is blowing a black like suit out off it
Nov 22, 2011 | Heating & Cooling
I have an celestial air con unit model KFR-70GW/K it is blowing air refresh out but will not turn on to air con with the remote... help
Jan 22, 2011 | Heating & Cooling
We have a spit system air conditioner.Celestial KFR-70GW/K it is leaking water/condensation internally behind the fan.I think it it from therear grill and for some reason it does not go into the drain...
Leaking water from indoor is a common problem. Please check the following:
1. Cooling coil and air filter blocked-Clean it. 2. Drain pan and hos dust blocked-Clean it. 3. Non insulated pipelines-Insulate properly. 4.Less rpm of blower motor.-Replace capacitor.
Helpful?
Jan 01, 2011 | Heating & Cooling
How does the Timer and Sleep functions work for the SUMO KFR-70GW Heat Pump
Hi!!
Aug 10, 2010 | Heating & Cooling
Mar 30, 2010 | Heating & Cooling
Require instructions and wiring diagrams for Celestial KFR-70GW/K
If you pull the unit out of the case it should have a wireing diagram in a envelope near the compressor
Jul 17, 2009 | Frigidaire FAA065M7A Air Conditioner
Amani Whisper Series Model KFR 70GW keeps turning itself off
Just had the Amani service guy out. Had the same problem. It was the capacitor. Took about 15 mins to fix. The machine turns off to protect itself because it knows something's wrong
Jan 05, 2009 | Heating & Cooling
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
