Question about Hardware & Accessories
I have several DT 121 timers that were flashing LO. I replaced the batteries with new Energizer's and they still flash LO. They function when plugged in but have no memory if power is lost
They are installed with the proper polarity but still flash LO. I've changed the batteries with the same results. Any idea's Help Bob
Gryfox
  • 216 Answers
SOURCE: my nikon n55 is flashing err after installing new film
It could be that your camera doesn't know it's rewound the film already. With the camera turned on, push and hold BOTH manual rewind buttons simultaneously - one near the release button ( +/- ) and the other toward the front of the camera at the lens release button. Try the release button again.
Posted on Jan 03, 2009
  • 14 Answers
SOURCE: Energizer 15 minute Ni-MH Battery charger
A flashing red light indicates that there's an error, or the batteries are defective.
No, the unit won't switch itself off once the batteries have been fully charged. The unit will start trickle charging instead.
Posted on Jan 05, 2009
  • 8 Answers
SOURCE: cradle not working
make sure that you didn't put the battery in backwards. It can be done and obviously, it won't charge
Posted on Apr 23, 2009
VtToolMan
  • 704 Answers
SOURCE: Intermatic Model DT 121 "LO" after programming
That is the visual indication for a "LO" battery. You need to replace the battery very soon or the timer will cease working properly.
Typically with this model of Intermatic timer, you only have about 30-40 seconds to change out the battery before the programming is erased and you'll have to re-enter your desired on/off cycles and such.
The battery is located under the manual push faceplate, just flip it down and you can either use a small flat bladed screwdriver or your fingernail to open up the battery compartment to change out the battery.
Hope you find this Very Helpful and best regards!
Posted on Sep 09, 2009
Testimonial: "Exactly on point."
welcomejee
  • 10594 Answers
SOURCE: power light is flashing 3 times consecutively.
Put lamp cover back in its place as 3 times blinking light shows lamp cover has not been fixed.
Lamp cover is first thing that you removed to replace lamp in tv, make sure it is fixed securely in its position.
Posted on Aug 13, 2010
Why does my Energizer CHVCM3 battery charger flash green lights with four batteries in it
The manual says it will be green when the batteries are placed in charger correctly. It has an automatic charge timer an shuts down.
May 03, 2017 | Energizer Electronics - Others
Anyone have a problem with replacement battery for SS8 intermatic timer
Copy following link for all Intermatic timers, including new Ej600, and older SS series timers.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Try resetting the timer. Hold down ON-OFF button and push and release reset button. Keep holding down ON-OFF until display starts flashing 12:00
Clean battery terminals.
My SS8 manual shows 1.5 volt alkaline battery but does not specify the shape or size of battery.
If the display is visible, then timer is getting power.
The low battery error might clear up after reset, but if it does not, then replace timer.
Intermatic has new EJ600 timer that has internal rechargeable battery, and does not need battery replacement. Or use ST01C or Ei600.
Remember also that timers cannot be exposed to extremes of hot or cold, or the battery can stop functioning.
May 01, 2012 | Intermatic Hardware & Accessories
Timer display says "Lo Battery". I put two new
Intermatic timers might require reset-and-reprogram after battery replacement.
To reset, hold down on-off button and push reset button once.
Keep holding on-off button until display changes.
Release on-off button, and display should blink 12:00
Try cleaning battery carriage contacts with alcohol and make sure battery polarity is correct.
If functionality is not restored, then replace timer.
Intermatic EJ500 comes with 1 year limited warranty and is rated for incandescent light bulbs only.
Aug 08, 2011 | Intermatic Inc. EJ500C Digital Wall Switch...
Iam using Energizer 15min charger. I have used for a longer time. Now the charger red light blinks while trying to re-charge batteries. I have tried various batteries but red light blinks. Failed to charge...
A flashing light indicates that the charger seems to detect a problem with the cells. (two or more cells form a battery). Since you've tried other cells, it can be reasonably assumed that the charger is faulty and should be replaced.
Feb 14, 2011 | Energizer 15 Minute Battery Charger Combo...
The LED's on my Energizer charger flash red and green constantly.
If your charging 2 batteries only they must be palced in the following poistions on the charger
1. both side by side in the 2 left slots
or
2. one each in the two right slots.
Otherwise the batteries will not charge.
The users manual can be downloaded here:
http://www.energizer.com/SiteCollectionDocuments/pdf/rechargeable/CHDC.pdf
Thanks for using FixYa.
Kelly
If the batteries are charging the battery indicators
Mar 24, 2010 | Energizer Rechargable Battery with Charger
Aug 25, 2009 | Hardware & Accessories
Dec 24, 2008 | Energizer 15 Minute Battery Charger Combo...
Hardware & Accessories Logo
59 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
