Washer will not start after 3 compleated loads this morning
  • 1,830 Answers
What brand of washer is it and what year and model?
Posted on May 18, 2017
I have the atf6000fso front load washer it does not spin
Good Morning Friend,
I understand your Frigidaire washer, model# ATF6000FS0, is not spinning. Try adding 1 or 2 similar items to help balance the load, as the load might be too small. If that does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 27, 2014 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer FTF2140 upon start it began filling and then turn off, did this everytime. Unplugged it and the same thing happened. Now the lights stopped coming on and it does not work.
Good Morning Heather,
I understand that your Frigidaire washer, model# FTF2140, begins to fill and then turns off. You unplugged it, trying to reset it, and now the lights are not coming on and your washer is not working. Since you have already reset your washer, by unplugging it, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what the cause of your washer not working is. Hope this is helpful.
-Best Regards-
WP
Apr 29, 2014 | Frigidaire FTF2140FS Front Load Washer 10...
Holds water wont compleatly drain shuts down before spine cycle
Hello
If the washer shuts down before spin cycle it indicates that it is unable to drain properly. Please check the drain hose/drain pump filter for any clogs/blockages and try cleaning them to solve this problem. Also after cleaning check if the pump is working fine.
Kevin
Nov 10, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
THE WASHER DOES NOT COMPLEAT THE CYCLE IT STOPS AND Codes IE
Are all taps turned on, is the filters in the hose connections clean? The code means it is not getting water, if water supply is ok one of the valves may be faulty.
Apr 18, 2010 | LG WD-3274RHD Front Load Washer / Dryer
Power Washer will not start - pull cord seems to be stuck
hi take out the bolts holding the compleat pull starter remove unit pull the cord if it wont move something is jamming it inside if it is ok then the fault is with the motor //seized or washer remove washer pump if engine turns over /pump seized the fault is 1 of the three you have now found out wich 1 starter, motor or pump it will take too long to go over all 3 get back when you have got this far merlinv12
Aug 22, 2009 | Honda Maxus Pressure Washer MX5222
Help my kenmore will not run a compleat ccycle
* The motor spins backwards during extraction, so there could be a problem with the motor, timer or a short in the motor wiring harness. Unplug and replug the harness.
Jan 22, 2009 | Kenmore 22422 Top Load Washer
Fault F15
Smash the **** up and get a real machine!
Apr 16, 2007 | Dyson Flowcheck CRO1 Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
