Question about Home
Can you put new rubber gaskets in a single handle bath tub faucet to fix a drip?
    Top Expert:
  • Home Master
  • 45,112 Answers
Depends upon the design. I have repaired Delta faucets using parts provided in a kit.
Posted on May 18, 2017
Delta 400-DST Single Handle Kitchen Faucet Spigot Drips
I've installed quite a few of these from the big box stores that leak. There are 2 rubber pieces inside the valve body that act as seats. The seats are what turn the water on and off as you move the handle. These rubbers need to be replaced. You can buy a delta repair kit, which will contain these parts. Where the faucet is new, it might be easier to bring it back
Mar 02, 2014 | Delta Faucet Plumbing
I do not have the side spray, but there is a dripping that is getting hard to stop. Can't stop the drip and would like to know what I need to do to fix. I have already tightened the screw on the top....
faucet needs new gaskets and springs located below the handle. remove handle, loosen collar nut and remove, pull cartridge out straight up, remove gaskets and springs, take to local Home Depot and buy new and replace. install cartridge, install collar nut, install handle. All finished.
Aug 30, 2011 | Kohler Fort© Single Lever Handle Kitchen...
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
I have a Moen shower tub single handle from the
I took the parts to the Menards in town. Luckily I found the guy that knows it all! He showed me the rubber gasket( that holds the ball) to purchase as well as recommended that the 2 small rubber gaskets that were in there to be replaced as well while I had it open to avoid doing this in the future. I got home and replaced them and no leaks:) Thanks:)
Aug 28, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
Jun 14, 2009 | Water Pik WATERPIK SHOWER HEAD COMBO PACK...
Single handle tub/shower leaked, now not working
you may have installed the stem incorrectly or something is blocking the water passages inside
Apr 11, 2009 | Plumbing
Tub faucet drip
Hi, You have to replace the two rubber cups in the hot&cold faucet lever. Let me know if you need more info.
Nov 09, 2008 | Banner Faucets Pro Series M580 Single...
Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Moen 2919 Chateau Two Handle Tub and...
Home Logo
32 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
