Question about Power Washer Garden
Purchased a troy-built power washer on 5/16/17. When I tryed to use it there is a hole in the wand hose.
    Top Expert:
  • Power Washer Master
  • 40,324 Answers
Sooo.....return for replacement
Posted on May 18, 2017
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How to remove calcium buildup from pressure washer pump
I have found t vinegar has many uses. Mix the water with vinegar
Jul 09, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
I have a Troy Built pressure washer and don't have much pressure from the wand. I loaned it to a friend (mistake) and when he returned it it was not working right. I know he tried to change the...
Try this disconnect the nozzle that sprays off the sprayer itself and see if there is dirt plugging the end. Mine was plugged two thirds and hardly any pressure. Mine has a fine screen that filters the dirt out. If your garden hose gets dragged in the dirt there will be enough to plug the hoses in the unit. Do this for all hose connections.
Feb 06, 2018 | ALL POWER AMERICA LLC All Power America...
My Troy Built pressure washer shuts down when I turn on the water. Is the pressure cut off valve that might be frozen?
Hold the trigger of the pressure nozzle open. Turn on the water . Wait to see water coming out of the pressure wand.Then try and start the engine. They can get air locked.
Feb 12, 2010 | Karcher 2500 PSI Pressure Washer
Ex-Cell VR2500 Builds Pressure but Won't Spray
I have a similar problem and diagnosed it to be a problem with the gun. I spoke to a technician that services this pressure washer and he walked me through all the diagnostic steps. The pump is working because there is pressure being built up and the gun sort of works because you can get water out before the washer is started. The technician said that the mechanism inside the gun is either clogged or broken. I am going to Home Depot or Lowes to purchase a new gun and will try it tonight. Guns are only about $30-40. He said generic is fine as long as the thread matches and PSI is in range. Good luck!
Aug 09, 2009 | Karcher 2500 PSI Pressure Washer
My Troy Built 2500psi washer will not pump cleaning solution.
Next problem will be the spray head itself. It needs to be cleaned with a small wire from time to time.
Jul 21, 2009 | Karcher 2500 PSI Pressure Washer
Have hole in water hose to wand. can it be fixed
you cannot fix the leak, you must replace the hose.
Jul 14, 2009 | McCulloch FH160G Pressure Washer
I have pressure coming to my wand but when i attach the nozzel the water comes thru but with no force? I am trying to take the nozzel apart but can seem to do so. It is a Troy Built Washer and the wand is...
the red button is just for the warning label. Did you pull the nozzle down. This nozzle is an adjustable nozzle. You push it in and this is for the soap injector and you pull it out for the pressure. If you have done this, then you may need to replace the nozzle. You can even put a quick diconnect on the end and use the small tips you can buy local or replace with the same type nozzle.
Also check to see if there is something blocking the hole.
Jun 17, 2009 | Briggs & Stratton Garden
Garden Logo
20 people viewed this question
Top Power Washer Garden Experts
Dennis Key
Dennis Key
john h
Are you a Power Washer Garden Expert? Answer questions, earn points and help others
