Question about White Rodgers Home Security
I have a White Rodgers 1F87-361 Thermostat. Everything works with heat.turns on when it falls below hold and turns off when it hits temp.AC is issue. fan will not turn off at desired temp.
  • 27 Answers
SOURCE: Honeywll Chronotherm 3 reading Hold AC
the power to your furnace has been turn off. check the switch at the top of the stairs.
Posted on Nov 26, 2008
mastatech
  • 478 Answers
SOURCE: Heat pump cycling on and off.
It sounds as if you you have a low charge of refrigerant, r22. When the unit comes on outside, the outdoor coils become the lowside, there is a low pressure switch that is tripping out contactor protecting the compressor.
Posted on Mar 11, 2009
paulm10
  • 73 Answers
SOURCE: AC turn off before it reaches the desired temp
Hi there. I assume the indoor fan runs continuously until the house has cooled down. Clean the condenser. (outside unit)
Another possibility is that the system is getting low on freon. Check for leaks with soapy water at all joints and fix them.
Thanks
Paul
Posted on Jul 13, 2009
liteswink
  • 99 Answers
SOURCE: No Heat with new White Rodgers 1f85rf-275 Thermostat
The only way to resolve this problem and to distingush if its a thermostat issue on the system is to by pass the thermostat by putting a jumper between the hotwire and the heating wire if the system did run which happen most of the time. Call the HVAC technician to check your heating unit. Or call the White- Rodgers technical line at 18887259797 choose contrator division.
Posted on Oct 20, 2009
SOURCE: On my white rodgers thermostat 1F80-361 air and heat wont work
Mine is doing the same thing!! My daughter and I are FREEZING!!!
Posted on Jan 10, 2011
White rodgers customer service phone number
we are not white rodgers /emerson --the following links can assist you but if the trooble shooting doesnt fix problem just replace the stat
White Rodgers White Rodgers White Rodgers Thermostats Thermostat AC Wholesalers How to Troubleshoot White Rodgers Thermostat eHow
May 30, 2017 | Heating & Cooling
I have a white Rodgers ac thermostat and the temperature in my apartment stays on 88 no matter how low I set the temp. If I turn it off, of course it gets even hotter. This started happening when I pressed...
I'm not quite sure I understand what you have done but, make sure your compresor(outside is running and, that you don't have the thermostat set to "fan". You want the display to show "cool" and then adjust your temp. It sounds like you have the system set to fan and not cool. Provide me with a model number and I will see about getting you a manual.
Jun 04, 2011 | White Rodgers 0754-1 Electric Water Heater...
Blows heat until it matches the thermostat then it just stays on and keeps blowing semi cold air. It just maintains the temp but will run all day and night. It is a heat pump with emer/aux heat. If I...
Download a PDF version of the Operating Manual HERE. ___ *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Feb 01, 2011 | White Rodgers White-Rodgers 1F85RF-275...
We are renting a house with a white rodgers thermostat. we always adjusted the ac with the up/down arrows. the heat has been on this season, but it always seemed to be on a pre-programmed schedule. It...
If your rental agency/landlord cannot help you with this, the Operating Manuals for many White-Rodgers thermostats can be found in PDF form HERE, however they are not indexed by model number so you will have to download each file in turn until you find the one you want. All of the file names beginning with "0037-" seem to be W-R products.*Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Oct 29, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Thermostat resets itself to 85 degrees a couple hours after I set it to 74 degrees
To manually operate the thermostat set the system to cool and fan to auto then press the HOLD button one time then release, you will see the hold word on the screen after that up the UP or DOWN arrows is setting the desired temperature.
Jul 22, 2010 | White Rodgers White-Rodgers 1F85RF-275...
My AC unit is 3 years old. its set at 72 but wont go below 78 degrees. im in Las Vegas...Help
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the AC manufacturer or a service person to verify the cooling system is operating correctly.
Or call the techline 18002842925.
Jul 18, 2010 | White Rodgers White-Rodgers 1F85RF-275...
We have the white and rodgers thermostat model 1F81-261. The problem is that the ac unit will not work. We have reset and changed the batteries and set the point 4 degrees less than the actual room...
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Jun 28, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Its saying MO in the upper left hand corner and AC won't turn on
Diagnostic: Set SYSTEM Switch to COOL and lower the setpoint below room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. Ifthe thermostat does not click, try the reset operation .If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks,contact the AC manufacturer or a HVAC service
person to verify the cooling is operating correct.
MO stand for MONDAY.
Jun 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
My name is Tim Burke from White-Rodgers. If you hear the "click" the thermostat is calling. It would appear that their is a wiring issue to the funace. Please contact our customer service toll free hot line and they will be happy to walk you thru it and assist you. 877-978-7828
Regards,
Tim
tim.burke@emerson.com
Tim
Oct 19, 2009 | White Rodgers White-Rodgers 1F85RF-275...
Home Security Logo
21 people viewed this question
Top White Rodgers Home Security Experts
Nicholas Bannister
Tom Chichester
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
