Question about Zassenhaus Coffee Makers & Espresso Machines
Hallo, My new Zassenhaus Quito coffee grinder is making sound like winding up a clock when grinding without beans. I don't think this is normal, could you please hep me with this. Thanks, Jorick
When grinding with my new Zassenhaus Quito without beans, it makes a 'winding' sound. I believe to remember that the version which I've seen in storedidn't make any sound like this.
SOURCE: Coffee Grinder on the EAM3500
We just went through the same situation. We opened the top the Magnifica to get to the grinder and removed the four screws to seperate the grinding pieces. Inside we discovered two black fosilized beans/stones! We removed those, cleaned out all the bean dust and it is working like new! Took about an hour.
Posted on Dec 28, 2008
SOURCE: grinder does not work!
http://www.cerinicoffee.com/custompages/Tech/Grinder_Adjustments_for_Italia.pdf
Posted on Apr 12, 2009
SOURCE: Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Posted on Aug 14, 2009
Testimonial: "Grinder is turning but old bean oil is clogging it. Stirring beans on next brewing after drying the grinder was also customer services recommendation"
  • 1089 Answers
SOURCE: the coffee grinder on my Magic Comfort Plus is not
Hi Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute. Once that is cleared go to the bean hopper. There is a lever under the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time, but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
Posted on Jan 25, 2010
EsWorld
  • 1618 Answers
SOURCE: grinding and dumping coffee without making a cup.
Check the grind it might be too fine, then check the screen under the red o-ring in the brew unit it might be blocked.
Posted on Feb 26, 2010
Fill beans
the coffee beans are not entering in the grinder disks and since they rotate without coffee the machine understands that their is no beans. You need to clean the grinder disk and grinding coffee funel to bee sure their nothing blocking the coffee movements. Use a vaccum cleaner and try to clean everything in grinder and grinder exits. Try also the machine by regulating thegriding to more gross coffee and when it will start grinding normal then you can udjust step by step back to grinding position you have at the begeining.
Feb 27, 2012 | DeLonghi ESAM 5500M
Blade will not spin
While I don't have this brand or model of grinder, (coffee beans, spices?), I use a small elec. grinder for grinding coffee beans and unless the grinder and cover or perfectly lined up and locked in place, it willnot grind, a safety feature. Check and make sure everything is lined up so it closed with all the lines in place and the grinder is also put into the lock position.
Aug 21, 2011 | Cuisinart Grind Central DCG-20N Electric...
How many seconds of grind for standard drip grind
I've long ago lost the manual that came with my grinder (I actually don't remember if it even had one), but I don't think it listed grinding times. You just grind a few seconds and check, then grind a little more if it's still too coarse. Unlike a burr grinder which is adjustable, in a blade grinder the same grind time may result in different consistencies as you change beans. By now I've just learned how long to hold the button for the different beans I buy, and the first few times I try a new blend or varietal I have to adjust the time. I think you'll just need to experiment and then you'll know what works best for your tastes.
Jun 30, 2011 | Braun KSM 2 Electric Blades Grinder
Aug 14, 2009 | Jura Capresso Impressa E9 Espresso Machine...
Cuisinart DGB-700BC grinds but no grounds in the basket.
Hi there, you have some kind of blockage, If the beans are going down, you need to remove the brewer unit and wash it, if the beans arent going down the exit of the grinder is blocked and needs to be removed, cleaned and replaced
Jul 26, 2009 | Cuisinart DCC-1200 Coffee Maker
Zassenhaus knee coffee mill grinds too coarsely
I have a Zass and sometimes have a problem with it self adjusting, but when I do need to adjust it, I find that I have give it a good tap on the top to make sure it adjusts. So, just turn the knob counter clockwise as far as it will go, then give it a good knock on the top and bottom and try again. My mill offers the full grinding range, from a fine powder to large chunks.
Feb 04, 2009 | Zassenhaus Knee Mill Hand Crank 156 Manual...
Grinder starts up but wont grind..nothing happens. one week old
I think this might be because no beans have gone down into the mill. There is a definite difference in sound when it is actually grinding beans. Try emptying the beans out, set it to the coarsest setting, put the beans back in, shake the thing a bit then turn it on.
Jan 17, 2009 | Krups Burr Coffee Grinder
Aug 31, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Incanto-classic coffee beans do not flow to grinder
The machine automatically stir the beans since the blade make vibration and doing that shake the bean all around.Make sure the the tank is half full so the weight will help on that.If the container is almost empty the bean will fly around and don`t get in the grinder.Back up the machine to the original factory grinding and try to adjust again the wheel
Jun 07, 2008 | Saeco Incanto Classic Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Zassenhaus Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Zassenhaus Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
