Question about Kitchen Ranges
How to clean coils on Jennair model JFC2089 - Kitchen Ranges
Cleaning a self cleaning oven
I couldn't find any information on that specific model number, but here is a link to a generic Jenn-Air Electric Range - Use and Care Guide which seems to be model non-specific. The instructions for performing a self-cleaning (as well as other tasks) might be the same for yours.
http://www.jennair.com/assets/product/8113P619-60.PDF
Jan 05, 2008 | Ovens
My Jennair refrigerator (Model #JCD2389DES) does not stay cold. The freezer is cold but the fridge is room temp. There was a bit of frost inside the freezer. Looked up some advice and was informed that...
clean the coils under the ref will help it to run less and cool better . and make sure the fan under there is going also . but the ice or frost that you found in the freezer is the problem . it has block the air flow that cools the fresh food side . this is caused by 1 ot three things . i would replace the defrost terminator on the top of the cold coil first and if this does not correct problem replace the defrost control ( timer or some times called the A D C . ) part # 6100 5988 ) the heater is pr # 61006199 and comes with the terminator . hopt this helps mm feed pack please ..
Jan 01, 2011 | Refrigerators
Jennair gas range model jgr8850adw, has an error code of f1 during oven cleaning cycle, help?
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.
Oct 30, 2009 | Jenn-Air...
My (new to me) apt has an electric jennair stove top -no instruct
Try http://www.jennair.com/flash.cmd?/#/page/home
Click on cooktops.
I have looked, but cannot find your model number. Perhaps if you look, you may be more sucessful, they do have pics and descriptions.
Oct 15, 2009 | Kitchen Ranges
JennAir 88370 Door Handle replacement
Old part number y700442 subs to 12001222 retails around 60 bucks and is available,thats if your model number is correct.
Sep 01, 2009 | Ovens
Jennair JMV8208BCS No instructions in box
Hello. the installation of wall mounting bracket is not too difficult. you will need a drill, some bits, and a scrrewdriver. you will also need an electrical outlet at that spot to plug in the microwave.
Jennair makes a bracket kit for each microwave. Call any jennair dealer, have your model # handy and they will get you the bracket you need, also ask specifically for the instructions.
Aug 12, 2009 | Jenn-Air JMV8208A Microwave Oven
Kitchen Ranges Logo
22 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
