SOURCE: open heat error
"Open Heat Error" Means --- You need to make sure the voltage of the fuser is compatible with your printer.
Please rate the solution.
Thanks for using FixYa.
SOURCE: PRINTER NOT PRINTING ERROR MESSAGE :
This is the problem of the fuser unit. You may get it repaired/changed . Also you may approach Authorised servic ecenter.
SOURCE: led screen says open heat error cycle power
if the Fuser unit rubber are not burned , change the
Fuser unit Thermister....
SOURCE: Will not print shows open heat error cycle power
First try turning the machine off and back on. If they error continues you most likely need to replace the fuser (part number 126N00265 for 110V U.S. or 126N00266 for the 220V U.K. version). ItemInc.com has these in stock and ships same day. Just open the rear door and unscrew the 4 screws using a phillips screw driver to remove it. Here is a video that shows you how. Hope this helps, and thanks for using FixYa!
