Question about Hotpoint Washing Machines
Hello please could you help me with hotpoint washing machine model numberWML740. I can't seem to unset the spin speed so i can spin my wash load. i can see the spin icon with a line through it
  • 121 Answers
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Posted on Mar 03, 2008
SOURCE: washing machine will not spin
MY WASHER WANT SPIN AT ALL
Posted on Nov 15, 2008
  • 53 Answers
SOURCE: Hello-My Beko washing machine (WMA 1512 W)does not
recheck the brushes & pump/filter/outlet hose (make sure all cleaned out and impeller free to turn) your problem lies in there somewhere.
Posted on Oct 21, 2009
Testimonial: "Hello -The brushes have about 10mm left but will re-check ,the pump works well, I suspect the speed module board Regards Andyrooshous"
SOURCE: Washing Machine doesn't spin.
kitchen aid "quiet scrub" won't pump out the water? perhaps replace the unit or fix it?
Posted on Mar 17, 2010
barkencoa
  • 3463 Answers
SOURCE: washing machine is jumping around on the spin cycle
A few possibilities here.
Make sure the washer is level, both back to front, and side to side.
Do not over load, and make sure that there is more than 1 article in it, otherwise you will get an out of balance load.
Make sure the water is drainlng away properly.
Check the drum for excess movement, this would indicate a broken spring or worn drum bearings or worn or broken drum shaft.
Check the concrete wieghts at the top and bottom are not loose or broken.
Check the suspensions for excessive wear.
Hope this helps
Posted on Mar 31, 2010
The quick wash takes over an hour any suggestions how to make it quicker?
The manual says wash number 5 takes 60 minutes the only shorter cycles are numbers 9 & 10 which take 55 minutes but they are cooler washes for wool and silk with a spin speed of 800rpm the number 5 has a spin speed of 1400rpm.
Apr 26, 2015 | Hotpoint Aquarius WDL540P White 60 cm...
Hotpoint washing machine faults
Nicky, try a dry run without a load. Also check if moving to different levels gives you any reading. If not, you have narrowed down where the problem is.
Mar 01, 2014 | Washing Machines
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Jun 15, 2012 | Hotpoint Washing Machines
My Hotpoint Aqualtis washing machine leaves
the drain **** in the machine is partially clogged. my best guess is at the water pump. your washer needs to be serviced. call a serviceman..
Nov 15, 2009 | Washing Machines
Operating instructions
Hello.
I can help you with your query.
In your browser bar type in hotpoint user manuals
In the drop down list, click on
manuals-user guides-handbooks-hotpoint service
In the search box enter your model number and download the instructions.
Please rate my fixya solution.
Thankyou
Jan 29, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint washing machine final spin
possible door latch control may not be reading door switches closed
Dec 21, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Does not spin and rinse properly
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
Feb 16, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
