Question about Jenn-Air Kitchen Ranges
Jenn air oven installing new control pannel and has a 17 pin ribbon connection new part came with the black plastic pin mount on it do you pull the ribbon out and how do you get the new one in??
    Guru:
  • 310 Answers
I've seen both the ribbon cable and pin connector version of this, I think they are different part numbers (for the control panel). Can you provide model/part number info?
By the way, we may be able to repair your old one.
- www.fixyourboard.com
Posted on Jul 26, 2009
Jenn Air wall oven won't cancel / shut off . Recently replaced membrane.
Hey - the ribbon link from membrane to control is a tricky plug to get in right- double check this connection and let me know if it helps- Thanks- Ed
May 13, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Ww304430p lights on control pannel are very dim
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the
design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, Using as small a soldering iron as you can find De-solder it and replace with new, match polarity marks and don’t use any more solder than needed.
If you run into trouble drop me an e-mail to dltatsjc@aol.com and I’ll try to help.
If you opt to just replace the control board see if this link helps; Parts website:http://www.repairclinic.com/Home.aspx
Good luck.
Thanks for this site..
Mar 03, 2010 | Jenn-Air JJW8230D Electric Double Oven
Electronic control panel not working. Part not available for 2 months!!??!!
Not the same model # but worth checking out,
Good luck.
Nov 09, 2009 | Jenn-Air JGS8750ADS Gas Kitchen Range
Jenn-Air JJW8530 LCD panel does not light up
Good luck.
Link to Photo sequence of capacitor replacement (Captions still will not link):
http://picasaweb.google.com/dltatsjc/Photos?authkey=Gv1sRgCJPKv9CRgsXxNA
Oct 08, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn air ww30430p led controls are dim can't see temp. Need to change what part? and the doors never closed correctly
Good luck.
Sep 23, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
LED display does not light up. All other control functions seem to be working.
work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, De-solder it and replace with new, match polarity marks and don’t use any more solder than needed. TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
Good luck.
Jul 07, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
My jenn air model ww2780w double oven has nothing lit up in the digital panel, and i cant use the darn thing. Help!!!
BrianGem posted a great solution back in May of 'o8, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board appearently has a weak spot in the design, most likely heat related, (probabily low priced components from offshore sources)
Fix: Replace heat dammaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm luckey enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recomend changing sizes without design review for fear of overloading another componant, however several other posts have indicated a 35V 100mF cap has worked fine for them.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capicator is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unpluged. Capicator is likely discolored or leaking, Desoulder it and replace with new, match polarity marks and dont use any more soulder than needed. TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS. and good luck.
May 12, 2009 | Jenn-Air Electric Double Oven
Dimdisplay
The display board apparently has a weak spot in the design, most likely heat related, (probably low priced components from offshore sources)
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, De-solder it and replace with new, match polarity marks and don’t use any more solder than needed. TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
Good luck.
Jjw9630aab panel is dim
See other posts regarding replacement of capaciter #C3 on control board, cost of capaciter approx 65 cents.
Good luck.
Mar 25, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
SCD302 Thermador oven
I can't guarentee you have the same problem but my Jenn Air did the same thing.
Good luck.
Aug 19, 2008 | Jenn-Air Electric Double Oven
Kitchen Ranges Logo
138 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
