Question about Garden
Lawn tractor with Kohler CV16S 43518 engine had battery installed backward,now fuse blows when battery connected. Tested continuity of first device off pos. battery terminal not con pos to pos
  • 513 Answers
SOURCE: Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Posted on Jun 06, 2009
  • 197 Answers
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Posted on Nov 14, 2009
  • 197 Answers
SOURCE: I have a John Deere LT 1`33 lawn tractor with a 13
I believe they are 8mmX35mm.
  • 223 Answers
SOURCE: Upon replacing old battery, I accidently got the
Your charging regulator has failed. The reverse voltage caused one or more diodes to fail shorted, and this short is blowing the fuse.
Posted on Jan 08, 2011
SOURCE: KOHLER 15.5 OHV engine runs wide open all cables
Drive it in a ditch, let the lawn grow. Don't change your underwear and shirts and always smile and wave to the neighbors as you bend down to get their paper each morning;)
Posted on May 04, 2011
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ... > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
How to adjust the valves on a Kohler command 13 CV16s
you need a valve job done and valves replaced you have to take in maybe carb rebuilt to valve job 100.00 per cylinder carb rebuilt 80.00
Sep 14, 2014 | Garden
I have a kohler model cv16s in a lawn tractor, sears model 944.608961. The problem is that the ignition is intermittent. I have replaced the spark plug and turned the engine over, plug out, it may spark...
weak spark could be a ground problem or it could be module itself check the wires that go to the module for nicks or cuts if none exist I would lean more toward the ignition module
Oct 19, 2012 | Garden
How do I connect wiring on Kohler CV16S motor to craftsman mower that had a B&S YBSXS.7242VFmotor?
You need to know which ones are the kill wire, charge wire and starting wire for both side of the harness and make you own connector.
Dec 06, 2017 | Garden
How can I test a riding mower regulator? (puts out 23 amps @ 3800 rpms. My dmm only goes up to 10 amps.(system won't charge battery while in operation. Can it be tested off the mower? Mower is a Craftsman...
Simplest test is to leave it on the engine, battery hooked up normally. Run the engine at normal full speed (not just idling) and use your voltmeter to measure the voltage across the battery with your DMM. If you measure 13.5 to 14 volts, your rectifier/regulator is probably OK.
It can't easily be tested off the mower. You'd need a source of AC at 24 volts to simulate the motor's stator winding, and a load that draws about 23 amps at 12 volts.
Don't forget a bad battery can cause failure to charge - it's not always the regulator.
Jul 16, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Have a Craftsman , with 25 HP Kohler engine & 50in. deck. Just stoped running whlie mowiing. Now won't start, Sounds like battery dead. Checked seat safty switch by jumping eires, did'nt solve problem
My Briggs and Stratton did the same. Look under the hood along the wiring harness for a 20 amp automotive type plug in fuse. Mine was blown, but fuses blow for a reason. One of my headlight connections came loose and shorted to ground. If yours has that fuse look for a short.
Apr 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My riding mower blows fuses once you turn the key.
Sounds like you are on the right path, maybe some wires on the ignition were replaced backward, and you are sending +12v directly to ground? Does it blow right away?
Jun 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
