Is there a reset sequence I can use to get this going again? Model # mvwc300xw0 Sn c12221142
Start button does not activate washer. I have washed 3 other loads this morning with no issues.
  • Whirlpool
    Whirlpool Jun 16, 2017
    Hi Terry, we'd be happy to help you arrange service as we are not trained technicians and would be unable to instruct you on this. If you still need assistance, please provide your name, the name of the site you were contacted on (fixya.com), your user ID name (Terry Jensen), your phone number, your address, the full model and serial number, and email the requested information to Maytag_Digital@Maytag.com. We would be happy to review your concerns further.
    Master:
  • 238 Answers
Hello Terry!
The manual says:
To restart the washer, close the lid (if open) and pull out the Timer knob.
I add a link to a manual of a similar Maytag washing machine, hope it will help you.
NOTE In wash water temperatures colder than 60F 15 6C detergents do not...
Posted on May 18, 2017
Testimonial: "My timer knob only spins to select cycle. I attempted to pull out, but it just came off. This is a commercial centennial model"
My cabrio washing machine want start
start with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc. There is an error code chart in the image below.
If there are no error codes stored, I recommend that you start from the beginning (step 1 above) and then run the Automatic test mode. If this unit detects a problem, it will display the error at the end of this test.
Post the results back to me.
Nov 30, 2012 | Washing Machines
Washer will not start
I know how frustrating it can be when appliances do not function properly.
This particular washer has a test that we can run to see any errors. This can be confusing on this model.
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc...
If there are no error codes stored, you will need to replace the control board. Here is a link to the part.
Oct 17, 2012 | Whirlpool Washing Machines
Self cleaning button sequence want start
you need to see in the bottom of your washer or take the back panel and some of this washers have a reset button, try due that, make sure is unpluged while you due this, clean all the contacts inside and check all the wires make sure they okay
Oct 17, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
My hotpoint washer aq9l292i keeps spining
You might find a sequence online for resetting the machine.
This is a coded sequence of pressing buttons on front of machine.
I managed to get my sort of going again by using this method.
worth a try if your bored!
Jun 10, 2012 | Hotpoint Washing Machines
Dish washer the clean light stays on and the dish washer wont run
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Whirlpool Dishwashers
Washer will not start. "Clean"
Kevin
Jun 20, 2011 | Dishwashers
DISH WASHER NOT WORKING, ONLY CLEAN LED FLASHING
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Mar 15, 2011 | KitchenAid KUDE60FVSS 24 in Builtin...
I see that this issue has been posted a few times so here we go again, sorry! The clean light blinks but i am not able to clear and start a new cycle?
Kevin
Mar 07, 2011 | Kenmore 24 in. 16029 Built-in Dishwasher
Our Kenmore Elite Dishwasher has a blinking green light next to the clean cycle. It won't reset. We changed the motor and this has been going on ever since. Do you know what we need to do to fix it....
Hello
Blinking green light can be reset by following two buttons in sequence: press HIGH TEMP WASH-HEATED DRY buttons in sequence around 3-4 times so that the control reset itself. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Standard 58715182400 Blinking Light
Don't you hate it when you can find lots of people with the same problem, but no one with an answer?
Well I have the same problem. I cracked open the front and found the service manual. Not sure what it does, but holding in "Hi Temp" plus "Start/Cancel" for either 3 seconds or 0.5 seconds is supposed to do something. 3 seconds seemed to reset it, and now it's washing.
Good luck.
Feb 01, 2008 | Kenmore 43142 Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
