Question about The Office Equipment & Supplies
Why is the green light orange ?
The green light is orange instead of green can I still use my Jovia
2 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: my light under the power button continues to stay orange instead of green, what is causing this?
William,
Not my money, and not my decision, but would you be willing to spend around $30, and a little labor, to see if the Power Supply is the problem?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1389575&CatId=1078
You could also use the above as an example, and find your own. If you wish, copy and paste the webpage URL of the example in a Comment, and I'll check it out for you.
I would recommend buying an economical multimeter, ($8 to $12), and test the Power Supply, but the cost is almost half of what a new, reliable Power Supply would cost. Again, the choice is up to you. You buy a multimeter, I can guide you.
1) Computer on a table, computer unplugged from power, computer case open. FOLLOW Anti-Static Precautions;
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside your computer.
Relieve your body of Static Before reaching inside your computer.
Again, computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
That's it. Your computer is safe. Power unplugged, you are safe.
IF you leave your computer for in the middle of working on it, be SURE to Touch the metal frame again upon your return.
2) Remove all cables from the computer. If you are not SURE of where they go, now is an excellent time to make a few notes, before you remove them.
3) Open the computer case,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00583783&tmp_task=useCategory&cc=us&dlc=en&lc=en&product=3644705
View the video, and/or the first three steps.
4) Replacing the Power Supply,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01358091&tmp_task=useCategory&cc=us&dlc=en&lc=en&product=3644705
Looks a little complicated with all those wires, and a tight space, huh?
It isn't that bad.
You will just be removing the power wires from the Power Supply, to the motherboard, optical drive/s, (CD/DVD drive), and maybe computer case fans.
In order to do so you also need to remove the other Side Panel, and Front Panel. This is shown on the link above.
You have loosened the two thumb screws for the left Side Panel, and removed it. (As shown)
Now go to the other Side Panel. The one on the right. (Directions are from looking at the Front of the computer)
The left Side Panel just has two Thumb screws to loosen.
The right Side Panel has two Philips head screws to remove, at the back of the computer.
Once the screws are removed, slide the panel towards the back of the computer.
It will only slide back a little bit. It is because of the 6 interior tabs on the panel, that fit into slots in the metal framework of the computer case. They have a hooked end. Once slid back, it is lifted out.
The Front Panel (Front Cover) has 6 plastic tabs, formed out of it's plastic body.
These are more readily seen in Step 1, under the subheading
- Replacing the front cover,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00598081&lc=en&cc=us&dlc=en&product=3644705
Looking under the subheading - Removing the front cover, Step 2.
Here it shows 3 of these tabs for the Front Cover on the left side.
There are 3 matching tabs also on the right side.
As you can see in the video, the tabs are pressed to the OUTSIDE of the computer case. This brings a hooked edge on the tab, away from the slot edge in the metal framework.
Once the 3 tabs on the left side are depressed, one at a time, top to bottom, the front cover will swing away, and off. Do this gently, and slowly.
You are trying to ease the tabs, on the right side of the front cover, out of their respective slots also. Go too fast, or get rough, and you could break the tabs.
Hard part is over. If at any time you get frustrated, please stop for a moment.
With all three covers off, it is time to slide the optical drive/s out, one at a time. Suggest start with the top one, if there are two.
In Step 2 you see the green plastic locking mechanism, that holds the optical drive/s in place.
The plastic lock is only eased out so far. This lets a screw post on the optical drive slide by. The optical drive is slid forward a little.
This allows you easier access to the power cable, on the main optical drive. (If there are two)
According to the specifications of the computer, there is just one optical drive. A DVD burner drive, (DVD-R/W), and a SATA type unit.
Should be on top.
5) Removing the power cables from the Optical Drive and Harddrive:
This is what the power cable looks like,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
The other cable that looks similar to it is SATA data cable. It's connector is the shorter of the two. Do not remove it.
The TOP of the connector has a lock you press down on. A tab if you will.
Squeeze the tab lock down, use the connector when removing the power cable, not the wires.
(Yes, I know you are replacing the Power Supply anyway, but it is good practice to use just the connector, and not the wires when removing )
Now go below the optical drive, and remove the SATA power wire from the Harddrive. In the Playtool link above for the SATA power wire, it is shown plugged into a SATA harddrive.
Also look at the end of those SATA power cable connectors. Note the L-shaped slot. Use this for reference when reinstalling a SATA power cable. Has to line up with an L-shaped tab on the harddrive, or optical drive.
The next power cable to remove is the 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
[NOTE* Color of connectors does NOT matter ]
This is on the motherboard behind the metal framework, that holds the optical drives, and harddrive. (Optical drive bay, and harddrive bay)
This is where it plugs into the motherboard,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01357135&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3644705
Note the long blue, and black Ram Memory slots, with the white 'ear' locks.
To the right of them is a whitish connector, that has two rows of 12 socket holes. (Columns actually in this view)
This is where the 24-pin ATX main power cable plugs in.
Going back to the link above for this power cable, I would like you to look at the photo to the right, and middle photo.
Notice the Lock Tab on the side of the power cable connector.
It has a hooked end that goes over a tab on the motherboard connector.
The Lock Tab acts like a see-saw on a playground. The top is squeezed in, and this action brings the hooked end, away from the motherboard connector tab.
Squeeze it in, then gently rock the power cable connector a little bit, and pull up.
(WATCH the edges of the metal framework! Could be sharp! )
The next power cable to remove from the motherboard is this one,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
On your motherboard the square 4-socket hole connector, is to the immediate Left, of the bottom left corner of the Processor socket.
(In the motherboard photo the Processor socket, is the white rectangle at the top, with a bunch of socket holes in it. Has a black retaining ring going around it )
Note that this power cable connector also has a Lock Tab on the side.
Finally, look to see if there are any other power cables, coming from the Power Supply, that have to be disconnected.
There may be this power cable used, to connect a computer case fan to,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
The Processor fan, and computer case fans, should plug into the motherboard. Just wanted to post the above style of power cable, in case.
Now go to the back of the computer. There are 4 Philips head screws to remove shown, from the back of the Power Supply. This is seen in Step 5.
Once you go to remove the last screw, support the Power Supply from the inside. Once the screw is removed the Power Supply may try to fall forward inside the computer.
Slide the Power Supply a little towards the front of the computer case, tilt it down, and swing it out of the computer case.
Suggest use one hand to hold the power supply, while using the other hand to guide all the power cables you removed, out of the computer case.
Reversal of these steps to install the new one.
For any additional questions, and especially if you have a problem along the way, please post in a Comment.
Regards,
joecoolvette
Posted on Jul 28, 2012
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet 1300 Printer
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
Orange internet light on wireless router
first you need to configure your router with the help of your internet service provider then you need to save the setting and you need to reboot your router then check it
Jun 29, 2010 | Computers & Internet
Orange light is on instead of green in the freezer does this mean anything?
no. the orange light is the temperature light and the green light is the mains light.
Apr 06, 2010 | AEG 10.35 cu. ft. / 293 liter Upright...
When the computer is plugged in it doesnt work. The datech fan doesnt work. The front of the computer displays an orange light instead of green. If I replace the fan will this correct the problem
Replacing the fan as far as I know should not cause a light change but instead the computer would get hot shutdown every time he got too warm the orange light usually signifies a hardware problem. If you have opened your computer before you might have accidentally disconnected the hard drive or one of the cables from the motherboard. If the hard drive is disconnected that usually will get an orange light or if a ram chip is missing or not in all the way does a computer beep when you turn it on
Jul 27, 2009 | Dell Dimension 3000 PC Desktop
HP C4180 orange light
your cartage is now damage relapse it your problem will be solved
Dec 17, 2008 | HP Photosmart 4180 All-in-One Printer
32 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Gareth Cockram
Gareth Cockram
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
