Question about The Computers & Internet
We went outside so we could enjoy the sun. Phase or clause
What is a compound sentence?
Compound Sentence Examples - YourDictionary
  1. Cached
  2. Similar
Compound Sentence Examples. ... A compound sentence has at least two independent clauses that have related ideas. The independent clauses can be joined by a coordinating conjunction (there are seven-for, and, nor, but, or, yet, so) or a semicolon.Coordinating conjunction · ‎Independent clause · ‎Examples of Compounds
Examples of Compounds > Reference > Examples > Examples of Compounds
  1. Cached
  2. Similar
Compound sentences and compound words are an easy and fun way to add interest to a sentence. Reviewing examples of compounds helps illustrate ...
What Is a Compound Sentence? (grammar lesson) - Grammar Monster
  1. Cached
  2. Similar
It is worth being able to spot a compound sentence because you should use a comma before a conjunction that joins two independent clauses. For example:.Commas before conjunctions · ‎What Is a Complex Sentence?
Compound sentence ' Define Compound sentence at
  1. Cached
Compound sentence definition, a sentence containing two or more coordinate independent clauses, usually joined by one or more conjunctions, but no ...
What is a Compound Sentence? - Examples & Definition - Video ...
  1. Cached
  2. Similar
Aug 31, 2015 - A compound sentence is a sentence that has at least two independent clauses joined by a comma, semicolon or conjunction. An independent clause is a clause that has a subject and verb and forms a complete thought. An example of a compound sentence is, 'This house is too expensive, and that house is too small.'
what is compound sentence Google Search
Mar 17, 2017 | Computers & Internet
Examples of complex sentense
A complex sentence contains an independent clause and at least one dependent clause. An independent clause can stand alone as a sentence and makes a complete thought and a dependent clause can not stand alone, even though it has a subject and a verb.
Complex Sentence Examples - YourDictionary
Dec 06, 2016 | Office Equipment & Supplies
Why does my pt cruiser blow hot air when a/c or just turning on outside air?
It's probably that the air tubes lines are already hot due to the hot weather(car parked outside in the sun) and it takes 2-5 for the AC to be blowing air at the correct temperature.
Solution: Turn the AC on but reduce the fan speed to bare minimum for the at least 2 min. After that, crank it up and you should be able to enjoy the cool refreshing air.
May 23, 2014 | Chrysler PT Cruiser Cars & Trucks
Puma trailer, Why is Fridge not covered under warranty if only 2 yrs old?
Many times they have a clause built into the contract which the original purchaser signed and it only covers items for X number of years and only to the original purchaser. They know people trade out and upgrade RVs all the time. It is a poor way to do business in my opinion. The other option might be to find the serial number and contact the manufacturer of the fridge. Most give you a 3 year warranty on stuff like that.
Good luck.
May 06, 2014 | Palomino RVs
Does the dark moon rise on the south side of the bay
No, sorry. The mean inclination of the lunar orbit relative to the ecliptic plane is merely 5.145 degrees. Just like the sun it rises in general eastern direction and sets in western direction, it will not touch the horizon in the south or north of any location on earth.
This result is independent of the moon phase which is solely determined by sun, moon and earth's relative positioning. The dark (or new moon) is simply not illuminated by the sun on the section visible from earth but still rises in the east.
Feb 20, 2014 | Office Equipment & Supplies
Outside A/C unit not working
is this 3 phase? 3 phase is diffrent from single phase
Jun 18, 2013 | Goodman CLQ36AR49 Air Conditioner
Wire diagram to change a royal sun tan bed model # 46/6 vhr*turbo 1100 from 1 phase to 3 phase
send me your email address and I will give you what I have. We have a 2004 model 46/6 turbo. Wiring diagram is in the manual. I have this.
Jul 26, 2012 | Cars & Trucks
Activate your GPRS
Two ways to activate your GPRS:
1. Text ACTIVATE to 2300
2. Call 200 using your Sun phone or 395-8000 via landline, and a customer service representative
will assist you
Configure your Handset
Two ways to configure your phone:
1. Text SUN GPRS <handset model> to 1200.
2. Manually configure your handset : CLICK ME
Jun 09, 2011 | HTC Wildfire Cell Phone
Where can I buy rinnai dynamo 15dyn gas heater 3 metre hose in sydney.
You Cant.
clause from Nz/Oz gas code
Hose asemblies shall be:
(a) As short as practicable and not exceed 1.5m inside a building and 3m outside a building.
Jun 09, 2009 | Rinnai Vent Free Gas Heater/
Outside unit not registering temp and humidity to base unit
Uniden EWCI936
To get the outside temperature working again, open the outdoor sensor box carefully loosening the one screw with a screwdriver, insert 3 brand new AA batteries, check phone for outside temperature. If not showing on the phone display, try changing the 'channel' setting, just above the batteries. Be careful not to break the tiny switch. Gently use a smaller flathead screwdriver, if needed. There are 3 settings. Mine worked fine on the first setting. If it is showing on the phone set screens, then, carefully screw the lid back on to the sensor box, and re-insert into the sensor wall holder. I keep mine in a plastic bag on a shelf outside, away from sun, so I can get a true reading day or night. It is always a bit warmer in the sunlight than the true outdoor air temperature. Enjoy
Apr 24, 2009 | Lands Phones
Computers & Internet Logo
29 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
