Left earbud will not charge. I have tried everything even made sure no plastic was interfering.
2 Suggested Answers
Agent Aaron
  • 265 Answers
SOURCE: sound only on left side. tried earbuds and head phones
Hey markallen407,
If you've tried several different pairs of headphones and have encountered the same problem with every pair, you could possibly be looking at a defective headphone jack. In some cases when headphones are unable to make a secure connection within the jack, they may only receive an audio signal through one of the two speakers.
Unfortunately, this means that you may want to seek repairs on your iPod at this time. If you are still covered under the manufacturer's warranty, I would strongly suggest contacting Apple first for more information or further assistance. Many manufacturers may be able to provide faster solutions than third-party service facilities for problems with their products, but remember that it may be necessary to ship your iPod out for repairs.
Additionally, please keep in mind that you may always bring your iPod to your local Best Buy™ store for service. Geek Squad® agents are able to provide support for most products we sell, and can even honor existing factory warranties for products that were purchased through other retailers.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 16, 2008
Left earbud has no sound
I had this problem with 2 of my HBS 700s. The speaker in the earbud goes bad and needs to be replaced. If it is still under waranty you can send it in to be replaced (trying a home repair will probably void your waranty so try this at your own risk). If it is out of waranty and you have experience with a soldering iron, the earbuds can be replaced with a plain set that look similar to the originals from your local store (Wallgreens has a good selection for like $10). I am a novice at these things but the solution was pretty easy and has worked for both of my earbuds. I actually improved the quality of sound by installing better earbuds.
3d9a9467-2679-44c4-ba93-679ba93f6b9d.jpgYou will need:
- 1 small soldering iron
- one set of new wired earbuds (no volume control or mic... just plain earbuds)
- jewlers phillips head screwdriver
- one small flat screwdriver or thin flat edge to pry the cover off.
- one needle or thumbtack
Directions are the same for both sides. I suggest doing one side at a time and repeating the steps for the other side.
Directions:
- TURN OFF HBS 700
- locate the rubber plug on the bottom of the case (one on each side above the L and R symbols) and remove the plug with a needle.
- remove the screw located under the plug
- use a jewelers flathead screwdriver or thin flat edge to pry the case appart. The best method is to gently pry the bottom of the case outward then push in and up on the top part of the case starting at the back of the plastic case (where the earbud wire comes out) and working your way forward.
- remove the earbud cup and set aside. (if working on left side, also remove the charger door.)
- the circut board is held in place by plastic arms on the sides. Gently pry the circut board away from the case and lift up where the arms are holding it in place.
- once case is removed from circut board, you will see where the earbud soldered to the board.
NOW FOR THE FUN STUFF...
-cut your replacement earbuds to length and expose about 1/4" of the two wires inside (usually one gold and one colored or one solid color and one multi colored).
-The two wires are coated to prevent them from shorting out while touching. Add solder to your soldering iron so there is a good drop hanging from the tip. Insert one wire at a time into the drop of solder (about 1/32" will do) and hold it there for a few seconds. This will melt the coating and allow the solder to stick to the wire.
BE CAREFUL NOT TO SOLDER TOO MUCH OF THE WIRE OR IT WILL TOUCH THE OTHER AND SHORT OUT! ONLY A LITTLE ON THE TIP OF THE WIRE WILL DO.
-carefully use the soldering iron to remove the old earbuds from the circut board. A small soldering iron with a sharp tip works much better than the standard size at this. The soldering points for +/- are VERY close together so becareful not to melt them together.
-solder the new earbuds in place of the old ones. + to + and - to -.
-tie a knot in the earbud wire close to the circut board so it does not pull free from the case when closed.
-at this point in my repair, I turned the HBS 700 on to listen for the startup tone to make sure the earbud was connected properly. I DO NOT RECOMMEND TURNING IT ON OR TOUCHING COMPONENTS WHILE IT IS ON. IF YOU WISH TO CHECK IT AT THIS POINT LIKE I DID, DO SO AT YOUR OWN RISK. ALSO, MAKE SURE NOT TO HOLD THE CIRCUT BOARD OR TOUCH IT WHILE IT IS ON AND TURN IT OFF BEFORE CONTINUING.
NOW IT'S TIME TO PUT IT ALL BACK TOGETHER.
-reinsert the circut board to the top cover in reverse of how you took it out. Do not force it and make sure all the plastic arms clip over the circut board securely. Make sure to press the buttons to see if the are seated right.
-replace the earbud cup, battery door and power switch if it fell off.
-attach the bottom cover making sure to leave the knot on the inside of the cover. The cover should snap on easily.
-Re-insert the screw and plug.
DONE!
If you wish your new earbuds to attach magnettically to the cup, you will need to break open the old earbuds and remove the magnets from inside. Then glue them to the outside of the new earbuds or drill a hole for them to sit in and glue them in. Be careful tho because drilling holes too deep in the new earbuds could damage the wires inside (I found that out the hard way)
I hope this solution was helpful
Oct 17, 2013 | LG HBS-700 Bluetooth Headset
I can not hear anything out of my right ear bud
Hi there thobe47!
Please test the pair with a different audio device and see if the problem goes away first!
Firstly, make sure you are pressing the plug all the way into your audio device jack. Most are designed with two tiers, so only one ear will sound if only one tier of the electrical connection is fully established. Once you've tried that, continue!
Most earbuds are created with very small working parts with equally small electrical connections. If you have lost sound in one side, the most likely cause is a loose connection somewhere.
If it still doesn't work, your options are sort of limited. I would recommend first gently "jimmying" the wire leading to the bad earbud around while it is in your ear and music is playing. If you manage to get the sound to be restored, wrap sticky tape tightly around the wire and the tapered part of the bottom of the earbud in an attempt to maintain the new connection. It is not a permanent fix but might buy you a bit of time with the pair.
If you can't get it to work in that way, your remaining options are pretty much to either open the earbud and attempt to reestablish the connection (difficult, small parts, and could damage the earbuds if you don't know what you are doing), or to buy a new pair. You can get some pretty nice earbuds for under $5 at most megastores, and anybody who could fix them and would charge you will charge you much more.
If you must try to open the earbud (I don't recommend it!), I have a generic set of steps here. I take no responsibility for damage of your earbuds or devices that may follow!
Gently peel back the gelly cover of the earbud, starting under the top seam and pulling it off.
Unscrew or "pop off" the portion of the earbud that has the small grating. There may be an inner retaining system involving more plastic rings. Just keep these safe and remember the order in which you took them apart.
You will now probably be seeing the speaker of the earbud, looking like what you might see on an uncovered subwoofer speaker (just much smaller!)
Being careful to not touch the flat portion of this disk and avoiding anything magnetic (including your laptop / desktop), see if you can pinch it by the sides and gently pull it out of the casing -- probably less than a quarter centimeter. If you can, look for any severed connections between the solder points on the bottom of the speaker and the wires coming from the bottom of the bud. Soldering these would be extremely difficult, but you can attempt to fix them with small pieces of tape.
Nestle the speaker back into the housing, replace any retaining disks in the correct order, screw/pop the outer clip back on, and slide the gelly back into place.
Hope this helps!
Mar 24, 2011 | JVC Gumy Ear Bud Headphone - Peppermint...
Audio is not coming out of the right earbud
Try this set on another player to be sure, but if this is the symptom you have a blown speaker or a broken wire in the cord somewhere. Replace as necessary
Feb 11, 2010 | Shure SE310 Headphones
I have the same problem...
there may some problem in the board. its better to take your mobile to the service station and check else all the component may go bad. charging of mobile is good sign. dont try any thing it may short circuit.
Aug 21, 2009 | LG Vu CU920 Cellular Phone
Left earbud problems
Well, I had the same problem with the right earbud. Luckily I was under warranty with Target, so they told me to contact Bose. I did and they had me send in the headphones (to make sure I waas telling the truth) and about 2 weeks later I got my earbuds back. Their customer service is excellent, so that's what I would reccomend
Aug 09, 2009 | Bose in-ear headphones - Black with...
Same issue - right earbud volume lower than the left
yh im having the same problem good to know its not just me
Jul 08, 2009 | Sennheiser CX 300 Consumer Headphones
Sony MDR-NC11 Left Earbud has no sound
They should come apart right where the metal meets the plastic, just below the buds themselves - be careful, one set like that I took apart were actually surface-mounted to the housing, there weren't any leads to repair...
May 27, 2009 | Sony MDR-NC11 Consumer Headphones
My left earbud no longer produces sound! I was jogging with the earbuds and it started getting static and cutting out. I took them out thinking maybe some sweat got in them or something. I let them sit...
whatever the problem is give a call to Bose customer support(800-999-2673) and u can talk with them to get a replacement. If u r in one year warranty they will replace it(even if havnt bought it at bose store)...otherwise they will charge $50 i believe
Apr 19, 2009 | Bose in-ear headphones - Black with...
My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
Nov 16, 2008 | JVC Gumy Ear Bud Headphone - Peppermint...
Sansa clip 2 gb
Lets rule out hardware
  • Make sure the player is fully charged.
  • Make sure the earbuds are FULLY plugged in. This is easy to miss on a new player.
  • See if the problem depends on the volume setting on the player.
  • Change the earbuds from the originals and see if the problem continues.
  • You may have a bad player, try another.
If it is software, you will have to answer the first question.
Oct 09, 2008 | SanDisk Sansa Clip MP3 Player
14 people viewed this question
 Grubhead
Grubhead
