Question about Samsung Televison & Video
How do I get my Samsung device to stay open longer ?
My 55 inch 3D Samsung smart tv won't stay on for any longer then a minute any suggestions on how to fix it there are no timers set on my tv. I think it's a compaseter problem
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name and type (TV, VCR, DVD player etc:) of your device, in the search box [at the top right] of the home page. It will make surf easy.
Jun 13, 2015 | Samsung Televison & Video
How to delete network on tab4
To delete a wifi network from an Android device first open wifi settings and the list of networks.
Touch and hold the network you wish to remove.
An option will pop up to "forget network" this will delete it from memory and it will no longer connect to this network.
Feb 04, 2015 | Samsung Tablets & eReaders
Why will my rts he 10 not stay on no longer than a couple of seconds
Have you been playing the unit really loud or have you connected more speakers to the device, than originally came with the unit? I had a Yamaha unit and connected 4 extra speakers to the unit, which eventually overheated the device and the device would simply shut off, until it cooled down, however; the unit finally failed and burned up. I used a fan to keep the unit cool, until it finally failed, though......
KR
May 26, 2014 | Samsung Audio Players & Recorders
Blocked contacts
I would assume you are using an android samsung device.
Depending on device steps may differ.
Open Contacts, find the contact you blocked and touch it to select it, then press Menu and More, then tap Remove from Reject List
Then...
Press Home button, open Applications, go to Settings, then Call, then Call Rejection, open Auto Rejection List, find number blocked and touch it and hold until menu pops up, touch Delete then OK. Press Home button.
Number is no longer blocked
Dec 15, 2013 | Samsung Cell Phones
2004 kia sorento radio will no longer stay on when the key is turned off
its a electronic device and will cost more to replace than the fault is worth
Dec 21, 2012 | 2004 Kia Sorento EX
Cannot get my motorola H710 to enter pairing mode to conect to my new samsung highlights.
If you've already tried to reset it- by pressing all buttons (center and the two volume buttons for longer than 10 seconds until the light turns steady blue, which is recommended in the manual), then try this: (I had the same problem, but got mine to work). On headset, close boom, hold center button (and it turns pink). then, while keeping center button depressed, open boom- light remains pink. Then look on phone, and hit Add new device-- and bingo, it should be recognized now!! You'll be asked if u want to pair w/ Motorola-- and led through the process--follow those steps.
I had tried similar earlier, but the trick was to keep the button depressed, and then open the boom. I can't quite remember if I kept button depresed until I also pressed Add new device on phone or just until after opening the boom and the light stayed on ... Sorry I can't be exact; I was too excited. Hope this helps you get yours working!
Dec 29, 2009 | Jabra BT8010 Wireless Headset
Samsung YP-P2JAR. My Comp doesnt recogize it.
You need SamsungMediaStudio or something (the program which came with your P2). Open the program, and your P2 will appear. Good luck.
Sep 30, 2008 | Samsung Yepp YP-P2 Digital Media Player
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
