Question about Fast Garden
I have rtzs 42 wheNi step oN the gas it will ruN But makes what seem like a ruBBiNg Noise aNd mower will move But woN't go fast it feels like the Brake is holdiNg it Back
  • 3,168 Answers
Dear Charles,
You have well described exactly what is happening.
You have a part of your machine that is binding or sticking and must be dis-assembled and cleaned and lubricated, or at worst, replaced. The bad thing about lawn and garden equipment is they still need regular maintenance, unlike cars..
When you take your machine apart, you should find the offending part readily enough, it will not turn freely.
God bless your efforts.
Posted on May 01, 2018
  • 71 Answers
SOURCE: engine code p0420
The P0420 code is set when the oxygen sensor after the catalytic converter gives a reading the same or very close to the reading of the oxygen sensor(s) before the catalytic converter.
There are usually three possible causes...
The front oxygen sensor (before the cat) is giving an incorrect reading.
The rear oxygen sensor (after the cat) is giving an incorrect reading.
The catalytic converter is not working properly.
Since you recently replaced the cat, the logic points to the sensors, but it could be the cat again. Aftermarket converters are usually smaller than OEM and don't last as long.
For a more thorough description of the code and troubleshooting visit
http://www.obd-codes.com/p0420
Our Subaru encountered this issue several years ago under warranty. The first time the dealer replaced the front oxygen sensor. This was the cheapest repair and since it was an intermittent problem I am sure they hoped to delay the issue until the warranty was up. The second time they replaced the catalytic converter and we haven't had any more issues.
Posted on Jan 08, 2010
ftw1952
  • 10319 Answers
SOURCE: 2004 Hyundai Santa Fe? squeaky noise frnt driver side wheel
I do think the same way. If the pads look flat and not so worn have the rotor turned to eliminate the squeaksyou are encountering
Posted on May 31, 2010
  • 146 Answers
SOURCE: MTD 42" CUT MOWER MODEL 42A707 TYPE 1238 01
I think either the bolt holding the left blade onto the spindle is loose, or the cup washers under that bolt are flattened or missing. As a result, the blade is slipping on the shaft and probably making a squeal or squawk. Take off the deck, flip it over, and remove the blades. Note if the bolts seem tight. And look at the washers stacked under the bolts. Replace any missing washers, or flattened cup washer. Make sure the cup washer faces the right way (hollow side toward the blade). Tighten things back up securely - it takes a hefty pull on the end of a 2 foot long wrench to get enough torque.
Posted on Jun 18, 2010
juliefarley
  • 17 Answers
SOURCE: 24 hp LA165 mower. While mowing
check the connecting rod to the tranny. follow the gear handle and you should find a rod connecting the handle to the axle make sure you're in neutral and adjust the rod until the handle starts to move
Posted on Jul 18, 2011
  • 6468 Answers
SOURCE: lawn mower belt is rubbing on something. its a craftsman 42
check the idler pulley
Posted on Mar 30, 2012
I have a toro z master 42" cut 17 HP Kawasaki zero
Could be a bad bearing or could be something rubbing against something. Are the blades sprung so they are touching part of the body or something they shouldn't Just ideas to check out.
Sep 19, 2014 | Garden
Mower cranks with throttle in choke. after cranked and throttle moved to fast or any other position. The mower dies as if someone turns it off??
Ok I assume what you are trying to say is that once it starts with the choke on and you turn the choke off it dies.
This behavior usually means that the engine is leaning out. This means that it is not getting enough gas. Often if you put it back to choke fast enough it will keep running though very roughly.
The problem is the main metering jets are plugged or there is some kind of obstruction in the carburetor. This is assuming of course that the tank is full of gas and the fuel filter is clean.
Aug 17, 2013 | Craftsman 20 hp 42 in. Deck Yard Tractor
917272681 won't move forward
Um, have you checked the engine? Gas? Oil? I know. Dumb questions. But some peeps check everything before they check the gas and the oil.
Jun 15, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have a 42 inch cub cadet z force mower runs blades will not engage makes small noise by pto knob below it
i have found that the wires going to the clutch rub on the frame and break the wire check for power and ground at the clutch under the mower
May 09, 2012 | Garden
I have a troybuilt bronco 42" ride on mower and when i put it in foward or reverse and step on gas peddle the peddle bucks while moving. motor idle fine and cuts just fine, almost feels feels like its...
Yes, especially if there are chunks missing from it on the inside. Also be sure to check the idler pulley, make sure there is no wobble and that it spins freely with no grinding sound.
Sep 04, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
I have a craftsman riding mower that's 2 years old and it won't go into gear it's a 6 speed won't go in reverse either
Hi, did this happen when you went to use it or while mowing? Also will the lever go in but the mower won't move or won't the lever go in either gear at all? Regards Phil.
Aug 17, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
Clicking noise
removed engine cover - found starter was hung up, this seems to have fixed the problem it starts and runs fine now.
Jun 01, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tractor starts fine but wheni take my footh off the clutch the tractor dies
Most of the time its the seat safety switch .
Alway engage and disengage mower deck too as there is a safety switch there too, some times its just needs moved some, its not the clutch pedal safety switch.
Feb 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
20 people viewed this question
Top Fast Garden Experts
roeb
john h
Are you a Fast Garden Expert? Answer questions, earn points and help others
