Question about Hardware & Accessories
THE CLOCK ON MY TIMER IS UPSIDE DOWN. 12 IS AT THE BOTTOM; HOW DO I RIGHT THIS?
  • 1,830 Answers
Try to turn is right side up.
Posted on May 18, 2017
I have a 7-day timer model em0101 and can't set it
That timer is not identified:
Copy following link to see variety of timers that might match your timer, and then download same-similar manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Jun 15, 2012 | Timex Hardware & Accessories
Setting clock
Hello
To set clock:
1. Press "Timer/clock button". The hour digit begins to flash.
2. Press (<< P.DOWN or >> P.UP) on the multicontrol to set Hours.
3. Press SET button. The minute digits begins to flash.
4. Press (<, P.DOWN or >> P.UP) on the multicontrol to set Minutes.
5. Press "Set" button."CLOCK OK" appears on the display. The clock stops flashing, and the clock timer starts from "0" seconds. If the clock is not set "AM 12:00" will flash instead of the clock indication. When the time has been set, TIMER/CLOCK can be used to operate the daily timer recording timer.
If you haven't the user manaul to your set with you now, send your email address to me by Fixya comment bos. I've the downloaded user manual to your set, and I'll send a copy of it to you by return mail. OK.
Jan 21, 2012 | JVC MX-D402T Shelf System
I have a used JVC FS-B70 with no remote. How do I set the time on the clock?
To set the clock go to the link below page 9 will tell you how to set clock.
http://resources.jvc.com/Resources/00/00/97/MB002ien.pdf
On the remote control ONLY:
1 Press CLOCK/TIMER.
The hour digits start flashing on the display.
2 Press UP or DOWN to adjust
the hour, then press CLOCK/
TIMER.
The minute digits start flashing.
• When you press and hold UP or
DOWN, the hour digit changes
continuously.
3 Press UP or DOWN to adjust the
minute, then press CLOCK/TIMER.
The built-in clock starts.
• When you unplug the power cord or if a power failure occurs
The clock is reset to "AM 12:00" right away. If this happens, set
the clock again.
• The clock may gain or lose 1 to 2 minutes per month
If this happens, reset the clock.
Mar 02, 2011 | JVC Audio Players & Recorders
The manual switch works but the timer does not rotate. The timer knob is properly placeed into the geared drive but the timer motor does not seem to be operating.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/e1010%20-%20english.ashx
Half of the online manual is upside down.
According to the manual, the clock motor that operates the timer requires a separate Neutral wire.
The clock motor is a separate circuit, just like your alarm clock.
The wiring is:
Black-hot-from-breaker connects to timer-black wire
Wire-to-Load connects to timer-red wire
Timer-white wire connects to Neutral.
The Neutrals are white wires twisted together and covered with a wire nut.
Not every box has Neutrals ... in that case, connect timer-white wire to bare copper wire.
Bare copper wires connect back to the Neutral busbar in breaker box.
Attaching your white wire to ground is not code, but it will work.
How to test your wires:
Separate wires
Turn on power
Test each wire to bare ground
Tester lights up on Hot wire from breaker
Now test Hot from breaker to each of the other wires, except ground.
Tester lights up on Neutral
Nov 09, 2010 | Intermatic Timer E1020, Single pole/single...
For some reason my cooker keeps switching itself off, unless the timer is set to 12:01 it does this. It used to go off when the timer counted down to 8 mins, but this varies, and now it has a mind of its...
It sounds like you are setting a cooking time instead of setting the time of day. The oven wont work until a time of day is set. press the centre button (4x)until a red light flashes in the bottom right corner of the clock if you miss it keep pressing until you cycle through to the rh corner(note clock symbal) press + or - until you get to the right time leave for 12 secs then time locks in and your oven will work. the other flashing lites top left= cooking time bottom left =end time top right =timer function with no oven control. If this does not solve it the timer is faulty and requires replacing. good luck.
Oct 31, 2010 | Electrolux Insight EKC6049X Stainless...
AEG single oven - clock runs for 12 hrs , buzzes and goes back to 12 o'clock - if set timer and check time remaining, it buzzes and jumps to clock setting loosing time remaining. Buzzer sounds ''hoarse''.
you must setting the count down timer instead of time of day. to set time of day. press centre button 4 times lamp flashes in bottom righthand of display. use + and - to get correct time after 10 secs time will lock in. to check you have not set count down press centre button 3 times lamp flashes top right corner of display if not at 0000 use - button to get to 0000 leave 10 secs then should revert to time of day. also check you have not entered cooking time. press centre 1x this also should read 0000. hope this helps
Jul 17, 2010 | AEG B2100-4 Electric Single Oven
Upside down screen on monitor
hi,
turn your monitor upside down on your desk and look near the clock at the bottom in the system tray. you may have a shortcut there to that video setting, hover above the icons next to your clock, hopefully one of them is your video settings and study in there to change the setting back to the way it was. if not then right click the destop, go to properties, then go to settings in your display properties, then click advanced, and right in there should be a setting to flip the screen 180 degrees back to the way it was..
jm
Dec 15, 2009 | ViewSonic VX2235WM Monitor
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Oct 10, 2009 | Bulova Watch
Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
Jun 13, 2009 | Black & Decker CTO650 1500 Watts Toaster...
Using automatic timer to take group photo
Press the bottom part of the square with the "OK" button in the middle. It has a picture of a clock. "Off" will be highlighted, so scroll down to the picture of the clock, and it will show the message "Selftimer On: A photo is taken automatically 12 sec. after shutter button is pressed." Press the OK button to activate this mode. Now it's just like taking a regular picture, just press the button and run over to the group and in 12 seconds it will take the picture.
Jul 07, 2008 | Olympus FE-210 Digital Camera
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
