Question about Ricoh Office Equipment & Supplies
My Ricoh Aficio 2020 is showing error occurred sc 901. what solution should i apply
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
  • 2794 Answers
SOURCE: ricoh aficio 1035 sc code sc 329 troubleshooting
Laser diode beam not positioned correctly. Turn the machine off and back on and see if it goes away. You can run sp 2109-3 or 2109-4 in the service mode to adjust the beam in service mode by pressing on the yellow button. pressing the 107 keys and holding down on the clear button.
If this doesn't resolve the issue, you probably need a laser which we have one for sale here.
Posted on Dec 17, 2008
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
  • 4 Answers
SOURCE: error code sc 386 on
The black developer is out of range. Either you need to add toner, if it is empty, or the black developer housing needs to be replaced. There is an off chance the high voltage power supply is bad.
Posted on Feb 13, 2009
  • 313 Answers
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Posted on Jun 26, 2009
My machine ricoh 2035 sc code 901 how to remove
my dear total counter error you chek total counter meter
Aug 04, 2015 | Ricoh Aficio 2045e 2035e Copier...
What is SC500 error on Ricoh Aficio 2020D?
gear assy not turning can be many things. Main motor/devlp unit /fuser/ transfer roller
Aug 14, 2014 | Ricoh Aficio 2020 All-In-One Laser Printer
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Sc 901 ricoh 2018d
901 B Mechanical total counter
The mechanical total counter does not
work properly.
• Mechanical total counter defective
• BICU defective
• Disconnected mechanical total counter
Apr 07, 2014 | Ricoh Aficio 2018D All-In-One Laser...
RICOH Error Code List SC-901 Mechanical counter or fuse FU4 locket
I have a problem is that the SC901
We changed, but the problem is still so far
Jul 26, 2012 | Ricoh B/w Mfp Copier Aficio Mp 2510 W/...
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Error message sc 172 on ricoh aficio color 2103
You'll need a tech on site for this one, but it may be difficult to source parts if required for this old box. One of the following situations has occured:
• Poor connection of CCD
• Dirty optics
• Defective lamp regulator
• Defective main scanner IPU board
• Defective CCD
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Jul 12, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
