Question about Moen Plumbing
My Moen fawcet leaks.. I didn't keep receipt just sticker with model #84503 can I get replacement? June
  • 1,830 Answers
You can always by a new one. I suggest a different brand.
I use Price Pfister.
Posted on May 18, 2017
My Moen Chateau (older style) kitchen faucet is leaking under the cap that covers a black plastic part where the on/off lever attaches. I purchased and installed a new cartridge, but that didn't
Did you know Moen faucets are warranted for life? You should go to Moen's website to identify the faucet you have and then contact them directly. They will ask you when you purchased and / installed the faucet but will not ask for a receipt or other proof of purchase. If the faucet was installed by a previous owner and registered by them - that warranty will be void unless you installed the same faucet after you bought the home (renovation, etc.).
All parts and tech support are FREE from Moen and if your faucet is being phased out, they will offer you a choice of faucets from their current line up (similar to the one you have) for very short money (I paid less than $50 for mine).
Feb 26, 2013 | Moen Plumbing
Replace o rings on a moen adeline model 87787SL KITCHEN FAUCET
How do I remove the faucet Moen model 87787 to place O-rings?
Jan 30, 2013 | Moen Plumbing
How do you replace handle adpater for moen 8400 monticello faucet
The handle adapters that Moen makes are right and left. Because you bought a universal one, it works on both the right and left, but only turns one way. If you but an original Moen part, you won't have this problem.
Sep 15, 2017 | Moen Bathroom Sink Faucet - 4-inch...
New Danze D308340 faucet leaking under handle. Can't remove the capto get to retainer screw, which needs tightening.
is the capp colored red/blue? if yes, take a picky pointy knife (lmao) and peel it off,pick it off,The leak is probable just the adjustment under the handle, the fawcet originaly came with a tiny spud wrench (made like a 2 pick pitch fork, if you cant find one, i use a pair of channel locks pliers, but first wrap rubber glove or cloth around the top of fawcet so you dont scratch it.How old is this fawcet?
Nov 12, 2011 | Plumbing
I cant get the old cartridge out to replace ive tried every idea i can think of, help
You didn't include the model of faucet assembly but on those with which I am familiar, there is an inside snap ring lodged in a groove that keeps the cylinder in place. Without having this out of the way, the cylinder (thankfully) will not come out.
May 16, 2011 | Moen & Replacement Cartridge
Single handle Spray faucet leaks at it's base, leaking under the kitchen sink
If you still have the receipts from the purchase call Moen directly as they warranty their faucets for life and will send you the replacement parts you need. If you need to purchase replacement parts then you can purchase a Moen single lever repair kit from your local hardware store which should run you around $10. Go the the Moen website and look for your model. They generally have an exploded view of every one of their models that will assist you in dissassembling the tap without any surprises. Reassemble the tap with the new o-rings etc installed and test.
Aug 10, 2010 | Moen 7437 Chateau Single Hole Kitchen...
How do I remove the plastic cartrige from a double handle moen bathroom sink fawcet
Pop the plastic caps of the top if they are this stile but if not their is a set screw behind the blue and red plugs for hot and cold thev will pop out as well.Hope this helps.
Aug 10, 2010 | Moen Home
Have a Moen single lever kitchen fawcet with seperate sprayer and it drips. I poped off the center cap on top of the fawcet and can see a cartridge but don't know how to remove it. It's brushed chrome.
Most MOEN single handle faucets use the same cartridge, the 1200 or 1225. If you have it apart enough to see the top there should only be a few more parts to remove to get at the stem ie the handle and cap. Once there you should see the horse shoe clip that holds the stem in. Once you slide the horse shoe clip off, the stem should be ready to go. Now sometimes these will come out easily, but most of the time they are a little tough. You can use a crescent wrench and gently turn the cartridge at the ears where the horse shoe clip was removed and this will loosen the cartridge, then you can use the handle or what ever you can grab the stem with to pull it out. FYI a lot of the home improvement stores carry a MOEN cartridge puller and they make it a lot easier. After cartridge is removed install new one and your done. DONT forget to turn off water before you begin. Hope this helps.
May 13, 2010 | Plumbing
Dripping continuosly. Model L82691 SHOWER fAUCET
Moen provides a lifetime warranty and doesn't require a receipt. Just call them and explain the problem and they'll send a replacement cartridge which should solve your problem. Cartridge replacement is pretty straightforward so it should be no problem to do it yourself. The one you have probably has a bad washer.
Apr 19, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Cold water flow is slow and handle is starting to get a little stiff to raise and lower - what is wrong and how can it be fixed? Moen M7800 Kitchen faucet
Not sure whether you are aware or not but most times, if you call moen with your model number and explain the problem your having, they will usually send you (free of charge-lifetime warranty) the part with instructions on repairing it along with it. You may have the 7800 series, but there are 3 or 4 different models if you check their site, and can identify the actual model, they will send you repair parts. Tell them you bought it ? years ago, and don't have the receipt, if they even ask.
try this link, if no luck, get back to me.
http://www.moen.com/replacement-parts
Apr 16, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
Plumbing Logo
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
