500X500X50mm panel is equal to how many inches?
How much area will be covered with 36.78 cubic feet of mulch please answer in feet and inches
How it Works
Stone and Mulch Calculators
As an example, let's use 500 square feet to be mulched at a
3" depth.
  1. First, the depth must be converted to feet. To convert inches to feet, simply divide inches by 12, the number of inches in a foot.
    So for our example: 3 inches divided by 12 equals a 0.25 foot depth.
  2. Now that we have the depth in feet, we can multiply the depth by the area.
    So for our example: 0.25 foot depth times 500 square feet equals 125 cubic feet.
  3. If you are calculating 0.5, 2, or 3, cubic foot bags, simply divide 125 cubic feet by the size of the bag.
    So for our example: if we are using 2 cubic foot bags, we can divide 125 cubic feet by 2 which equals 62.5 bags.
  4. If you are calculating cubic yards, we need to convert 125 cubic feet to cubic yards by dividing by 27. One cubic yard is equal to 27 cubic feet, see the diagram below.
    So for our example: 125 cubic feet divided by 27 equals 4.63 cubic yards.
For Your Information
  • 1 inch equals 0.08333 feet
  • 1.5 inches equals 0.125 feet
  • 2 inc
Jun 29, 2016 | Office Equipment & Supplies
How many gallons in an 88" x 15" x 9" trough?
try this :
Instructions
  1. Measure the rectangle length, width and height. For example, 8 inches long, 6 inches wide, 10 inches high.
  2. Multiply the length by the height, then double the product. With this example, 8 inches multiplied by 10 inches results in 80 square inches, which multiplied by 2 equals 160 square inches.
  3. Multiply the width by the length, then double the product. With this example, 6 inches multiplied by 8 inches equals 48 square inches, which multiplied by 2 equals 96 square inches.
  4. Multiply the height by the width, then double the product. With this example, 10 inches multiplied by 6 inches results in 60 square inches, which multiplied by 2 equals 120 square inches.
  5. Sum the amounts from Steps 1 through 3 to find the rectangle surface area. So adding 160, 96 and 120 square inches results in 376 square inches.
1 Us gallon is 231 cubic inches
Sep 05, 2015 | Garden
How much volume in gallons does three quarter inch copper pipe if it is ten f9ot long.
Hi Wayne:
For my curious mind, what is the project that you need this for?
To solve the problem, the volume of the pipe is the cross sectional area times the length.
Area = pi r squared.
= 22/7 times .75 / 2 squared
= 3.1428571 times .375 times .375
= o.4419642 square inches
The pipe is 10 feet long, times 12 equals 120 inches long.
The pipe volume is 120 times 0.4419642 equals 53.035704 cubic inches.
The next part of the question is to convert cubic inches to gallons.
I use my Texas Instruments TI-1889
53.035704 to metric, in cubed to cm cubed = 869.09608
Divide by 1,000 equals .86909608 litres
From Metric, imp gal (I'm in Canada) to L = 0.1911781
Ta Da!
Cheerfuls
Jun 03, 2015 | Cars & Trucks
How many cu yards to cover 196 sq ft to a depth of 2 1/2"
Hi Bob:
1 cubic yard is 3ft by 3 ft by 3 ft.
3 times 3 times 3 equals 27, so
1 cubic yard equals 27 cubic feet.
2 1/2 inches divided by 12 inches equals .2083333 feet
196 square feet times .208333 feet equals 40.83333 cubic feet
40.83333 cubic ft divided by 27 cubic ft equals 1.5123456 cu yards.
Ta Da!!!!
May 01, 2015 | Refrigerators
100mm equal what in inches?
Hi Jehaad:
100 mm equals 10 cm
1cm equals 0.3937007 inches
10 cm equals 3.937007 inches
100 mm equals 3,937007 inches
Apr 03, 2015 | 2000 Ford Expedition Eddie Bauer
Convert millimeters to inches
-26mm Equal 1 1/64 Inch.
-Here some basic solution:
-mm divide by 25.4 equal inches.
-Inches multiply to 25.4 equal mm.
Good luck
Mai
Aug 26, 2014 | Measuring Tools & Sensors
64x58 inch how many metors
64 x 58 inches equals 3712 square inches.
1 square inches = 0.00064516 square meters.
3712 x 0.00064516 equals 2.39483392
Therefore 3712 square inches equals 2.39483392 square meters.
Here is a link to a quick online calculator for that conversion:
http://www.calculateme.com/Area/SquareInches/ToSquareMeters.htm
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Jun 01, 2011 | Office Equipment & Supplies
22 people viewed this question
k24674
