Question about Refrigerators
Hi I have a indersit fridge freezer and not sure what the knob should be at for it any Ideas please
4 Suggested Answers
  • 3 Answers
SOURCE: Freezer working, fridge isn't.
It is possible that your cooling unit is failing due to a blockage. The solution used to cool starts at the top of the fridge and works its way to the bottom. If there is a blockage in the cooling unit it could produce the symptom you have explained.
Posted on Jul 06, 2009
heatman101
  • 43501 Answers
SOURCE: Hi, Our RA21VASS fridge with
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Posted on Dec 16, 2010
  • 52130 Answers
SOURCE: Hoover contour upsidedown fridge/freezer.Freezer not freezing, fridge is OK just.Need some suggestions please.Jimmy
need recharged with freon. can only be done by certified person
Posted on Feb 09, 2015
Hi Iv got a Hotpoint fridge freezer iced diamond rfa52 it keeps switching on and off it seems when the fridge gets warm it turns back on my freezer is not defrosting but the fridge is then freezing again...
Okay, have you adjusted your cold temp knob inside the fridge part? There are two switches one in the freezer and one in the fridge you will need to watch it day by day until the optimum temp setting has been achieved same goes for the freezer if it defrosts that is the exact point where your freezer is at best! It takes patience so be patient and your problem will be solved! Good luck and thanks again for using fixya.com
Oct 09, 2014 | Hotpoint Refrigerators
My landlord just gave me this fridge and it appears that one thermostate controls freezer and fridge. I am not sure what temperature to set it at as the freezer is getting cold but the fridge is not real...
if this is a self defrosting ref. it should do it by itself. one knob on the right will make your ref cooler by making your freezer warmer..it controls a vent that lets cold air from your freezer. try that ok.
Feb 13, 2011 | Refrigerators
Hi, Our RA21VASS fridge with freezer box seems stuck on the coldest setting after defrosting. Everything in the fridge compartment is frozen and the temp knob appears not to work. Any ideas?
heatman101
Dec 15, 2010 | Samsung Refrigerators
Hotpoint fridge - temperature problem
Somewhere there's another knob that controls the position of a damper that balances cold between the freezer and the refrigerator. Despite where the knob is, the thermostat is probably controlling the freezer temp. The damper controls how much cold from the freezer gets to the refrigerator.
You need to adjust that knob to divert less cold air into the refrigerator section.
It's also possible the damper has gotten stuck and can't be moved, in which case you may need a repair tech.
Feb 25, 2018 | Refrigerators
Hotpoint RFA52 fridge freezer
if you cant hear the motor/compressor running when energised then its likely to be a thermostat fault... but on energising the system if you hear a buzz then a click then its more seriously the main motor... turn off at mains for 5 mins then turn on... this should tell you either way
Dec 22, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Frigidaire FRE196A
you know where you adjust the temperature of your fridge. its a knob with a line that increase in thickness. or it may have numbers written on it. before you replace it. try adjusting that knob to set it to a higher temp. please if your taking the covers off the replace thermostat,, please turn the power off first.
Nov 11, 2009 | Frigidaire Freezers
I am renting a house with a ge profile refrige model no PSS27SGPASS. My food keeps freezing in the refrige. I keep raising the temp but that does not help what can I do I do not have a manual is there a...
That model has a electric powered damper that opens or shuts to reduce or increase the flow of cold air from freezer. Sometimes they stick open and will not close. It's quite expensive to replace. And the temperature control board is also expensive. I believe it's time to talk to the Landlord and get them on the project. Thanks, Sea Breeze
Aug 19, 2009 | GE Refrigerators
Creda R335NW Fridge/Freezer. The fridge section is not cooling down anymore, The freezer is working ok. Any ideas please?
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 03, 2009 | Refrigerators
Fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Feb 17, 2009 | Maytag MZD2766GES Side by Side...
I have ? for model # ET1MHKXMQ00
Sounds like you need a new thermostat to me. They are kinda expensive, not too hard to replace though.
Jan 24, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
