Question about Dryers
Putting Weatherworks fan together after cleaning. Can align all pieces to tighten the bolts to hold covers together
SOURCE: I'm noticing oil dripping from
Had same problem and it turned out to be oil dripping all the way down from the valve cover and not the tranny. Check/tighten bolts around valve cover.
Posted on Aug 17, 2008
  • 7353 Answers
SOURCE: I am installing an Offenhouser intake manifold on a Ford inline-6
put the halves together leave bolts snug, then bolt it to the head, now go back and tighten the halves together,
Posted on Oct 07, 2009
Testimonial: "thanks for the prompt answer/help."
ZJLimited
  • 17970 Answers
SOURCE: Head tourqe specs for 403 olds and bolt tightening
Fig. : Cylinder head torque sequence, 260, 307, 350 403 Oldsmobile built engines
On the V8, tighten the bolts, in the sequence illustrated, to 100 ft. lbs. When all bolts have been tightened to this figure, begin the tightening sequence again, and torque all bolts to 130 ft. lbs.
On V6's, tighten all head bolts in sequence to the following torques:
* All except bolts 5, 6, 11, 12, 13 and 14 - 100 ft. lbs.(19-135.5 Nm)
* Bolts 5, 6, 11, 12, 13, and 14 - 41 ft. lbs. (19-55.5 Nm)
* All bolts except 5, 6, 11, 12, 13, and 14 - 142 ft. lbs. (19-192.5 Nm)
* Bolts 5, 6, 11, 12, 13, and 14 - 59 ft. lbs. (19-80 Nm)
Hope this help (remember comment and rated this).
Posted on Mar 29, 2010
Testimonial: "Every thing I was looking for Thanks a lot"
ilianj1
  • 67 Answers
SOURCE: can not figure out where the pieces go to hold fan
If what you are calling a center piece is the safety grill, it has clips around the edges to remove the screen for service or cleaning.
If the fan is wobbling, the nut in the center of the fan needs to be tightened.
Jim Hart
Posted on Jun 20, 2010
tbreeze47
  • 3083 Answers
SOURCE: I inherited a Solidex VT-85hq
It could be missing. Most photo repair shops are familiar with this tripod, and my advice would be to just run it by one and see if they can get you fixed up. That's the easiest way, without having to bring up myriads of photos on the net and try to peruse what's missing.
Good luck, and hope this helps you get it fixed.
Posted on Nov 10, 2010
How to set valve timing on the 1990 3.0 cressida
To install:
  1. Install the oil pump drive gear and tighten the 16 ft. lbs. (22 Nm).
  2. Using a suitable seal installer, install a new crankshaft timing gear seal. Install the gear.
  3. Temporarily install the idler pulley and tension spring.
  4. If using the old belt, check the rotation direction chalk mark placed on the timing belt during disassembly.
  5. Install the timing belt on the crankshaft pulley.
  6. Install the lower timing belt cover, air conditioning idler pulley bracket, compressor bracket and the lower timing belt cover retaining bolts and nuts. Install the pollution system air pipe assembly.
  7. Install the crankshaft pulley and pulley retaining bolt and torque to specification.
  8. Turn the crankshaft pulley and align its groove with the 0 mark on the lower timing belt cover.
  9. Install the camshaft timing pulleys and timing belt as follows:
    1. Turn the crankshaft pulley and align its groove with the 0 mark on the No. 1 timing belt cover. If the engine has not been disturbed, the engine should still be in this position.
    2. Align the alignment marks on the camshaft timing pulleys and the No. 2 timing belt cover. Install the timing pulley.
    3. Install the straight pin into the hole.
    4. When replacing the camshaft or the camshaft timing pulley. Always align the center holes of the camshaft and timing pulleys and insert the straight pin. When reusing the camshaft or camshaft timing pulleys, check that the straight pin hole position is in the same position it was at disassembly, insert the straight pin. Install the plate washer and pulley bolt.
    5. Using a suitable camshaft pulley holding tool, hold the pulley and tighten the pulley bolts to 36 ft. lbs. (49 Nm).
    6. Check that the matchmarks on the camshaft timing pulley are aligned with those on the No. 2 timing belt cover.
    7. Install the timing belt to the intake camshaft timing pulley, the exhaust camshaft timing pulley and the idler pulley.
    8. Loosen the idler pulley mount bolt until the pulley is moved slightly by the spring tension. Tighten the idler pulley mount bolt to 36 ft. lbs. (49 Nm).
    9. Check that the timing belt tension is equal all the way through. Turn the crankshaft pulley 2 revolutions clockwise from TDC to TDC.
    10. Check that the alignment marks on the camshaft timing pulleys are aligned with those on the No. 2 timing belt cover.
    11. If the marks do not align, remove the belt and install it again.
    12. Install the No. 3 timing cover gasket, cover and retaining bolts.
    13. Install the power steering pump belt.
    14. Install the four bolts, fan clutch, water pump pulley and fan shroud.
    15. Install the fan shroud mounting nuts.
    16. Tighten the fan belt adjusting bolt and nut of the power steering pump.
    17. Install the 4 bolts to the fluid coupling (fan clutch) flange.
  10. Install the air conditioning drive belt.
  11. Install the thermostat and water outlet along with it retaining bolts.
  12. Install the spark plugs and spark plug wires.
  13. Install the radiator assembly along with the radiator hoses.
  14. Install the drive belts and adjust as necessary.
  15. Install the air cleaner case assembly with the air intake connector.
  16. Refill the coolant system.
  17. Reconnect the negative battery cable. Connect a timing light and tachometer.
  18. Start the engine and set the ignition timing. Recheck the idle speed adjustment. Check for leaks and add coolant as necessary.
Aug 20, 2017 | Cars & Trucks
I need the timing marks for a Mazda 2.5 wl TDI motor as well as the technical specifications
TIMING BELT
Removal
Disconnect battery ground cable. Remove exhaust side spark plugs.
Remove fan shroud bolts and fan shroud, and position aside. Loosen, but do not remove, water pump pulley bolts. Remove accessory drive serpentine belt.
Remove fan and clutch assembly retaining screws. Remove fan and clutch assembly. Remove fan shroud. Remove water pump pulley.
On models with A/C, discharge A/C system using approved refrigerant recovery/recycling equipment. Remove A/C compressor from mounting bracket. Remove A/C compressor mounting bracket with power steering pump attached, and position aside.
Remove timing belt outer cover retaining bolt. Release 7 cover interlocking tabs. Remove timing belt cover.
Rotate crankshaft in normal direction of rotation so that No. 1 cylinder is at TDC of compression stroke. Align camshaft, crankshaft and oil pump timing marks. See Fig. 1 . Crankshaft keyway should be pointing straight up, and circle on crankshaft sprocket must align with notch in engine front cover.
Holding timing belt tensioner with Camshaft Belt Tension Adjuster (T74P-6254-A) or equivalent, loosen adjusting bolt and pivot bolt. Slowly release spring tension. Pry tensioner away from timing belt, and tighten bolt to hold tensioner in place. Remove timing belt.
Installation
Ensure crankshaft is set at TDC and camshaft sprocket timing mark and oil pump sprocket timing mark are aligned with inner cover timing marks.
Install timing belt on crankshaft sprocket, oil pump sprocket and then the camshaft sprocket. Loosen timing belt tensioner bolt.
Allow tensioner to adjust itself against timing belt. DO NOT tighten belt tensioner. Slowly rotate crankshaft clockwise 2 complete turns clockwise (as viewed from front of engine) so No. 1 cylinder is at TDC of compression stroke.
Recheck timing alignment marks. If timing marks are not aligned, reposition timing belt. Repeat timing belt tensioning procedure.
Tighten timing belt tensioner adjusting and pivot bolts to specification. See TORQUE SPECIFICATIONS . Install crankshaft pulley. Tighten center bolt to specification.
Install timing belt cover. Install exhaust side spark plugs. Install A/C compressor mounting bracket to engine. Install A/C compressor to mounting bracket. To complete installation, reverse removal procedure. Recharge A/C system, if necessary.
Oct 13, 2012 | Computers & Internet
Timming belt replacement video for kia rio 2004
  • Place the drain pan under the radiator drain plug, open the plug and allow it to drain. Close the plug. Loosen the four nuts on the water pump pulley but do not remove them yet. Loosen the adjusting bolts in the alternator and the power steering pump with a wrench, push them away from the belts and remove the belts.
  • 2Remove the bolts securing the fan shroud to the radiator support using a 10 mm socket. Remove the four nuts on the water pump pulley, then remove the fan and shroud as an assembly. Remove the bolts in the crankshaft pulley using a socket. Loosen and remove the crankshaft bolt using a socket.
    • 3
  • Remove the top radiator hose. Extract all the 10 mm bolts securing the top and bottom timing covers and remove the covers.
  • 4Install the crankshaft bolt temporarily. Use a socket on the bolt and turn the crankshaft clockwise until the mark on the crankshaft sprocket aligns with the timing mark on the block at the 12 o'clock position. Look at the camshaft sprockets and make sure the left sprocket has the "I" facing straight up and the right sprocket has the "E" facing up. At the same time, notice that there is a line on each sprocket adjacent to each mark--make sure they line up with the notch on the cylinder head at 12 o'clock. This allows for perfect alignment. If they do not come close to aligning, rotate the crankshaft one more time and they will align.
  • 5Loosen the tensioner bolt and push the tensioner away from the belt. Loosely tighten the bolt to maintain position. Remove the belt.
  • 6Install the new belt starting on the right side away from the tensioner. Keep all the tension on the right side. Loosen the tensioner bolt and allow it to apply tension on the belt. Do not tighten the bolt yet. Rotate the engine two turns clockwise and re-align the timing marks. Tighten the tensioner bolt to 35 foot-pounds.
  • 7Install the timing belt covers. Remove the crankshaft bolt and install the crankshaft pulley. Reinstall the bolt and tighten. Install the radiator shroud and fan as an assembly. Place the fan on the water pump pulley, install the four nuts loosely, install the bolts in the fan shroud and tighten.
  • 8Install the belts around the crank pulley, water pump pulley and alternator and pull the alternator up to tension the belt and tighten the bolts using a socket. Tighten the water pump pulley nuts using a wrench.
  • 9Install the belt on the power steering pump, pull the pump out to tension the belt and tighten the bolts. Install the upper radiator hose. Fill the radiator with antifreeze
  • Jul 27, 2012 | 2004 Kia Rio
    How do you time a 350 gmc motor
    4.8L, 5.3L and 6.0L Engines
      • Locate the camshaft sprocket alignment mark in the 6 o'clock position and install the camshaft sprocket and timing chain
      • Camshaft sprocket bolts and tighten the camshaft sprocket bolts;
        1. Torque to: 26 ft. lbs. (35 Nm)
      • Oil pump
      NOTE: Do not lubricate the oil seal sealing surface.
    1. Lubricate the outer edge of the oil seal with clean engine oil.
    2. Lubricate the front cover oil seal bore with clean engine oil.
    3. Install the crankshaft front oil seal with a suitable seal installer. NOTE: Do not apply any type sealant to the front cover gasket (unless specified). Special tools are used to properly align the engine front cover at the oil pan surface and to center the crankshaft front oil seal.
    4. Install the front cover gasket, cover, and bolts onto the engine.
    5. Install the front cover-to-oil pan bolts and do not overtighten.
    6. Tighten the cover bolts finger tight and do not overtighten. J41480 installation-4.8L, 5.3L & 6.0L 9308kg59.gif
    7. Start the J41480 or other suitable tool to front cover bolts but don’t tighten the bolts yet. NOTE: Align the tapered legs of the tool with the machined alignment surfaces on the front cover.
    8. Install tool J41476 or other suitable tool.
    9. Install the crankshaft balancer bolt and tighten the crankshaft balancer bolt by hand until snug but do not overtighten.
    10. Tighten the J41480 bolts and front cover bolts;
      • Torque to: 18 ft. lbs. (25 Nm).
    11. Remove the tools. NOTE: Place a straight edge across the engine block and front cover oil pan sealing surfaces. Avoid contact with the portion of the gasket that protrudes into the oil pan surface. Insert a feeler gauge between the front cover and the straight edge tool. The cover must be flush with the oil pan surface or no more than 0.5 mm (0.02 in) below flush. If the front cover-to-engine block oil pan surface alignment is not within specifications, repeat the cover alignment procedure. If the correct front cover-to-engine block alignment cannot be obtained, replace the front cover.
    12. Snug the oil pan-to-cover bolts in order to position the cover at the pan rail.
    13. Tighten the oil pan-to-front cover bolts;
    14. Tighten the front cover bolts;
    15. Install the crankshaft balancer and bolt (See: Crankshaft Damper).
    16. Install the water pump (See: Water Pump).
    17. Fill the engine to the proper level with oil.
    18. Fill the engine to the proper level with coolant.
    19. Test drive the vehicle to confirm the repairs.
    6.6L Engine To Remove:
    NOTE: The 6.6L engine uses gears in place of a timing chain. For removal and installation, please see the Camshaft and Lifters procedure. This procedure covers the removal of the front cover and seal.
    1. Before servicing the vehicle refer to the precautions at the beginning of this section.
    2. Remove the upper intake manifold sight shield as follows:
      • Remove the retaining bolt in the front of the shield
      • Lift up on the front of the shield, then lift the shield off the rear bracket
    3. Drain the cooling system.
    4. Remove or disconnect the following:
      • Negative battery cables
      • Right front wheel
      • Right front fender splash shield
      • Upper fan shroud
      • Fan clutch (See: Engine Fan and Clutch)
      • Drive belt
      • Oil dipstick tube
      • Thermostat housing crossover
      • Crankshaft damper (See: Crankshaft Damper)
      • Crankshaft front oil seal
      • Water pump (See: Water Pump)
      • Camshaft sensor electrical connector
      • Camshaft sensor bolt and sensor
      • Crankshaft Position (CKP) sensor connector, bolt and sensor
      • CKP sensor spacer bolts and spacer
      • 5 bolts securing the upper oil pan to the front cover
      • Bracket bolts and the bracket for the turbocharger outlet coolant pipe
      • Engine front cover bolts
      • Use a suitable seal cutter to separate the front cover from the cylinder block and upper oil pan NOTE: Do not bend the turbocharger outlet pipe.
      • Oil pressure relief valve from the front cover
    To Install:
    1. Clean and inspect all sealing surfaces.
    2. Install or connect the following:
      • Oil pressure relief valve with a new O-ring and tighten the valve
        1. Torque to: 30 ft. lbs. (41 Nm)
    3. Apply a 1/8 in. (2-3mm) wide to 1/16 in. (0.5-1.5mm) high bead of sealant to the front cover sealing surfaces to the engine block and oil pan.
    4. Install or connect the following:
      • New front cover O-ring after lubricating it with engine oil
      • Front cover and bolts and tighten the front cover bolts
        1. Torque to: 15 ft. lbs. (20 Nm)
      • Upper oil pan-to-front cover bolts and tighten the bolts
      • Turbocharger coolant outlet pipe bracket and bolts and tighten the bolts
        1. Torque to: 15 ft. lbs. (20 Nm).
      • Camshaft sensor and bolt and tighten the bolt
        1. Torque to: 80 inch lbs. (9 Nm)
      • Camshaft sensor connector NOTE: The CKP sensor spacers are machined with different timing positions. If you have to replace a spacer, make sure it has the same part number.
      • CKP sensor spacer and spacer bolts and tighten the bolts
        1. Torque to: 89 inch lbs. (10 Nm)
      • CKP sensor and bolt and tighten the bolt
      • Oil fill tube
      • Drive belt
      • Upper fan shroud
      • Right front fender splash shield and wheel
    5. Refill the cooling system with the proper type and quantity of antifreeze.
    6. Inspect the engine for leaks.
    7. Test drive the vehicle to confirm the repairs.
    Aug 27, 2010 | GMC Sierra 1500HD Cars & Trucks
    Need diagram to put timingbelt on 2001 kia sportage
    prev.gif next.gif Timing Belt Removal & Installation SOHC To Remove:
    1. Disconnect battery negative cable.
    2. Remove fresh air duct.
    3. Drain engine coolant into an appropriate container and retighten radiator drain plug.
    4. Remove upper radiator hose.
    5. Remove fan clutch assembly bolts.
    6. Remove 5 cooling fan shroud bolts.
    7. Remove fan shroud and fan as an assembly.
    8. Loosen alternator mounting bolts and remove drive belt from pulley.
    9. Remove fan pulley.
    10. Remove 4 cooling fan assembly bolts.
    11. Remove cooling fan assembly.
    12. Remove 4 bolts and upper timing belt cover.
    13. Remove 2 lower bolts and lower timing belt cover.
    14. Loosen adjusting bolt and remove A/C belt.
    15. Remove alternator belt.
    16. Loosen power steering pump lock bolt and mounting bolt.
    17. Remove drive belt from crankshaft damper. Camshaft timing marks kia-03-20-7032.gif
    18. Turn crankshaft until timing mark on front housing and the arrow "2" on the camshaft pulley align.
    19. Remove 5 bolts and remove damper.
    20. Remove timing belt guide from timing belt pulley.
    21. Loosen tensioner lock bolt.
    22. Pry tensioner away from timing belt and tighten lock bolt to relieve tension on the timing belt. NOTE: Mark the direction of timing belt rotation on the belt if it is being reused.
    23. Remove timing belt.
    To Install:
    NOTE: Timing belt pulley timing mark and timing mark must be aligned.
    NOTE: The arrow at "2" on camshaft pulley must be aligned with timing mark on front housing.
    1. Install timing belt with minimal slack from timing belt pulley to water pump and from water pump to camshaft pulley.
    2. Loosen tensioner lock bolt until tension is applied to timing belt. CAUTION
      Do not turn crankshaft counterclockwise.
    3. Turn crankshaft pulley 2 full turns clockwise and ensure timing marks are properly aligned.
    4. Tighten tensioner lock bolt to 33 ft lb (45 Nm).
    5. Apply a force of 21 lb to timing belt midway between idler pulley and camshaft pulley.
      • Deflection should measure 0.43-0.51 inch (11-13 mm)
      NOTE: if timing belt deflection is incorrect remove timing belt and install NEW tensioner spring.
    6. Install timing belt guide.
    7. Install crankshaft damper pulley.
    8. Install 5 crankshaft damper pulley bolts. Tighten bolts to 132 in lb (15 Nm).
    9. Install power steering pump drive belt.
    10. Adjust power steering pump drive belt tension and tighten lock bolt and mounting bolt.
    11. Install alternator drive belt.
    12. Install A/C drive belt.
    13. Install lower timing belt cover and bolts. Tighten bolts to 84 in lb (10 Nm).
    14. Install upper timing belt cover and bolts. Tighten bolts to 84 in lb (10 Nm).
    15. Install cooling fan assembly and 4 bolts. Tighten bolts to 27 ft lb (37 Nm).
    16. Install fan pulley.
    17. Install fan clutch and shroud as an assembly. Tighten bolts to 74 in lb (8 Nm).
    18. Tighten 4 cooling fan nuts to 16 ft lb (22 Nm).
    19. Adjust alternator belt tension and tighten alternator mounting bolts.
    20. Install upper radiator hose.
    21. Install fresh air duct.
    22. Connect battery negative cable.
    23. Refill/bleed cooling system.
    DOHC To Remove:
    3. Remove 5 cooling fan shroud bolts and 4 thermo-modulated fan nuts.
    4. Remove 4 thermo-modulated fan shroud fasteners.
    5. Remove generator drive belt.
    6. Remove fan pulley (located above crankshaft pulley).
    7. Remove 4 bolts and splash shield (located under front of vehicle).
    8. Remove A/C drive belt and power steering drive belt. Timing Belt Removal kia-03-20-7097.gif
    9. Remove 5 bolts and upper timing belt cover.
    10. Remove 2 bolts and lower timing belt cover.
    11. Loosen tensioner lock bolt and pivot tensioner pulley outboard.
    12. Retighten tensioner lock bolt. NOTE: Mark timing belt for rotation if it is being reused.
    13. Remove timing belt.
    To Install:
    1. Align marks on timing belt pulley and pump body. Camshaft pulley alignment marks 79245g28.gif
    2. Align marks on camshaft pulleys with alignment marks on seal plate.
    3. Install timing belt. NOTE: No looseness should exist on the tension side and at the camshaft pulleys.
    4. Loosen tensioner lock bolt.
    5. Turn crankshaft 2 revolutions in direction of rotation and check that timing marks are still in alignment.
    6. Tighten timing belt tension lock bolt to 27-38 ft lb (32-52 Nm).
    7. Apply a force of 22 lbs to timing belt between camshaft sprockets.
      • Belt deflection should measure 0.30-0.33 in (7.5-8.5 mm)
      NOTE: Replace tensioner spring if timing belt deflection is excessive.
    8. Install lower timing belt cover.
    9. Install upper timing belt cover.
    10. Install power steering drive belt and adjust belt tension.
    11. Install fan pulley.
    12. Install generator drive belt and adjust belt tension.
    13. Install A/C drive belt and adjust belt tension.
    14. Install splash guard.
    15. Install fan and fan shroud.
    16. Install 4 fan bolts. Tighten to 24 ft lb (33 Nm).
    17. Install fan shroud mounting bolts.
    18. Install fresh air duct.
    19. Connect hose to resonance chamber.
    20. Connect battery negative cable.
    Aug 02, 2010 | 2001 Kia Sportage
    My 2001 jeep grand Cherokee will not start don?t know why no codes are coming up put new cam sen, crank sen, coil pack, new ecu, new coolant temp sen, it turns over but will not run has injector pulse and...
    Timing Chain, Sprockets, Front Cover and Seal REMOVAL & INSTALLATION 2.5L and 4.0L Engines
    1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
    2. Remove or disconnect the following:
      • Accessory drive belt
      • Cooling fan and shroud
      • Crankshaft damper
      • Front crankshaft seal
      • Accessory brackets
      • Front cover
      • Oil slinger
    3. Rotate the crankshaft so that the timing marks are aligned. Fig. 1: Timing chain alignment marks — 2.5L and 4.0L engines 7924pg20.gif
    4. Remove the timing chain and sprockets. To install:
    5. For 2.5L engines, turn the timing chain tensioner lever to the unlock (down) position. Pull the tensioner block toward the tensioner lever to compress the spring. Hold the block and turn the tensioner lever to the lock (up) position. Fig. 2: Timing chain tensioner — 2.5L engines 7924pg19.gif
    6. Install the timing chain and sprockets with the timing marks aligned. Tighten the camshaft sprocket bolt to 80 ft. lbs. (108 Nm) for 2.5L engines or to 50 ft. lbs. (68 Nm) for 4.0L engines.
    7. For 2.5L engines, release the timing chain tensioner.
    8. Install or connect the following:
      • Oil slinger
      • New front crankshaft seal to the front cover
      • Front cover, using a new gasket
      • Timing Case Cover Alignment and Seal Installation Tool 6139 in the crankshaft opening to center the front cover Fig. 3: Timing Case Cover Alignment and Seal Installation Tool 6139 — 2.5L and 4.0L engines 7924pg21.gif
    9. Tighten the front cover bolts as follows:
      1. Step 1: Cover-to-block 1⁄4 inch bolts to 60 inch lbs. (7 Nm)
      2. Step 2: Cover-to-block 5⁄16 inch bolts to 16 ft. lbs. (22 Nm)
      3. Step 3: Oil pan-to-cover 1⁄4 inch bolts to 85 inch lbs. (9.5 Nm)
      4. Step 4: Oil pan-to-cover 5⁄16 inch bolts to 11 ft. lbs. (15 Nm)
    10. Install or connect the following:
      • Crankshaft damper. Tighten the bolt to 80 ft. lbs. (108 Nm).
    11. Start the engine and check for leaks.
    Jul 30, 2010 | 2001 Jeep Grand Cherokee
    Hiwich timing mark I used to time the balancer shaft on a 99 honda accord with a 2.3L
    To Install:
    NOTE: Clean balancer belt drive pulley, timing belt pulleys and upper/lower timing cover prior to belt installation.
    1. Set timing belt drive pulley to TDC by aligning dimple on pulley with dimple on oil pump. honda-03-23-3426.gif
    2. Set camshaft pulley to TDC so that "UP" mark is at top and grooves align with top of cylinder head. Timing belt installation honda-03-23-3549.gif
    3. Starting with driver pulley, install timing belt in a counterclockwise sequence.
    4. Loosen and ten retighten adjusting nut.
    5. Install balancer belt drive pulley. NOTE: Inspect rubber seal on lower cover and replace as necessary.
    6. Install lower cover.
    7. Install crankshaft pulley and bolt.
    8. Rotate crankshaft pulley counterclockwise several times to seat belt.
    9. Loosen adjusting nut 1 turn.
    10. Rotate crankshaft counterclockwise 3 teeth on camshaft pulley.
    13. Ensure that camshaft pulley "UP" mark is at top and grooves align with top of cylinder head.
    14. Remove crankshaft pulley and lower cover.
    15. Rotate crankshaft to TDC again and lock timing belt adjuster arm with a 6 mm timing cover bolt.
    16. Loosen adjuster nut 1 turn and ensure that belt tensioner freely moves.
    17. Push tensioner up and tighten adjusting nut. Balancer shaft alignment honda-03-23-3556.gif
    18. Remove bolt and washer from maintenance hole.
    19. Using a 6 X 100 mm bolt, scribe a mark 2.9 in (74 mm) from end.
    20. Insert bolt into maintenance hole and hole in balancer shaft.
    21. Install bolt up to scribed line. Balancer shaft alignment honda-03-23-3557.gif
    22. Align groove on balancer shaft with pointer on oil pump housing.
    23. Install balancer belt and loosen adjusting nut 1 turn to tension.
    25. Remove bolt from maintenance hole and install bolt and washer. Tighten to 22 ft lb (29 Nm).
    26. Reinstall crankshaft pulley.
    27. Loosen adjusting nut 1 turn.
    28. Rotate crankshaft pulley counterclockwise 1 turn and tighten adjusting nut.
    29. Remove bolt from timing belt adjuster arm. NOTE: Inspect rubber seal on lower cover and replace as necessary.
    30. Remove crankshaft pulley.
    31. Install lower cover.
    32. Install seal at adjusting nut. NOTE: Crankshaft pulley, bolt and washer must be cleaned prior to installation.
    33. Lubricate crankshaft pulley bolt between head and washer and bolt threads with clean engine oil. honda-03-23-3537.gif
      CAUTION
      Do not use impact wrench to perform following step.
    34. Install crankshaft pulley and tighten bolt using special tools to 181 ft lb (245 Nm).
    35. Install dipstick/tube assembly.
    36. Install upper cover. Tighten bolts to 9 ft lb (12 Nm).
    37. Install cylinder head cover.
    38. Install alternator bracket and alternator.
    39. Install power steering pump belt and alternator belt. Upper bracket installation honda-03-23-3420.gif
    40. Install upper bracket and tighten fasteners in proper numbered sequence.
    41. Install stop.
    42. Install battery and enter radio anti-theft code.
    Jul 03, 2010 | Cars & Trucks
    Can not figure out where the pieces go to hold fan together (center piece) show diagram if can thank-you
    Jim Hart
    Jun 20, 2010 | Optimus F-1212S Table Fan
    How do you change the fan belt on a john deere mower? The model is X740.
    You must remove drive shaft,once that is done you can remove bolts holding pulley on the flywheel and then slide belt around fan.The pulley will become two halves once you remove bolts securing it to flywheel,When putting back together you must rotate flywheel to help alignment of belt in v-groove.
    Nov 04, 2009 | Garden
    Dryers Logo
    22 people viewed this question
    Top Dryers Experts
