Question about Garden
Just bought jd214 used got mower deck down but not cutting grass
  • 6 Answers
SOURCE: Drive belt diagram
go to and put in model# for parts look up and they will have it or call 1-800-4my home to get owner manual
Posted on Apr 30, 2009
  • 376 Answers
SOURCE: Craftmen mower doesn't cut well on right side
Sounds like you may have made a common mistake, getting one or both of the blades upside down.
Posted on Jun 28, 2009
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
  • 360 Answers
SOURCE: uneven grass cutting
I have seen dull blades, blades not installed right and an un-level deck cause that.
Hope this helps.
Posted on Sep 21, 2009
  • 146 Answers
I think either the bolt holding the left blade onto the spindle is loose, or the cup washers under that bolt are flattened or missing. As a result, the blade is slipping on the shaft and probably making a squeal or squawk. Take off the deck, flip it over, and remove the blades. Note if the bolts seem tight. And look at the washers stacked under the bolts. Replace any missing washers, or flattened cup washer. Make sure the cup washer faces the right way (hollow side toward the blade). Tighten things back up securely - it takes a hefty pull on the end of a 2 foot long wrench to get enough torque.
Posted on Jun 18, 2010
How to use mulch plug on cordless mower
Mulch plugs are typically a cover that is affixed to the discharge chute of a mower deck. As blades spin, they cut grass, and lift them up into the swirling air above the cut grass and below the mower deck. The clippings are suspended until they are blown out of the chute.
Mulching, is the process where grass clippings aren't simply discharged out of the chute after cutting; rather they are kept under the mower deck and spin around suspended in the blades resulting in repeatedly being cut. Instead of long clippings exiting the chute, much smaller clipping result from multiple cuttings and settle back on to the lawn under the deck. The smaller clipping allows them to decompose much quicker and return nutrients to the lawn.
Long clippings take longer to decompose and can turn into thatch on top of soil between blades of grass - effectively smothering the lawn. Long clippings can sit on top of cut grass and choke off sunlight, etc. and cause dead spots. Thatch can occur with mulching too - but takes longer to accumulate.
I nearly always mulch
Apr 17, 2015 | Worx Garden
My craftsman DLT 2000 won't cut grass , the pulleys are clean n moving the blades are rotating but when I let the deck down to cut the grass it stops and sounds like the belts trying to turn, making the...
be sure the blades are not bent and you dont feel any wiggle when pushing them up and down. be sure nothing is wrapped around the spindles. be sure the belt isnt damaged and tight when the deck is engaged to cut with the engine off.
Sep 18, 2017 | Garden
I have a Craftsman SL3500 42" riding lwan mower. the two blads make uneven paths ans the left blade makes a cut about 1/4" lower than the right blade. What do I do?
You should be using a up lift blade it will help by sucking up the grass to be cut. You should have an adjust on both sides of the blade deck . As for the strip check to see if you have a wheel behind the mower deck. If you do it might be the cause for mower leaving a strip uncut . Sears has been noted for putting wheels in the path of the blade area and smashing the grass down . That is also why I suggest to use an up draft blade it should **** the grass back up again so you can cut it.
Oct 07, 2013 | Craftsman Garden
Riding mower deck height too low
If you have removed the cutting deck for any reason you may have put the deck arms in the wrong knotch.
Apr 08, 2017 | Yard Man Garden
My 10 steps to ensure even cutting for any riding mower.
1. The rear tires must be the same diameter i.e. same tread type and the same amount of pressure
2. Level the deck following the instructions in the manual
3. Make sure the blades are not damaged or bent.
4. Make sure the deck nor its attachments are bent
5. keep the blades sharp and don't drive too fast when mowing.
6. Over lap rows about 20%
7. Cut the grass at intervals that ensures you never cut more than 1/3rd the total length of the grass.
9. Make sure the underside of the deck is free from chunks of clippings.
10. Use a blade with higher lift, yes you have to match the blades to the type of grass you cut most often, (commercial mowers use a universal blade and high speed decks).
Jun 18, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
1993 john deere 445 surging and popping down on power won't spin mower deck fast enough to cut grass. seems to be running rich.
sounds like the flote is stuck down in the carb thats causing it to flood up strip card and give it a goofd clean out
its that or the mower deck is sezed up or the blades are rounded off and your stalling the engine trying to turn it and cut grass,, have a look at them as well,,,
Nov 17, 2009 | Garden
Jun 28, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Bog when trying to mow
you are cutting to much grass & it isn't kicking it out fast enough out of deck which will bog it down it might help if you clean out the bottom of the deck & also dont cut really low if grass is really tall also cutting wet grass will aslo cause the bogging if i can further help e-mail me wade at
Jun 26, 2009 | Garden
My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Jun 23, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
