Question about Dryers
Control panel on 2013 19bhs,and i have 2 switches at entrance inside,one turns on lights,the second does nothing that i can tell?
Sportsmen
milten1
  • 1304 Answers
SOURCE: I have an MER 6772
odd i just saw this one...
ok i would check to make sure all your connections are tight to the new control board.
then check where the chord connects to the range
make sure all your connections there are tight and secure
then check to ensure you have the proper voiltage at the outlet
120v on bothe sides to ground
220v between l1 and l2
Posted on Oct 17, 2009
ginko
  • 19396 Answers
SOURCE: Whirpool GGw9250Pw3 no power on Control Panel Inside light works
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
The front light lit on my Whirlpool.
Regards.
Posted on Feb 22, 2010
rylee_smith
  • 8619 Answers
SOURCE: control panel not working
Hi
Thanks for using FixYa. To reset the dryer you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. If still the issue is not resolved then unfortunately you'll have to replace the control panel. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 31, 2010
murdozzz
  • 41 Answers
SOURCE: whirlpool dishwasher:DU915PW PQ0 Hi :) It was
i would check the fuse fist to establish if there is power to the appliance first
Regards
Ian
Posted on Apr 20, 2011
  • 368 Answers
SOURCE: Minimax NT.. Shows green power
I would call the Pentair technical support line because they may be able to help you figure this thing out. I hope this helps.
Please vote on this answer. Thank You.
Posted on Aug 25, 2011
Tv turns on for less than 30 seconds and turns off and red light is blinking
Hi John,
TV going off in thirty seconds and red light blinking means there is something wrong inside your Tv and it should not be working in this condition and hence is the "going off" happening. The automatic protection inside is switching your tv off. Please consult some local TV tech. There is nothing you can do about it yourself.
Good Luck.
May 23, 2015 | LG Televison & Video
Where do i find the switch for my Hotwater heater inside my keystone vr1 323fks
I don't have this model, but it is usually on the main control panel along with main lighting, slides, etc. Usually near the entrance.
Mar 10, 2015 | Keystone 2008 VR1 323FKS
In the kitchen I have replaced the light sockets a double inside the the main entrance & a single switch by the utility room the double switch controls the lights under the units & the main light,...
can't quite make out the question, but feel your fear-o-stick.
You have 3 way switch.
So 2 different switches control same light(s)
If this is true, then wires are reversed on one switch or the other, or both switches are wrong.
I've been there.
Copy following links to see illustration of typical 3-way switch wiring, and then lets do some testing.
http://waterheatertimer.org/images/GE-15312-3-way-circuit-600.jpg
http://waterheatertimer.org/How-to-wire-switches.html#3-way
Each 3-way switch has 3 screws (plus green ground screw)
We are not going to discuss the green ground screw.
Each 3-way switch has a 'common' screw. And two traveler screws.
Th common screw should be different color than other two screws.
Or there is a marking on back of device that denotes 'common.'
Please note your common screws.
Disconnect all wires from both switches.
Separate wires for testing.
Turn power ON.
Tape wood sticks to tester so hands are away from power.
Stand on dry surface or boards. Never stand on bare ground.
http://waterheatertimer.org/images/GFCI-protection-2-402.jpg
Power is ON. All 3 switch wires are separated on both switches, so you have 6 total wires to test.
Test each wire to bare ground wire.
One and only one wire will test for live power to ground.
This is Hot wire, and it will connect to 'common' screw.
Other two wires will connect to two traveler screws.
Switch #1 is done.
Turn power ON again. Three wires are still separated on second switch.
At second switch, test each wire to bare ground. Note which wire shows power. This is a traveler wire.
Go back to first switch and flip the switch other direction.
Repeat test at second switch. Note which wire shows power. This is also a traveller wire.
There should be 2 traveler wires.
Connect these two wires to the screws that are NOT common.
Other wire connects to 'common' screw.
ADD A COMMENT for more help.
Sep 09, 2012 | Home
Washibng machine switches on but nothing happens.
Step 1: Make sure the washer is receiving power. Check the cord, the plug, and the outlet. If a wall switch controls the outlet, make sure the switch is working. Look for blown fuses or tripped circuit breakers at the main entrance panel. If the unit is receiving power and still won't run, press the reset button on the control panel (if the washer has one).
Step 2: Make sure the control knob is properly set to the ON position and the door is tightly closed. Check the latch to make sure it's free of lint and soap buildup.
Step 3: Make sure that both water faucets are turned on and that the drain and soap-saver return hoses are properly extended, without kinks. If the washer has a water-saver button, make sure the button is depressed; water may not circulate through the filter nozzle if the basket is not full and the button is not depressed.
Step 4: To make sure the water is the proper temperature, check the temperature selector switches on the control panel to make sure they're properly set. Also check the water heater temperature control. It should be set no lower than 120 degrees F.
Apr 29, 2011 | Bosch WFL 2062 Front Load Washer
After self clean the door will not unlock. Tried resetting circuit breaker several times. Tried to restart the cleaning and cancel after 15 min. Tried restarting cleaning and cancel after 1 min. Tried...
Hi
Thanks for using FixYa. There is an over-temperature switch built into the electrical panel of the oven. Resetting this switch solved my problem.
To reset it: Turn off the power. Open the door (if door is locked, turn the power back on and gently try pulling the door every few seconds as the locking mechanism cycles until it is unlocked). Remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven). Pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
Within the electrical enclosure exposed by removing the control panel, look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 19, 2009 | Kitchen Ranges
I have a 2008 Honda CRV and for the life of me I cannot engage the Cruise control- I press the Cruise Button on the right of the steer wheel and nothing happens - nothing Help anyone ? Tks Nancy
The cruise-controls have 2-buttons that must be activated before it gets the car going when you remove your foot off the gas-pedal.
The cruise button is essentailly a switch that turns 'on' the cruise servo-motor that tells the sytems that you wants to use it, so it gets ready.
There are other three switches on the right-side of the steering wheel namely: resume accel; cancel; set decel.
To get your car to cruise: you must steady your speed and foot on the gas-pedal. You cannot just press the switches and expect the car to cruise. It takes about two-to-three seconds for the system to respond to a set cruising speed.
How to do it: accelerate to a speed of about 30-mph. Press the 'cruise' button on the dash first. Next you press 'set decel' button. This will turn 'on' the cruise control light on the instrument panel. Then wait a second or three and you would feel the cruise engagement. Any touch on the brake pedal will slow down the car and turns the cruise off. The 'cancel' button turns off the cruise light on the instrument panel.
If you hit the brake-pedal at any time for any reason, and you would like to continue cruising again, simply press the 'resume accel' button.
The cruise system works in conjunction with the braking system of the car. So all major parts of the braking system must be in good condition, otherwise the cruise system could shut off itself.
Sep 28, 2009 | Honda CR-V Cars & Trucks
GE Profile Electric Self cleaning oven locked still lit
There is an overtemperature switch built into the electrical panel of the oven. Resetting this switch may solve the problem.
To reset it:
TURN OFF THE POWER!
Open the door (if it is locked, turn the power back on and gently pull on the door every few seconds as the locking mechanism cycles until it is unlocked)
remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven)
pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
Within the electrical enclosure exposed by removing the control panel, Look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure. usually located nearly in the middle of the electrical enclosure.
Push the tiny button on top of the switch. You should feel a click.after Reassemble and power up.
hope this solves the problem do let let me know i will appreciate a fixyaa rating thanks and Godbless
Nov 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Got a hoover washer /dryer wdm 1300 , it wouldnt empty properly, watched the impellor on the pump and some times it would run and then stop , a quick flick with a screw driver and away it went again ,also...
HI CHECK THESE....
THANKS
Sep 12, 2008 | Washing Machines
Green light comes on for 2 seconds and then nothing
most of the time the led in front of the tv will blink red and that will tell the technician wich circuit to look in. if it does blink at all when it shuts down then the problem is more than likely in the power supply. the part number for that is 313819875691
Oct 12, 2007 | Philips 20PF5120/01 20 in. EDTV-Ready LCD...
Mitsubishi WS-55411 55 in. No Power up
Error code 12 means normal operation. On these models we have found that a switch is bad on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on set. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. You can use an ohm meter to find the bad switch.
Jul 04, 2007 | Mitsubishi WS-55411 55" Rear Projection...
Dryers Logo
18 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
