Question about Dell Optiplex GX270
Dell optiplex gx150 power button just flashes - help?
Nothing appears on the screen. Monitor say no signal
no running sounds from modem only power button flashes amber color.
  • 1 more comment
  • iamjar21 Jul 25, 2009
    Thanks, however, I have done that many time already. The light just flashes amber.
    any other suggestions?
  • iamjar21 Aug 08, 2009
    Thanks for your help -everyone.
    I think it was the power supply I returned it to where i got it and they gave me another.
  • iamjar21 Sep 04, 2009
    Thanks for the comments/help
    i took the PC back to where i got it and they gave me a new one.
    Problem Solver:
  • 12 Answers
I get the feeling that the flashing Amber light is on the video monitor and what you refure to as the modem is the large desktop case with everything pluged into it right?
Could be 1 of 2 problems;
1) faulty power plug or house/powerboard
Check power cord and check that plug has power.
2) Faulty Power Supply Unit (PSU)
Renew PSU, look on Ebay or old computer auctions
Posted on Jul 28, 2009
  • 71 Answers
System seems to be in hibernate or standby mode and frozen in that state. Hold dosn power button for 5 seconds or until all signs of life shut down. Wait about 30 second and power up the system.
Posted on Jul 25, 2009
  • GFXTech Jul 25, 2009
    Symptom sounds like a bad power supply. If the system has been moved around (knocked) their may be a lose cable. Checking all cable to make sure they are well seated may help. Some systems are designed to not power up at all if the CPU fan does not engage (locked or burnt out). LED's will light up, but system will not run. Bad or memory chips that come loose may also cause the system to quick cycle and then power down to a low power like state. Some Wal-Marts now have Dell service desks in electronic dept.
Dell OptiPlex GX150 no display no sound with yellow led
Hi, just pull out your memory card and clean it with an eraser. And insert it tightly again and don't forget to clean also the memory bank.
Hope it will help you.
Mar 27, 2012 | Dell OptiPlex GX150 SF PC Desktop
My xp pro on Dell gx150 not saving settings
Try to use the System Restore, this process will fix all system errors in your computer.
In your desktop screen, go to:
  1. Start Menu
  2. All Programs
  3. Accessories
  4. System Tools
  5. System Restore
  6. In the System Restore Window, choose Restore my computer to an earlier time.
For example: Today is March 22, try to locate the date were your computer is in perfect condition.
7. Click Next
8. Then you'll see some marked dates
which means those are the dates to use
the system restore
9. Choose a date, then click Next
button
10. Your computer will automatically
restart then wait for the process to
finish
11. A message will appear that states
your computer is successfully restored
12. Then observed the changes in
your computer system
Mar 22, 2010 | Dell OptiPlex GX150 PC Desktop
Fan makes a lound noise and power button is orange
It sounds as if your power supply is cooked because the cooling fan has been running slow
Only way you can check is to take a panel off and hook a voltmeter into the 12v & 5V supplies on the Hard Drive and the Floppy Drive.
Jun 25, 2009 | Dell OptiPlex GX280 PC Desktop
Dell optiplex gx150 cd drive won't boot
Hmmm--when you went into the BIOS setup, your first boot device should be CD. The next your hard drive. The other boot devices should be set to disabled. Now if you have a third boot device as a network device, then your computer is not seeing the CD or the Hard drive--you have a problem. If all the drives are hooked up properly (sounds like you have that covered) then your motherboard is probably the problem.
I would try to disconnect all your stuff except the CD. Try it on the first IDE channel (set it either as cable select or master). If that fails, try it on the other channel. Do you have a second CD to swap out?
Still no boot? Bad motherboard.
Mar 28, 2009 | Dell OptiPlex GX150 PC Desktop
Dell Optiplex Power-on Problem
An Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc...
Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 18, 2009 | Dell OptiPlex GX260 PC Desktop
Audio problem
Go to this link:
http://www.free-codecs.com/XP_Codec_Pack_download.htm
Download it. When a box appears, Click Run button.
Best regards
Jan 03, 2009 | Dell OptiPlex GX150 SFF (GX150BLACK) PC...
Boot problem with Dell Optiplex GX150
To reinstall Xp from the CD you need to press F2 and go into the BIOS then select the boot order configuration and make the CD the first boot device and the hard disk the second boot device.
After installing XP, if you wish you can go back into the BIOS and change the boot order to boot from the hard disk first.
Dec 13, 2008 | Dell System Board for Optiplex GX 150,...
Dell Optiplex GX270  Logo
495 people viewed this question
Alun Cox
