Question about SkyCaddie GPS
MY SKYCADDIE TOUCH IS STUCK ON THE CALABRATION SCREEN. HOW DO I GO BACK TO HOME SCREEN?
I have a SGX and have lost the antenna cover. Can I find a replacement?
Stay AWAY from the SGX. The quality control is really poor. I know of three other users having the same problem, the antenna cover falls off and the unit does not get satelite reception. It becomes a piece of junk. Once that unit got replaced, in less than 5 months, the rubber covering the knob that allows you to select items had a tear and now the unit is no longer waterproof. This is not covered under warranty and they want you to pay $89.95 for a replacement. I am done with SkyCaddie. I have just purchased the new Garmin G6, awesome device, no annual fees, long battery life and touch screen enabled.
Look at the following link to get other user experiences.
Amazon com Customer Reviews SkyCaddie SGX Golf GPS
Feb 09, 2015 | SkyGolf SkyCaddie SGX GPS Receiver
When I turn on my skycaddie at the golf course or at home , I geta message, could not start Application
Are you sure you have registered the device with Skycaddie? If not theedsahe will continue to appear.
I would call them make sure you have all the information they will need on hand (model number, etc).
They are very helpful and can even download the course there and then to your device for you if it is not all ready loaded. Hope this helps.
Jan 15, 2015 | SkyGolf SkyCaddie Handheld GPS Unit
My toshiba e studio 350 machine toner is very high.how could adjest devoloper and toner ratio please help.
05 turn on copier hold for 5 sec will go to test mode 200 print will start developer calabration going down in numbers adds less toner go down about 50 in numbers so it wiil stop adding then press set this is done all on touch screen except for 05 and 200 use keypad
Feb 07, 2013 | Toshiba e-Studio 350 Copier
Help please tell how to exit recovery mode
How to Fix an iPod Touch Stuck in Recovery Mode With a Free Program
An iPod Touch's "Recovery Mode" is for alleviating major operating system issues. Recovery Mode rolls back your iPod's operating system, stripping problematic updates and downloads from the unit. The goal of this total system recovery is to revert the iPod to a stable, usable version. Before you use Recovery Mode, exhaust other troubleshooting methods. In some cases, Recovery Mode is triggered automatically after a failed system update or system restore. When it goes into Recovery Mode automatically, you cannot use your iPod until you complete the recovery process. You can get your iPod Touch out of Recovery Mode using Apple's free iTunes software.
Things You'll Need
-Apple iTunes-USB cable
Instructions
1 Turn on your computer and open iTunes. If you are prompted to download any new iTunes updates, install the updates before proceeding.
2 Plug an iPod USB cable into your computer. Do not plug the other end into your iPod Touch yet.
3 Turn off your iPod Touch. If the iPod Touch is already shut down, skip this step.
4 Press and hold the Home button on your iPod Touch, and plug the other end of the USB cable into your iPod Touch.
5 Release the Home button after you see a white USB icon and the iTunes logo appear on your iPod Touch's screen. At this time, a pop-up should appear on your computer screen, explaining that the software has detected an iPod in Recovery Mode.
6 Click "OK."
7 Click on the iPod Touch from underneath the "Devices" heading on the left-hand side of your screen.
8 Click on the "Home" tab, and then click "Restore." Once it's restored, your iPod Touch goes out of Recovery Mode and you can start using it again. The restoration process takes a few minutes. Do not disconnect your iPod Touch until a prompt appears, letting you know the system restored successfully.
Dec 24, 2011 | Apple iPhone Audio Players & Recorders
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
Itouch stuck on the playlist screen??
mine does this sometimes also, i'll be in a program and i hit the home button and the music/ close menu will pop up. i hit close or hold down home and it goes back. there was a new update to the unit so that might fix it also
Nov 30, 2008 | Apple iPod touch
Touch screen not working
the only solution i have found...replace the phone
Feb 20, 2008 | HTC Touch P3450 Smartphone
GPS Logo
73 people viewed this question
Top SkyCaddie GPS Experts
Joseph Hoffmann
Will Halftowaite
Are you a SkyCaddie GPS Expert? Answer questions, earn points and help others
