Question about Shredder Office Equipment & Supplies
Why is my shredder works on and off whenever it feels like it as if it has a mind of it's own?
  • Shredder Master
  • 1,830 Answers
Unplug it and check if there is any paper caught in its teeth.
Posted on May 18, 2017
Testimonial: "that was the first thing i checked, it's clean where is the phone number where i can call someone here ?"
  • joe hamed
    joe hamed May 18, 2017
  • Pamela Leach
    Pamela Leach May 18, 2017
    Who manufacturers your machine? If you know that you can call them for help.
Unit runs with nothing inserted into shredder
About 598,000 results (0.73 seconds) Search Results
    [PDF]Shredder Troubleshooting FAQ
    https://images-na.ssl-images-amazon.com/images/I/81GTHxKpz9S.pdf
    Make sure that the unit is securely plugged into a working outlet / socket. 2. If you have ... The shredder runs but it does not pull paper down. 1. Be sure the ... When ready to shred, be sure to insert material directly into the center area to start.
    [PDF]Instructions Manual
    https://images-na.ssl-images-amazon.com/images/I/71EUxqIkPNS.pdf
    you leave the shredder in the "Off" position whenever the shredder is ... To beginshredding, locate the switch on the unit and select the "Auto" mode (FIGURE 2). ...Your basic vegetable or cooking oil (nothing flammable ... a) While in "Auto" mode, the motor will not start running until paper is inserted into the feed slot. Set.
    General Shredder Troubleshooting - iThinkBlue
    store.ithinkblue.com/shredder-troubleshooting/
    Make sure that the unit is securely plugged into a working outlet / socket. ... While in "Auto" mode, the shredder will not run until paper is inserted into the middle ...
    [PDF]troubleshooting paper shredders - Ativa
Jan 31, 2016 | Shredder Office Equipment & Supplies
How do you removed jam paper in the schredder
1) pull what you can of the jammed paper out. Make sure the shredder is unplugged whenever trying to work on or in the unit.
2) Then liberally soak the remaining jam with shredder oil and let it sit for 15-20minutes.
3) Try to pull out what you can again. Use tweezers or pliers if available.
4) Then first start the shredder in reverse and then alternate for a few seconds between forward and reverse.
5) If it is still jammed repeat all of the steps as necessary.
Mar 09, 2015 | Omnitech 10-Sheet Micro-Cut Shredder
How do you oil a compucessory CCS60060
Most shredder are oiled by squirting some shredder oil in a serpentine pattern over a piece of paper to be shredded and run it through. Do this whenever you empty the shredder bin.
You can usually find small bottles this special oil of it at Wally World or the like. I use Fellowes oil.
Aug 28, 2014 | Compucessory CCS60060 Shredder
Why doesn't OfficeMax OM99732 shredder work on Auto?
My shredder would not sense paper being inserted and the sensor could not be cleaned. So "Auto" no longer worked but the manual reverse DID work. I opened the thing up, reversed the polarity on the red and black wires on the connector for the main drive motor and VOILA!!! I can use my shredder in manual mode by switching it to REV. Be mindful that this keeps the motor running until it is switched off. This can heat the motor and cause failure so I limit my shredding to 60 seconds then give it a rest so it will cool down. Also there is no emergency reverse so watch your fingers and neck ties.
Dec 17, 2012 | Office Equipment & Supplies
Is there a reverse button for the shredder
Yes, it has an automatic reverse whenever it has jammed. Hope this helps.
May 05, 2011 | Intimus 431 se Shredder
MY SHREDDER WORKS BUT WILL NOT SHUT OFF WHEN ON AUTO. THE LASER LIIGHTIS BURNED OUT
Try cleaning the eyes first...if that dosnt work and you feel they have to be replaced you can contact Royal at 1-800-524-0799 for parts assistance.
Jan 16, 2011 | Royal VF1012mx Shredder
How do I lubricate my NoviTech shredder?
If you prefer the convenience and don't mind the extra cost, you can buy shredder lubricant sheets at an office supply store and follow the directions on the package.
Or for a far less expensive method, buy a bottle of generic mineral oil (or baby oil) in the drug store. Spread 1/2 tsp of the oil onto a piece of letter size scrap paper, and run the oiled paper through the shredder. Then run the shredder in reverse for a few seconds and in forward for a few more seconds to spread the oil over the shredding cylinders. That's it.
Feb 04, 2010 | Shredder Office Equipment & Supplies
My Fellowes p600c-2 shredder will only run in reverse. I've blown compressed air on the switch and pushed on it with a toothpick but neither method worked. I removed 6 screws and the cover of the on/off...
Never mind providing help, I fixed it myself. There is a seventh screw hidden under one of the adhesive labels. I removed that screw and was able to disassemble the shredder. The plastic trigger mechanism that starts the shredder when paper is put in was stuck. I freed the trigger mechanism and reassembled the shredder. Now it works fine.
Jan 17, 2010 | Fellowes P600C-2 Shredder
Acheiver CCS5000 screaching noise
A piece of metal or coin might have gone into the shredder.
Apr 22, 2009 | Achiever CCS5000 Shredder
How to fix a stuck shredder
Go to your local hardware store, and pick up a quart of 3 in 1 oil, shredder oil or some other light weight oil. (With the shredder in the off position or unplugged). Use a couple of ounces and Pour the oil over the paper that is jammed in the shredder. Use enough oil so it saturated the jammed paper. Wait about 10 - 15 minutes so the oil really soaks into the paper. Don't go crazy with the oil, and keep in mind what goes in, must come out. If you pour too much oil in the shredder, the exess oil will drip out. Don't worry about having oil in the shredder blade, this will help lubricated the teeth, and it will actually make your shredder blades last longer.
Now try to turn your shredder on after the oil has soaked into the paper for 10-15 minutes. Hopefully, the paper that is stuck has gotten softer, and then it should pass the paper. If it still doesnt work, then, try some more oil on the paper, and then wait and then turn the shredder to the forward, and then reverse mode, and then back and forth.
Hopefully your shredder will be unclogged by this time.
Hope this helps.
Good luck.
Feb 04, 2008 | Office Equipment & Supplies
29 people viewed this question
Top Shredder Office Equipment & Supplies Experts
Ross Keen
Dave Reilly
Level 1 Expert
Gilbert Ruiz
Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
