Question about Tablets & eReaders
My Galaxy Note 3 SM-N900T is not seandroid enforcing set bit warranty I can't get into it
I have a Galaxy Tab S2 8.0 wifi only SM-T710NZWEXAR. Is it a real model? I can't find support for it anywhere. Not even hen I search on the Samsung website
Looks like a valid model - e.g. portableone.com is selling it, but to verify, check the About information on the Settings screen. Samsung should be able to track it using the tablet's MAC address. Try Samsung Global in case this model is one sold outside North America.
Jan 03, 2017 | Samsung Tablets & eReaders
I have a Samsung galaxy tab 3 sm t210, can i connect it to my television
Yes, you can either "cast screen" using the TV settings as well as the Tab button (providing your TV is fairly modern and with that feature)
But the easiest way is to buy a HDMI cable with a micro HDMI/USB from your phone on one end that converts up to the standard size HDMI...plug and play (just adjust the input port on your TV menu)
Oct 12, 2016 | Samsung Galaxy Tab 3 7.0" - White...
My samsung t210 is not resetting i have tried button and inside setting options both look like its working but when reboots no change the accounts come back aswell
Before performing the Hard Reset:
- In case your Galaxy Tab 3 7.0 can connect to a computer, Then it is better to make a backup of your saved data using Samsung kies software, You can read this Guide to learn how.
- But in case that is not possible, Then you can check that your phone's battery has enough charging level, Otherwise you should charge it.
Samsung Galaxy Tab 3 7.0 SM-T210 and SM-T211 Hard Reset Steps:
- Turn your Galaxy Tab 3 off.
- Take out any existed SIM or memory card.
- Wait for 10 seconds.
- Press and hold the Volume Up key + Home key, Then press the Power key.
- Keep pressing the keys until Samsung logo appears,Release all keys.
- Wait until you get Factory reset / System Recovery menu on screen.
- Use the Volume Down key to select Wipe Data / Factory Reset option.
- Use the Power key to confirm the operation.
- You need to use the Volume Down key again to select "Yes -- delete all user data"
- Use the Power key to confirm.
- After performing the hard reset, Select Reboot System Now option, And confirm it using the Power key.
- Now the phone will reboots, Wait for it to be fully on and then you can start using it.
New Hard Reset / Factory Reset Method Using Odin3 Flasher:
In case you cannot put the Samsung Galaxy Tab 3 7.0 Into Recovery Mode for any reason, Or the Normal Hard Reset operation does not solve your problem, Then you can use this new method to Hard Reset the device so easy, This New Method will reprogram the User area, And it can solve many software errors too, Just follow the steps below:
- Download and Extract Samsung Galaxy Tab 3 7.0 Hard Reset File ( SM-T210 ' SM-T211 ).
- Download Odin3 flasher.
- Put your phone into Download Mode.
- Run Odin3.exe
- Click on CSC button and Select the Hard Reset file.
- Connect your phone to PC via USB cable, And wait until Odin3 detects the phone.
- Click on Start button and wait until the operation done.
- Now your Samsung Galaxy Tab 3 7.0 will be rebooted.
- Done.
Jun 02, 2016 | Samsung Tab Tablets & eReaders
How do i take a screen shot on my SM-T550?
Samsung Galaxy Tab A (Wi-Fi, SM-T550) - Taking a ...
? 0:59
https://www.youtube.com/watch?v=u7nPrI5BG10
Jun 4, 2015 - Uploaded by SPSN
Capturing a screen shot is quick and easy on your Samsung Galaxy Tab A.
Taking a Screenshot - Samsung Galaxy Tab A (Wi-Fi, SM ...
www.samsungsupport.com/spsn/detail.jsp?ctg_id=1280...id...
Taking a Screenshot - Samsung Galaxy Tab A (Wi-Fi, SM-T550). Capturing a screen shot is quick and easy on your Samsung Galaxy Tab A. facebook twitter.
Jan 14, 2016 | Tablets & eReaders
Problems with wifi staying connected and sitting right in front of wifi modem
They all say, for best results, don't set less than 3 ft. from the Wifi antenna.
Apr 03, 2015 | Samsung Galaxy Tab 3 7.0" - White...
How do I find an online manual for the keyboard cover made by Supernight for the Samsung Galaxy Note Pro 12.2?
Here you go.
http://downloadcenter.samsung.com/content/UM/201401/20140125112328617/SM-P900_UM_EU_Kitkat_Eng_D06_140124.pdf
Mar 03, 2015 | SUPERNIGHT Universal 11-12 Inch Tablet...
Tablets & eReaders Logo
53 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
