My old price pfister tub and shower valves are leaking
How to identify to get repair kit
blueextc3221
  • 15935 Answers
SOURCE: my price pfister tub valve leaks
there is an o-ring inside the valve that seals. It has failed. They should sell a rebuild kit where you bought it, or dis-assemble, and take the failed oring in to have it matched to a new one.
Posted on Dec 26, 2008
  • 152 Answers
SOURCE: Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Posted on Mar 26, 2009
  • 112 Answers
SOURCE: I have a price pfister
You have to turn water off to shower and remove handle then cartridge lock ring then there are two washers and srpings that can be popped out with small screwdriver.Lowe's has replacement springs and washers ,be sure to mark position cartridge was because that is very important to reinstall the same way it came out.
Posted on Jun 12, 2011
SOURCE: set water temp
remove the handle, find the plastic disk with teeth, pull out disk and turn to left for hot, right for cold, set disk back in place, then replace the handle, repeat as necessary.
Posted on Feb 22, 2012
  • 63 Answers
SOURCE: Price Pfister tub/shower facuet needs much force turn on and off
call 1-800- p- faucet get new diverter
Posted on Mar 03, 2013
The faucet drips constantly from a single handle tub. How do I fix this?
we would need a little more information but sounds like it will need replacement, The water will eat up the meatle and make a rebuild impossible sorry but no quick fix the hot water lineis usley the culprit
Aug 09, 2017 | Plumbing
How do i install tub/shower remodeling kit 9B-3H/C
while the wall is open is the time to replace the plumbing it's cheaper to do it know then in a few weeks when its all closed in $100 now or $500 later
Oct 14, 2012 | Price Pfister Verve Tub & Shower...
I have a price pfister a112.18.1 shower only (no tub), single-handle. It is leaking from the shower faucet. How do I repair?
Jun 09, 2011 | Price Pfister Plumbing
I have a rebuild kit 124166 price pfister shower diverter valve I replaced the packing and the 3/8 l flat washer and one red o-ring gasket, there is a white plastic gasket that i think goes somewhere (i...
The issue might be the tub diverter spout. Most such do not seal well. It is a matter of jiggling the spout knob. It should seal better with a little experimenting.
Aug 30, 2017 | Danco Home
Hot watwer leaks from the hot side of the facet
Replace the stem assembly (ceramic cartridge) with Price Pfister service part #910-030. Be sure to turn water on briefly to flush out any debris in the valve body before installing new part. NOTE: this valve does not like old galvanized plumbing.
May 21, 2010 | Price Pfister 01-31xa Shower Head, Tub...
Water leaks out of shower head during tub use. valve was installed properly
The pipe to the tub spout is either restricted or the valve was placedd too high causing some of the water to come up and out of the shower head instead of it all flowing out of the spout.
Nov 12, 2009 | Price Pfister R89-7PC0 Chrome Portland...
Good luck
Aduz
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
Swaping Pfister Shower leaver handle
it must be the same model number,most models come in different colors and styles.
Feb 27, 2009 | Price Pfister 01-111 Shower Head, Tub...
My price pfister tub valve leaks
Dec 26, 2008 | Price Pfister Ashfield Single Control...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
