The washing machine doesn't want to run . it says Clean Tube and control lock is on
  • 238 Answers
Hi Arthur!
"Clear tube" means that there is a blockage in the discharge pipe. The machine asks you to clean it.
Posted on May 18, 2017
5 Suggested Answers
  • 3740 Answers
SOURCE: my washing machine control locked light is on,
You did not provide a model number so I am winging here trying to help you;. If you have your users manual fgo to the child safety lock steps and unlock it following the instructions in your manual.
Posted on Jan 12, 2010
  • 5911 Answers
SOURCE: My Maytag front load washing machine's control
The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured front loader, the following link explains how to lock/unlock this feature:
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem). Please post back and let me know if you require additional assistance. I hope this helps you.
NOTE: Maytag Epic is manufactured by Whirlpool, so these instructions should apply.
Posted on Apr 28, 2010
SOURCE: unlock control lock in washing machine, whirlpool, duet
my whirlpool heaavy duty 9Kg is locked so I can't unlock it, I need help please
Posted on Aug 22, 2010
  • 389 Answers
SOURCE: door lock light keeps blinking; machine doesn't wash
try firmly pushing the door shut
Posted on Sep 27, 2012
I have a Panasonic washing machine. When i switch on, water could not flow into the washing machine's tub
Let's run through the basics first, is the supply tap on? Is the supply hose free of kinks? Is the inline filter in the supply hose clean?
If not those, does the door lock work also? If this doesn;t then it could be a faulty lock not letting anything happen as it thinks the door is open
Oct 16, 2014 | Washing Machines
Washing Machine not stopping water flow
in the back of the machine attached to the bowl is a small tube that goes up to the controller in the dash panel. This tube should be straight with no kinks or pinch points. This is pitote tube and conveys pressure to the controller diaphragm that connects to a micro switch that turns the water off and the machine on. As the water rises the air trapped in the tube increases in pressure and pushes on the diaphragm. Sometimes if there is water trapped in the tube it stops working You control the pressure that the diaphragm works at by the water level you select
Jun 10, 2013 | AEG Washing Machines
Our new integrated washing machine (Baumatic btwm4) sometimes doesn't spin properly and clothes are very wet. Even thought a single spin is selected, the same poor result. The machine is definitel
1) tes the belt for broken or worn replace
2)test the door switch, this cause to NOT spindle the machine , replace if necessary or readjust
3)Main control module or CCU, if the door switch test o.k, tight any wires connector well from loose, otherwise the CCU is faulty.
4) motor control module, this receive signal from CCU, tight any wires connector for loose, otherwise you must replace the board faulty.
Jul 18, 2012 | Washing Machines
Hotpoint Aquarius wf541 fabric conditioner compartment fills with water and doesn't drain out
There is a syphon tube with a cover dome like a thimble. Lift it off, clean it and clear the syphon tube. Refit the cover.
Apr 25, 2012 | Hotpoint Washing Machines
I am trying to figure out JW's code to deep clean LG WM2301
If you cannot do it that way then toss a packet of Tide washing machine cleaner in there witout clothes and do the clean cycle as prescribed in the owners manual.
Nov 01, 2011 | LG WM2301HW Front Load Washer
DE code, machine will not run. door working properly
DE indicates a door lock error.
Either the door lock, wiring or main control board can cause this fault. The door lock is relatively inexpensive so it would be worth trying a new door lock first.
Check the wiring between the door lock and the control board. If a new door lock doesn't fix it and the wiring is ok you are only left with the control board.
Hope this helps.
Aug 06, 2011 | LG WM2042 Front Load Washer
The washer will not stop filling up with water and spilling water on the floor unless manually stoped. Sometimes it spins and rings the clothes out and sometimes it doesn't . With either problem it...
Remove front of machine with putty knife/slide knife in at top of front on left and right u will see the tabs.. there is a pressure tube that attachs to tub on the left side remove tube. DONT BREAK OF THE *** it is most likly pluged use small wire to clean tube and the little *** that it gos on to// put tube back on (SPIN AND DRAIN MACHINE) test on all load sizes.. good luck thank you for voting.............................
May 21, 2011 | GE Washing Machines
Top-load washing machine wont stop filling. It is as if the machine does not know when the proper water level is reached. However, if I advance the knob, it will proceed into the wash cycle just fine...
There is a scensor in the controll panel it have a tube connect to it.
that is the level switch .
make sure that the tube is clean by taking it out and run water with bleach make sure the tube is not damage.
hook it up again and check the machine again if it solve the problem dont forget to rate me, if you still have a problem let me know we will work on it more...
Jan 12, 2010 | Washing Machines
Simpsom concorde 741 washing machine it does not switch of the water level at the level asked for
Unplug the machine from the power point. Open the top hatch, two screw under the lid (they normally have a plastic cap over them which pulls out). Also two nuts behind the machine, from memory they are a number 7 nut.
Gently lift up the top hatch. You will see a thin tube which runs from the side of the Drum/Tank up to the control panel. Remove tube (it has a spring loaded clip where it joins to the tank. Make sure the tube is not clogged or dirty inside. If it is you need to replace the tube.
If the tube is clean, blow into it. You will hear a clicking noise under the control panel, where the water level dial is. that is your pressure switch.
The pressure switch has an adjustment on it, but it is best not to tamper with it, as if you get it wrong, you will flood your house.
Make sure you refit the tube properly as well.
In most cases though the tube itself gets dirty and the air pressure does not rise up to the pressure switch properly.
Good luck
Oct 22, 2009 | Washing Machines
Dishes not washing clean
check water level in machine
may be not filling enough and the wash pump is starved from water thus not pushing water to upper arm
drain water from machine dismantle and clean out air tube to pressure switch take off air tube at pressure switch and blow back into sump then pinch air tube with fingers to stop air from flowing back up tube then refit to p/s
run and see if that solves problem
Feb 15, 2008 | Dishwashers
Washing Machines Logo
Top Washing Machines Experts
