Question about Equator EZ 3600 CEE Front Load Washer / Dryer
Won't let in cold water. set on delicate, it used
Won't let in cold water, only pure hot water.
I set on delicate, it used cotton cycle.
It moved cross-country and needs personal attention!
I Need someone in East Bay CA area.
  • 867 Answers
Remove cold water supply hose, if all is well and screens are clear , means cold water valve is faulty
Posted on Jul 25, 2009
I have just moved into an Apartment with a Gorenje wi 62112 Washing machine, I have no manual Can anyone tell me what the numbers on the Dial mean What should I choose for a general wash.
Gorenje has some documentation for their washers here: http://www.gorenje.com/simplicity/en/washing_machines/simple_manual_for_washing . The numbers indicate the water temperature (in Celsius) for a given cycle. The common choices are a cottons load in hot water (60 degrees). This is great for towels and other whites. The mixed load is for permanent press that can be in warm water (40 degrees). Then there is a cold water cycle for delicates (30 degrees). However, you should check the fabric care label before choosing the cycle.
I hope this helps.
Apr 20, 2016 | General Washing Machines
Kenmore Elite HE3 does not work with Pure Wash system
One of the things to try is get a Y connector for the machine. Hook both ends of the Y to the washer at the hot and cold, then connect the last part to the pure wash. The HF error is HOT FLOW so it is not seeing any hot water pressure. The actual temperature should not be an issue. Also if you have too much water pressure you wont see the bubbles. If that happens just start turning down the cold water valve on the connection to the pure water unit until you see bubbles in the viewing window. I ams sceptical about these machines because you have to reduce the surface tension of water in order for it to clean, that is partly the job of heated water and laundry soap. Also if there is an ozone generator in that unit, there is a consumable part because ozone needs electrolysis to be generated. I cant help but wonder where the hydrogen goes when it is generated.
Feb 26, 2014 | Kenmore Elite Washing Machines
Clothes in bosche washer gets tied up in knots in spin cycle
Are you running a load according to the care labels?? If you run delicate or easy care items on a cotton wash this can happen. Just because an item is 100% Cotton doesn't necessarily mean it will tolerate a cotton cycle check the care label. Also, if for example a cotton cycle is 6Kg, the easy care will be 3-4Kg, Delicate and woollens will be approx 2Kg. Overloading can cause items to knot during cycle. Finally, check that your inlet water is not too hot. Repost if you need any further assistance
Feb 19, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have an Omega CW 675-A washing machine and I have just moved in but the owner did not leave an instruction booklet for the settings. Is this a free service? Can you help me? Paul
Hi
The particular model number is not listed in the list of manuals of omega washing machine.Please call the customer support for assistance.However given bellow are some settings of the washing machine,which is extracted from a website.Hope it helps:-
7 is warm wash delicates (warm cycles then it runs through the number 10 delicate cold cycle too)
10 is cold wash delicates
1 is the longest regular cycle
I normally wash with only the cold tap on, 3 for dirty washes, 4 for regular washes.
Soap goes in the middle slot
3 Buttons from left to right
left - in to spray rinse
middle - in to NOT spin dry
right - in for NOT boost heat (or maybe it has no booster and it is just in for cold wash - not sure)
when standing in front of it, reaching over the back, the left connector is cold and the right connector is for hot water.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 09, 2011 | Washing Machines
I get a 3E error code or nf. My fill valves don't seem to be working properly. I get no water in my fabric softener cup. Fill is slow.
Hi
Thanks for using FixYa. Error NF means No Fill. The washer has tried to fill but was unsuccessful. NF indicates No Flow. There is something that is interrupting the inbound flow of water to the washer, either hot or cold. Sometimes this happens when water service in the area is interrupted, creating an air pocket that causing the water valve not to sense water.
Try running the diagnostic test by—
  • Press the delicates and heavy soil keys together for 3 seconds.
  • You are in the service mode.
  • Now, press wrinkle free key, cold water should start entering.
  • Then, press the cotton sturdy and hot water should flow.
  • To exit the test mode, either unplug the machine or press the delicate and heavy soil again for 3 seconds.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 12, 2010 | Maytag Washing Machines
LED is flashing nF. What does this indicate? Washer is a front load Maytag Neptune, mod# MAH 8700 AWW.
Hi
Thanks
Rylee
Aug 25, 2010 | Maytag Washing Machines
Best temperature and spin cycle setting to wash cottons !
White cottons-Hot wash/Cold Rinse /high spin sycle
Colored Cotton Cold/Wash/Cold Rinse/ high spin cycle
Aug 21, 2008 | Hoover Washing Machines
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Cycle stops, won't drain
This is either a bad timer or a bad heat sensor. On most cycles that call for the water to be heated it will pause the timer and continue washing/heating until the sensor is satisfied the water is hot enough. Try selecting a quick, delicate, or china cycle without heated rinse or dry. If it works this way the timer is fine but the sensor is bad. Sometimes cold water to the machine will cause this problem because the machine is not capable of totallly heating cold water. It is only designed to boost the temp. Make sure you run hot water at the sink before you start the machine.
Jul 03, 2008 | GE Nautilus 24" Built-in Dishwasher
Equator EZ 3600 CEE Front Load Washer / Dryer Logo
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
isaac johny
isaac johny
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
