Question about Indesit Dryers
My indesit washer dryer is not drying, it seems to get stuck on 1 minute left and now the clothes arent drying
SOURCE: runs program but stops on 1 minute left and needs resetting each time
Did you manage to solve the problem with your dishwasher. I have the same model and it keeps sticking on 1 minute at the end of the cycle. Any advice please?
Posted on Sep 30, 2007
  • 240 Answers
SOURCE: Sears Dryer 417.80042990
What is happening here, is that the front bering (the area between the front and the drum) has become worn. Its not a very expensive or time consuming job really. Remove the top, then remove the front. You will tilt down the front and door assembly. Dont worry about the drum falling out, Frigidaire uses a ball and hitch rear bering that will hold it in place. On the very top of the door opening indise the front cover (where the drum rides on that felt) you should see a felt like covering with like 4 or 5 plastic type drum glides. Replace the top half of this felt with those plastic glides attached (should be attached). Just re-glue the felt to the drum (glue should come with part, and watch it, this glue is for real if you get it on you). If you wanted to be a real explorer, its always a good idea the lube or grease the rear bering of these Frigidaire's while your this far into it. If you want to, just remove the belt (remembering how it went back on the idler pully), then, with two towels around your hands, grasp the drum at around the 10 o'clock position and tug upwards to remove the drum from the rear bering. Also be sure to remove the drum upper support (yellow looking clip thing front center that will hold the drum until you remove it). Use a good quality-high temp grease inside the bering and the ball on the back of the drum. This will ensure you wont have to go back in there again normally for the rest of your dryers lifetime. Enclosed a picture of the front bering glides and felt:
And a small break down of the front section. Your part will be #20 that you will be replacing.
Let me know if you need any further assistance or have any other concerns or needs. Good Luck!!!! Jim
Posted on Dec 06, 2007
  • 734 Answers
SOURCE: Frigidaire AEQ8000 dryer doesn't completely dry clothes
1. Gas valve coilsIgniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Dec 02, 2008
  • 2651 Answers
SOURCE: Haier HWD1000 washer/drye
please repost for i have no knowledge of the haier productline
Posted on Jan 31, 2009
SOURCE: my indesit widl126s
i cant get the dryer to work i have followed all the instructions
Posted on Mar 18, 2009
What to do with F13 error indicator on my indesit washing machine please.
Dryer temperature sensing fault (washer dryers only)
Issue: Washer dryer is not drying clothes.
Advice: We recommend you call our customer service centre to book an engineer on: 0344 822 4224
Mar 31, 2017 | Indesit Washing Machines
2009 Kenmore Dryer. Wondering why it seems to only work on 1 drying cycle? Everytime I try to put it on another cycle all the lights flash and beep...and nothing...
sounds like the washer might not be spinning the water out of the clothes good enough . 1 60 minute cycle should dry them more than dry enough .
Oct 18, 2015 | Kenmore 8804 5.8 cu. ft. Electric Dryer
How to fix Miele WT2670. No issue in doing the wash, but when it comes to drying, it seems to be stuck in the last 12 minutes . Then eventually the machine stops, but the clothes are still not dry
perhaps the timer has gone bad many times the washer does not spin out as fast as they should thereby making the dryer work even harder to dry the clothe completely .
Apr 06, 2015 | Miele Washing Machines
Washer dryer not drying properly
the heating element of you dryer broken already
Feb 03, 2014 | Indesit Washing Machines
Can you please help me, I bought a brand new indesit washer-dryer machine, but when I take off the clothes, they are not white or colorful anymore, darker, like yellowish-brownish and the colorful clothes...
1. did you read the manual?
2. did you run a trial initial full cycle without clothes?
3. remember some factory stuff in the machine must have discolored your load. Now run a dry cycle again and try the same load.
Aug 05, 2013 | Dryers
My Indesit WIDL126 washer/dryer doesn't dry clothes
You have an air flow problem. This usually happens when the exhaust pipe/vent gets clogged. Clean/inspect the vent outlet, the pipe, the inlet, and the filter/lint catcher area.
Improper air flow prevents the moisture from being vented out of the dryer.
Sep 26, 2009 | Washing Machines
Tumble dryer not working
May 22, 2009 | Indesit W 123 Front Load Washer
LG WD-324RHD stops at 6 minutes left in drying
Your timer has gone bad and you need to replace the time. Best bet is to get a Technician out there but you can do it yoursel. It is behind the face plate where it counts down the time
Feb 09, 2009 | LG WD-3243RHD Front Load Washer / Dryer
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Indesit Washer/ Dryer 1200
A lot of times when people move they find their dryer has suddenly stopped working. Check the voltage at the outlet, make sure it matches the voltage on the i.d. plate on the appliance. I know people who didn't want to fuss with it and bought a new dryer only to find it did the same thing.
Mar 15, 2008 | Dryers
Dryers Logo
26 people viewed this question
Top Indesit Dryers Experts
Tim Whalen
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
