Question about Home
Why is water coming out of the small pipe where you connect your hose when the shower is switched on and being used?
    Top Expert:
  • Home Master
  • 39,229 Answers
The connection is leaking
Posted on May 18, 2017
Any chance for repair? Had a very unusual artic front come down here and it apparently froze up in the unit.
Open up the shower head so its open put heat it to room to help defrost lines . Or use a blow lamp on line to defrost or use heat tape
Jan 18, 2018 | Refrigerators
My mx inspiration lxl as a leak from the overflow pipe behind the shower hose it only leaks when turned on this only happened when I changed the shower hose I had to take the shower cover off to do yhis
u need to change the Black Leather Circle, it comes between the shower hose and the pipe!! also check the shower hose from inside you may find some small stones and sands inside!!! i had this before and fixed it the exact same way i told you :)
Jun 08, 2014 | Home
When i put my shower on theres water pouring out of the small pipe at the base of the shower behind the shower hose
sounds like you are missing the black rubber washer remove the hose from the shower arm see if its missing or crushed inside of the fixture.
Jul 02, 2012 | Home
Water coming out of small pipe next to water outlet to shower head whats the cause
its the overflow, you need to clean/descale the shower head/pipe,or have it serviced
Sep 25, 2011 | Home
Water comes out pipe in bottom of shower not from shower head
There is a little rubber O-ring seal inside the connection from the shower hose to the shower unit, Check this is now missing and if it is you will have to find a replacement.
Jul 21, 2011 | Computers & Internet
Ahhh... I bought an older condo and I have a bathtub/shower. The shower head is mounted on the wall and a switch at the faucet switches between the shower and the tub. The problem? When I switch from tub...
Normally the diverter in the spout does just that. It's basically just a little door you pull up to stop water from flowing out the outlet to bathtub, and it diverts water to shower head as it has no where else to go, as the door has been shut. Think of a "T", if you have water coming in, it's going to go out both openings if nothing stopping them, and they are at same level, but when you plug lower one, the water flows up and out the other. My guess is your getting very little pressure from head when it's still coming out at tub.
NOTE: before attempting this, make sure you incoming water supply to house is shut off at valve. Anyway, those spouts are usually held on by a set screw up under bottom side of faucet near back of it, (close to tub) there should be a small slot which will probably be an allen head or philips. You back that screw out, then twist and pull and it should slide off of copper pipe. If no indication under there of a set screw then there are also those that just thread on, which requires you just turn faucet counterclockwise to remove. Replace entire piece all in one, and be done with it. Most hardware or home centers will sell just that separate. Make sure you get the one with diverter. (handle that you pull.) Clean pipe well with steel wool if it's dirty and corroded before sliding new one on, and wipe some "vaseline" on pipe to help and protect "O" ring inside spout. Slide new on on all the way and tighten set screw on underside. If threaded, clean threads, add pipe dope or teflon tape and thread it on until aligned and tight. Good Luck.
Jan 28, 2011 | Home
Connected shower head to hose and the hose connection to shower head leaks back toward line. There is a white end over the inside of the end of the hose. I believe this restriction is causing the line to...
I understand that the white vac breaker end should be connected to the valve not the hand shower. FYI a little leak from this connection when the water is switched off is normal.
Sep 27, 2010 | Water Pik Shower Head
Kohler shower hose leak
If the problem is solely because of the rubber washer with screen you can buy any cheap replica hose and use the washer that comes with it. If the issue goes away you are done. If not, switch heads and see if the issue follows the head. If it does then there would be a crack in the head at the connection. If neither solves the issue then you must buy a new hose.
Apr 15, 2010 | Home
Water pressure to main hose has ceased, with water now pouring out of a small outlet pipe at bottom of unit next to fixing for main hose.
Sounds like your outlet at the top has clogged with grit/dirt. Turn the shower off, remover the entire shower head hose from its base (where it screws into the wall or pipe. Turn water back on. If you get a steady flow (as you should) the problem is isolated to the shower head/hose. Detach the shower head from the hose and clean the screen inside, attach hose back on first, try water again, if this flows then your blockage is in the head itself. After removing and cleaning the screen inside the shower head, reattach and run water, this should fix your problem, if not, you may need a new shower head. If the water will not flow to the outlet pipe alone, either your shower switch is broken or you have a serious plumbing problem.
Apr 16, 2009 | Home
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
