Question about Tablets & eReaders
Screen mirroring stopped working, will not work with phone or tablet, no picture
How do you enable the HDMI feature on nextbook Ares 10A android tablet
By default it is enabled already. If you are trying to connect your nextbook to a TV, try this: To link to the television, simply plug the HDMI cable into the tablet and then into the TV's HDMI port. Following the connection, a HDMI notification pop-up will show on the Nextbook's screen. Select it and choose to mirror content displayed on the Nextbook screen. Next, make sure the TV is set to HDMI input, and what's on the tablet should be mirrored on the television.
Feb 07, 2017 | Nextbook Tablets & eReaders
Can I connect my Tablet to my tv with a USB cable to watch videos or play games?
Only if the tablet supports hdmi out. Usually via the usb port or a dedicated mini hdmi port. Check the owners manual or Google the specs for your tablet. If it doesn't you can mirror your tablet however to do so you either need a wifi enabled tv that supports mirroring or a dongle like roku, chrome cast etc. with mirroring capabilities.
Nov 14, 2016 | Tablets & eReaders
I dropped it and although the screen isn't physically broken, it's not working properly.
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - Is your Android Touch Screen not working or being unresponsive? ...This will wipe your phone/tablet and return it to its original condition. ... a replacement for a glass broken? will I not reboot my phone and then it will work? .... My zenfone5 was dropped into water and some part of the screen isn't working.
iPhone Screen Not Responding - how to fix? - Tech-addict
www.the-tech-addict.com/iphone-touch-screen-not-working/
Nov 22, 2015 - Although the touch screen problem doesn't occur that easy, but still one can come ... Steps to fix if your iPhone Touch Screen not working properly ... to perform a factory reset i.e. restore your iPhone to its original factory settings. ... Touchscreen devices like iPhone, iPad, Tablets etc. are not only quite costly ...
Dropped phone, screen doesn't work. What repair kit do I need ...
forums.androidcentral.com > ... > Samsung Galaxy S3 > Sprint Galaxy S3
Sep 11, 2013 - When I try the unlock pattern on teh touch screen it does not work. ...the glass there does appear to be a spot that isn't the glass that is physically broken.... And I'm pretty sure once you get the phone disassembled, its just plug and ....Although I only had to do 1/3 of what was in them, they really are great for ...
How do I get my pictures off my phone if I have a broke screen ...
Mar 10, 2014
Brand new Galaxy S4 "broken" for no reason.
Aug 12, 2013
Does the digitizer break when screen is cracked on the Nexus 7 ...
Aug 3, 2013
TF700T now won't turn on.
Oct 15, 2012
More results from forums.androidcentral.com
Feb 03, 2016 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
I crack the screen on my ematic tablet an it won't unlock how do I fix it
I'm afraid, till you have another screen it wont work correct again. Goto a phone / tablet repair stop and ask them what it will cost you if they replace the screen. If you like the price they are asking, use their service. If it is to expansive, start saving for a new tablet. and perhaps a screen protector too?
Oct 31, 2014 | Tablets & eReaders
Nobis tablet turns off and on but all else does not work...no screen with app..states everything has stopped working
Sounds like you have some type of software corruption. What I'd do is try to factory reset the device. This will wipe the tablet, but at least you'll have it working again!
To factory reset your phone, Just follow this simple steps below: *Turn off your Tablet *Press and hold Power key and Volume down key at the same time *Release the keys when the recovery mode appears, then navigate using volume up key to Wipe All user data and use the power key to select that option *Wait for a DONE message that will appear in your phone. *Then restart your phone using the power key. Done!
Apr 22, 2014 | Nabi 2
Black Screen no battery picture
If you are having this problem with the tablet, but the charger works fine with the cellphone, then mKe sure that you are using the right charger for the tablet, or it could be that the charging port in the tablet is damage, or the battery needs to be replace.
Mar 20, 2014 | ASUS MeMO Pad HD 7
Screen rotates, pen doesn't
Is it maybe possible it is a hardware prob? maybe the directional sensor in the tablet was displadced.
BTW i have the same tablet and need an harddrive replacement/upgrade, how did you manage to do that? what kind of drive and where to buy? Viewsonic seems not so eager to help me out with that.
Best,
Fredrik
Apr 25, 2007 | ViewSonic Tablet PC V1100
Tablets & eReaders Logo
53 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
