Question about Air Tools & Compressors
Red flashing light on paslode nailer - Air Tools & Compressors
  • 7 Answers
SOURCE: paslode not working
Hi, the fan blade may be jammed. This can occur when blade is bent. I dont know why they bend but you need to remove fan from housing & straignten fins with pliers (gently), until they are correct angle.
Cheers
Lance
Posted on Nov 01, 2008
rowdy45176
  • 2176 Answers
SOURCE: Need cleaning instructions for ITW Paslode Impulse
I would recommend you go to Paslode.com and under support there is a section for cleaning of these tools. I can tell you how to do it but it is indepth. What kind of cleaning solution do you have? You can't just use anything to clean them. Also the red light on means a failure. Does the fan work? Does it have fire and it also means that the battery is weak. They also have a good troubleshooting section on the site. Let me know if I can help further.
Posted on Feb 17, 2009
lester482529
  • 226 Answers
SOURCE: Paslode 5350/90S PM Powermaster Bends nails over
USUALY THIS IS CAUSED BY TO LOW OF AIR PRESSURE(NEED AT LEAST90-100PSI)OR NAILING INTO SEASONED HARD WOOD SUCH AS OAK,OR THE WRONG DEGREE PITCH OF THE COLLIATED NAILSHOPE THIS HELP'S.PLEASE RATE THIS .
Posted on May 23, 2009
smartr10U
  • 1305 Answers
SOURCE: paslode im350 has indicator light flashing red/green
The nailer’s electrical system has gone into overload protection. There may be something wrong with the fan motor or the wires going to the fan motor. Remove the cap and grill to inspect the red and black fan motor wires. If the wires are pinched or broken, that may be the problem. It may also help to disconnect the small white connector on the wire assembly that goes to the motor and then reconnect it.
Posted on Jun 23, 2009
  • 131 Answers
SOURCE: Paslode 900420 nailer green light cycles doesn't stop???
Sounds like you need a new circut assembly.
Around 40 bucks.
Thanks,
Jeff
Battry charged but red light on gun still flashes on im 250
The red light flashing on the gun means that the battery does not have enough voltage to operate the tool. Try another battery and if it still flashes red you need to replace the spark unit
Aug 25, 2012 | RTO Paslode 902000 IM250 Ii Cordless 16...
When the trigger is pressed the light on the handle flashes green and red intermittently and nothing else happens. any ideas?
Hi,I believe that is a battery issue...either it is run down or not charging properly...
Here is a tip that I wrote about the Paslodenailers and the problems that can come up with them.
I also have a link to the Paslodemanuals which contain Paslodecleaning and troubleshooting guides.
If you need parts for your Paslode,there also is a link for a site that sells the Paslode nailer parts.
PaslodeCordless Nailer Problemsheatman101
Sep 18, 2011 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode 350 nailer wont work , push to fire fan works for 2 seconds then light flashes from green to red
Sounds like a battery contact problem or a bad battery..
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Feb 17, 2011 | Dewalt D55141FNBN HeavyDuty 16Gauge Finish...
IM350 when battery inserted flashes green then goes to red. Tried battery in other gun and works ok. Tried full charged battery (green in other gun) and led goes red in this one. Measured voltage at 6.74v....
Check the battery contacts in the gun...
heatman101
Feb 05, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Red light stays on as if battery is flat.
Check battery contacts...
heatman101
Dec 12, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Flashing green and red light by the trigger ,what does it mean
heatman101
0-
Oct 29, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Red light comes on
heatman101
Oct 26, 2010 | RTO PasLode 900420 Impulse Framing Nailer
My IM65 light flashes green then red, fan seems to be working and the gun does fire
heatman101
Aug 30, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
My im65 palode has stopped working,the red and green light if flashing,What could be wrong?
heatman101
May 14, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Air Tools & Compressors Logo
56 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
