Want to know about fashion consult anemie carpenter
    Top Expert:
  • Computers & ... Master
  • 15,427 Answers
Google her or do online search
Posted on May 18, 2017
Where to oil Singer fashion model 1036
Consult your owner's manual and oil according to the instructions. Use only fresh oil recommended by the manufacturer and apply 1-2 drops each place specified in the manual. Over-oiling or oiling in the wrong place can damage the machine.
You can find an owner's manual here:
http://www.manualsdir.com/manuals/719169/singer-1036-creative-touch-1036.html?page=57
Page 57 states that the machine does not require oiling, but based on it's age, I'll bet it could use some oil. With older mechanical machines, I generally recommend using ONLY fresh good quality sewing machine oil. (BTW, the top of your machine should open.) Then I hand rotate the handwheel slowly toward yourself, watch where metal rubs on metal and apply 1-2 drops of oil. If you can find oil ports, they could probably use a drop or two also. Do NOT oil plastic gears, cams or belts. Be sure to oil the moving parts inside the free arm too. And, move the selectors/levers, watch where they move and apply 1-2 drops (just avoid the plastic parts). A common oiling point on most machines, including the newer computerized versions, remove the bobbin shuttle, apply a drop to the outer edge of the shuttle and lightly spread it around the edge.
FWIW, I did read somewhere that the plastic gears and belt tend to be the weak points on these machines (which is common for a lot of machines from this period) and that it could be an expensive repair.
Hope this helps.
Jan 20, 2016 | Singer Sewing Machines
Need pedestal stand for grundig gu37fhd 1080
It may be almost impossible to find such a stand. I suspect that it was hung on a wall and then the original stand was discarded. You might try grundig customer service. I would also suggest exploring other options like rehanging the TV or having a carpenter fashion a replacement stand from wood.
Jan 01, 2015 | Grundig Televison & Video
How do you calibrate and Abney Hand Level? The one I have is a CST/Berger 17-645.
You need a carpenters level longer than the Abney level. Find a smooth flat level surface like a table with the carpenters level. Double check the carpenters level by turning it 180 degrees and see if it still shows level. If it doesn't get another carpenters level. Set the Abney level at zero and lay it on the carpenters level or the flat table. The bubble should center on the index line. There is usually two screws that allow you to move the glass tube (and the index at the same time) to center the bubble and index if it is off. Then check your findings. Put a piece of contrasting tape on a wall at eye level. Walk back 20 or 30 feet and see what the angle reading on the Abney level shows. If you keep your feet in the same position; that is your eye at the same level, you should read zero.
Oct 28, 2013 | Sokkia Abney Level with Clinometer 804710
Which place is good for buy Sliding doors and windows ?
There will be a window door manufacturing business in or close to your town . Check the local directory for this or go on the net and search for window/door manufactures.. Reputable companies will come to your premises and measure the openings and make the items to fit exactly.. Most hard ware shops only sell standard sizes which seldom fit properly as most doors and windows vary during construction.
Oct 26, 2013 | Cars & Trucks
What is a Carpenters axe?
A carpenter's axe is a small axe, usually slightly larger than a hatchet, used in traditional woodwork, joinery and log-building. The poll is designed for use as a hammer.
Feb 03, 2013 | Garden
Where is the ground located
The ground wire, typically black in color, is always attached directly to the chassis of the car itself in some manner, either with a ground loop attachment or an O-washer in some fashion. It must be grounded to the vehicle. ------------------------------------------------------------------------------------------
Nissan Consult 3
Jan 22, 2013 | 2001 Chrysler PT Cruiser
I need a baby boy name combing our names ariane and michael
Suggestions: LARI, MICHARI, AELARI, ARMICH, ANEMI, ANEMICHA -many more possible.
Jun 28, 2011 | ArcMedia ABC of Baby Names
I want carpenter to put a wood door
You'll have to advertise elsewhere if you want someone to install a wooden door into a framed opening. We're not allowed to take money for work done on this web site.
Oct 01, 2009 | Measuring Tools & Sensors
Computers & Internet Logo
132 people viewed this question
David Payne
David Payne
