Question about Uniden Lands Phones
Sometimes our outgoing signal is weak, sometimes we can't be heard at all. This problem happens on all the handsets, including the base station The phone is new and has never worked properly, other phone operate well. Even tried different cables and jacks.
    Sergeant:
  • 277 Answers
Wellcome,you need to change the phone panel to another one,because the one inside may not be original.
Posted on Jul 25, 2009
Deregister AT&T SL82118 handset
The following is for the model ATT 5830.
Enter the following sequence on the base station including the * symbols.
**335782
This will deregister all handsets associated with that base station. Handsets can then be added back into the system by entering the base station ID into the handsets one by one. The base station ID is on the bottom of the base station itself.
Feb 06, 2014 | AT&T 5830 Cordless Phone
I have a Uniden cordless phone #D2CT 6.0--I love the phone but the party on the other end of the line can barely hear me -how can I fix this or this a bad phone???
At 20 ft line of sight, you should have perfect reception with most any cordless phone.
The fuzzy signal can indicate:
1.
A weak signal between base and handset.
20 ft line of sight should have a good strong signal.
Your handset may be defective.
Or, your handset battery may be weak.
Your base unit may be defective.
2.
You may be experiencing RFI Interference.
Is the base unit next to any other electronic devices?
If it is next to a wireless router or some other wireless device, it may be overloaded by the nearby signal (even if on a different frequency)
I've got a 5 year old Panasonic 5.8 Ghz cordless phone connected to my VoIP box. I just tested it from about 25 ft away from the base unit in another room with a wall in between and my reception is perfect.
I did the same test with my Panasonic DECT 6.0 phones (1.9 GHz). The first handset is slightly fuzzy, but otherwise good signal. The 2nd handset was perfectly quiet with good strong signal. So, there is a difference between two identical handsets connected to the same base unit. This indicates to me that one handset is better tuned than the other. Nothing I can do about that but get a new 2nd extension cordless handset. Sometimes, it's just luck of the draw
Feb 15, 2011 | Uniden DECT 6.0 Cordless Phone ID
I have the DECT1580 cordless phone with 4 handsets. Lately, people cannot hear me when I call them. Sometimes it cuts in and out. It's happening with more than one of the handsets. Help.
Weak or Hard to Hear Audio (From the Uniden Manual)
If the caller’s voice sounds weak or soft, the signal might be blocked by large metal objects or walls; you might also
be too far from the base, or the handset’s battery may be weak.
  1. Try adjusting the volume of the earpiece (see page 36) or the audio tone
  2. Try moving around while you’re on a call or moving closer to the base to see if the sound gets louder.
  3. Make sure the handset’s battery is fully charged.
Jan 04, 2010 | Uniden DECT 6.0 Cordless Telephone...
I can hear, but not talk, on my ATS RA2184BB cordless phone.
Have you tried unplugging your base station and all the handsets?
Sometimes the base station, where the power and the telephone line plugs into needs a reset. Just like a computer sometimes it needs a reboot.
If problem presists, take a regular analog phone and plug it in to the same jack as the cordless phone bas station, and see if it is a cable issue/ telephone company issue.
Mar 19, 2009 | Lands Phones
Vtech cordless phone appears to be mute
Try the "hard reboot". /1/ Unplug power from base station. /2/ Disconnect battery in each handset. /3/ Wait a few minutes. /4/ Reconnect battery. /5/ Re-plug-in power to base station. /6/ Place handset in base station, and wait a few minutes for it to recover.
You may have to reset time/date and/or the handset ##.
Aug 24, 2008 | Vtech 9009111 Cordless Phone
Connection between two phones
There might be two problem....1st of programming and 2nd one of internal hardware problem of your handset which is not working.
For the 1st option- Read manual carefully, there is security setting. Follow the steps with second one handset which is not responding.( I can assum that it is power on but not responding to signals..May i right?) After completing security process it will give long beep and will bond with other one and that is necessary for frequiency adjustment. This generally occures after removal of batteries.
For the 2nd option- There is crystal inside your handset which is resposible for generat stable and similar frequency as other handset. When that crystal lost its capacity it results in mismatching of frequency and occures in non connection results in no response from handset. This can be repaired by technician after getting part no of that crytal from your device and replace it with another one. But for this you have to visit technician with all of handsets and attachment as it is necessary to check it working properly after repair, even technician may also need it for setting frequency level.
Is it clears all doubt about this problem then say FIXYA......
Jan 09, 2008 | Siemens Gigaset 8800 Cordless Expansion...
Phone rings, but once answered its not possible to hear a voice.
Similar issue - brand new phone - but incoming calls (skype or landline) would ring - and then nothing, and outgoing calls the handset would just reset.
The handset would just lose signal constantly (less than 2 meters from the base station).
The phone shipped with the latest software - but eventually I reinstalled it - no change, then de-registered the handset, powered everything down and re-registered the handset and that *seems* to have done it .....
So
1 - reflash / re-install latest software from philips website (even if the phone already has the same version)
2 - de-register handset (follow instructions)
3 - unplug base station and remove batteries from handset
4 - turn on base station, put batteries in handset
5 - re register handset (follow instructions in manual)
and that seems to do it.
Nov 18, 2007 | Philips VOIP8411B/37 IP Phone
My Motorola MA580 sometimes work and others don´t
It sounds as if the channel that the phone and base has selected during that session is bad, or being used by another system in the area. When that happens, try selecting another channel. You should be able to do this by depressing a button on the handset. Normally labeled "Channel". Please post further questions or comments. Please rate this solution through fix-it. Thank you
Jun 28, 2007 | Motorola Mobility MA580 (612572111116)...
Lands Phones Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
