Question about Coffee Makers & Espresso Machines
Hi I have a mellerware 3in 1 coffee bar and the espresso strength control knob won't turn. What can I do? Thanks
  • 2039 Answers
SOURCE: Coffee tastes burnt/No steam for froth
so i guess our expresso you dont have that creamy topping that lack pressure descalcify not with vinegar remove caicium in chunks have a chance of blocking everything descalcifier solution melt the calcium 1part solution 1 part water fill the water with solution open the valve if some come out close it leave the solution in it for 15 minute repeat untill empty rinse very good cheers
Posted on Feb 03, 2008
  • 40 Answers
SOURCE: Saeco Incanto Classic Espresso Machine Saeco
Do you get coffee? If it is just no water/steam, could be a blockge in the steam wand, or blockage in water lines. First test easy one - the steam wand. If the steam wand is o.k- then check for blockages in water lines/components ( pump, boiler, steam boiler). If you do not feel confortable with testing all the untis where water flows, contact Saeco USA Inc. to locate a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 20, 2008
EsWorld
  • 1618 Answers
SOURCE: What are the different settings on coffee machine power knob for?
On other machines with the position switches, 2 turns on the whole machine (elements heatup and groups work). Position 1 turns on only the groups but the machine never heats up. I have never worked on an azkoyen, but the test switch could be for the the board and the autofill circuits, instead of the technician turning the machine to 1 to test those functions, they provided a test position on the switch.
Posted on May 22, 2009
  • 7 Answers
SOURCE: How much coffee?
Fill it as full as you can with fine ground coffee. I cut the resulting brew with an equal amount of boiling water. Called an "Americano" in Italy.
Posted on Jul 17, 2009
  • 39 Answers
SOURCE: espresso function problem Krups XP2070
Most likely it starts the espresso but stops after a few second because the unit is not getting the water flow information or the unit is blocked. You will know that you have a blockage because not water will come out of the espresso filter but most likely you get some liquid during the 4-10 seconds it operates. My unit has the same problem and I fixed by getting a new flow meter. This unit is installed after the water tank and has wires (3) going to the the power module.
Posted on Dec 29, 2009
MANUAL FOR THE MELLERWARE IMPERIA COFFE MACHINE. ANY HELP PLEASE!!!!!
I got this from manualsonline, it is the manufacturer's manual library, it lists by model number which you haven't provided, I the correct one there ? (I doubt it)
http://www.mellerware.co.za/media/instruction-manuals/
I also found this the manuals link are towards the bottom, it's for the Taurus Imperia Coffee machine
http://www.coffeemachinemanual.com/taurus-imperia
2.June.2014
Jun 02, 2014 | Coffee Makers & Espresso Machines
Coffee bean light won't go out when full and coffee won't work
Hi coffee friend I have just answered this question. I think
After you have done all the cleaning you have done, you can try this: do check that all knobs correctly set. That the steam spout is closed. that the water tank sitter correctly
Disconnect from power, wait 2-3minutes connect again and hope for the best.
Kolbrun
Apr 16, 2012 | Solis Palazzo Espresso Machine
I have a Incanto Classic. I put in whole beans and it brew the first shot without a problem (the puck formed after) . I have since tried it again and no espresso (liquid) comes out. The grinds were...
Hi
The small knob in the bean hopper is set to the max or + side. Turn the small knob back 1 mark and try again.
http://www.fixya.com/support/r3658318-superautomatic_not_make_espresso_dumps
Sep 19, 2011 | Saeco Incanto Classic Espresso Machine
No coffee coming out. i hear it grinds but no water coming out. i primed but to no avail. i do get ground dry beans in the resovoir
Hi
Turn your small knob down in the bean hopper. You are putting to much coffee in the brw unit. The + / - knob has to be turned down 1 mark or click.
Nov 26, 2010 | Saeco Vienna De Luxe Espresso Machine
Cleaning of saeco royal cappucino machine
The user manual shows you how to clean your machine. If you don't have it you can download it from the Saeco site:
http://www.saeco-usa.com/en/products/household-automatic-machines/1/automatic/0/royal-coffee-bar/17/royal-coffee-bar.html
Hope that helped! Thanks for using FixYa.
Apr 09, 2010 | Saeco Royal Cappuccino Espresso Machine
Coffee is not strong enough?
Hi
There are 2 knobs in the bean hopper. Turn the small one to the + then back up 1 click. Turn the large knob to a smaller number, but only when it is grinding. The grind should look like coarse granulated sugar. It takes 3 cycles for the grind to take effect.
Jan 12, 2010 | Gaggia Syncrony Compact Digital Espresso...
Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
The steam knob only turns 1/4 turn to left
Hi
!/4 turn is all the Magic and Royal machines will do. Don't try to turn it farther or you could break the steam valve.
Dec 26, 2008 | Saeco Royal Digital Plus Coffee...
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
