Question about LG Televison & Video
LG 55LH90-UB LED TV I have an LG 55LH90-UB LED tv that has, what seems to be, sections of dim areas.
The bottom half of the tv is dim, and an area on the upper half about 4 in by 6in wide of dim area as well. From watching some videos, the only things I can come up with is a bad inverter board or bad LED strips. I ordered an inverter board with part # 6917L-0013C which is - i hope - a next revision of the board. It was cheap so no big deal. Any thoughts? The picture doesn't change, and viewing the tv is fine for the most part just dim.
    New Friend:
  • 46 Answers
Hi ,
try swapping the screen with another one to just see if it is behaving the same, because some times the screen circuitry or the led screen could be damaged .
good luck buddy
Posted on May 18, 2017
  • 3 more comments
  • Mike Grieshop
    Mike Grieshop May 18, 2017
    The display itself is fine. Its the lighting.
  • Daniel Augo
    Daniel Augo May 18, 2017
    if so you have to look for the right, same original card .
  • Mike Grieshop
    Yea I see that I ordered one for 47" models. Do you think its a board issue or LED light strip issue?
  • Daniel Augo
    Daniel Augo May 23, 2017
    Hi,again. yes it could be a board issue e.g Voltages going to the light strip are wrong . lastly screen has gone bad .
  • Anonymous May 23, 2017
    It was the inverter backlight board. Replaced now all is working. Thank you!
5 Suggested Answers
SOURCE: We just bought a 55LH90 LG LED tv. Our directv
I used my directv remote to access the setup and was guided through the steps to make my directv remote the "do everything" remote.
Posted on Nov 03, 2009
  • 630 Answers
SOURCE: Picture is larger than display area
Check the aspect ratio settings you may have it set to 14:9 movie expand
Posted on Jan 30, 2010
SOURCE: big screen tv, got wet
my celing was leaking like it was raining out side, but my son ran some bath water and for got he turn the water on and left it ran all over the floor, and i'm down stairs watching the water come down full speed on my big scren tv,i tried drying the tv with a floor heater from front to back wake up the next morning tv still dosen't come on.. what can be the problems,............... please you can reach me at i really ned to no i love my tv
Posted on Oct 21, 2010
  • 4889 Answers
SOURCE: right side of samsung ln52a580p
This is not an issue with the main board . Its a clear case of faulty LCD controller board or the LCD panel itself is faulty(most likely). I suppose the sound is not affected?
Posted on Feb 15, 2011
Why did the display of my LG 32LN5300-UB go BLACK?
Even the LG techinician can't give you no more information abut this fault. If you have any doubt; ask them. Poor fellow, you choose this brand TV.
Dec 28, 2015 | LG 32LN5300 32" LED TV 1920x1080, 60 Hz,...
Lg tv does not turn on
The 55lh90 has a vacation switch on the bottom right corner. It's a toggle switch that interrupts power to the power supply. Should just need to toggle that switch to the "on" position, and everything should be back to normal.
Dec 12, 2011 | LG 55LH90 55 in. LCD HDTV
Monitor dims when we turn lights off in room.
You need to give a more detailed description of the problem.
The LG 47LH90 is an LED backlit TV with 'local dimming' technology. This means that there are lots of white LEDs behind the screen and these can be controlled in groups to allow localised areas of the screen to be dimmed to produce better contrast between light and dark. It is very likely that when the room is dark, this local dimming is more noticeable. The actual individual LEDs cannot be controlled and so the area that is dimmed will generally be greater than the area that is required to be dark 'blooming effect'. In addition, LED backlit displays only maintain their contrast through a tight viewing angle. If you sit too farto the right or left, then light from non-dimmed LEDs will leak through and the screen will look lighter.
In short, there may not be any fault with your TV.
Jul 12, 2011 | LG 47LH90 47 in. HDTV LCD
LG 55LH90 TV to Sherwood RD6500 receiver
That's what manuals are for.
Video Out on the receiver goes to Video In on the TV. That's all you really need.
I recmmend you grab any TV-related audio from wherever its source is for the highest fidelity sound (NOT the TV).
Apr 18, 2010 | Sherwood RD-6500 Receiver
I have lg 90lh led tv, how do i get audio out om
Make sure ur audio output is variale out,not Fix input out.Use a HDMI cable instead of RCA AV Cable.
Jan 12, 2010 | LG 55LH90 55 in. LCD HDTV
Nov 02, 2009 | LG 55LH90 55 in. LCD HDTV
Our 32" Sony Wega CRT TV randomly shuts off. It starts to dim then completely shuts off. This is happening at faster intervals. (Shorter on times)The indicator led blinks 6 times after the random shut...
monitor if b+ voltage normal, if fluctuate check for the power supply area ckt parts for some discrepancy on biasing. if supply normal check on horizontal section area also replace crystal capacitor and check.
Aug 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Televison & Video Logo
48 people viewed this question
Computer Repairing
Computer Repairing
