Goldstar GE120CE aircoditioner control panel
It was working fine all night. I tried to turn it off but controls weren't responding. I had to unplug it to turn it off. Then it wouldn't turn back on after pluging it back in. I got it to turn on but controls and even the remote won't work. The panel lights up and reads out the room temp but thats it. None of the controls work.
1. The batteries in the remote have been replaced.
2. The air filter is clean.
3. I checked and reset the breaker on the power cord.
4. The AC unit is 14 months old and is in excellent condition. Its only used for 3-4 months of the year and only for 8 hours or so nightly.
5. It wasn't making any abnormal noises or sounds.
Any ideas what could be wrong?
    Problem Solver:
  • 6 Answers
Sounds like a bad circuit board inside contact GE and have them send you a replacement or have a tech service it for you
Posted on Jul 26, 2009
My pentair master temp 400 natural gas pool heater control panel won't respond. I can't adjust temp or turn it off. Any suggestions?
Have you tried unplugging the control panel? Or turn all the power off for 15 seconds then plug back in this will reset the control panel. If it still doesn't work I think you have a bad panel.
Oct 19, 2014 | Pentair Pool & Spa
Aqualux Whirlpool Bath controls not responding
Unplug, every thing, take batteries out of remotes etc, remove power from all parts.I mean every parts. leave out for about a minute. reconnect all. try then
Dec 02, 2013 | Home
Aqualux whirlpool bath
The panel has failed and it is unlikely that it was your dogs fault.
Dec 02, 2013 | Washing Machines
I have a goldstar dehumidifier that runs for a couple min. then turns off. I unplugged the rheostat wires from the mother board and it runs just fine. Does that mean if I replace the rheostat switch the...
Runs for a few minutes then shuts off, easy fix. First, remove water catcher and slide filter out and clean it. Then find the two screws that hold on the front panel remove front panel. Make sure the unit is un-plugged. The humidity control dial has two wires connected to it. clip the inner wire. This will keep the unit on full. You could replace the humidity control dial, but why bother?
Dec 12, 2011 | Goldstar DH304 Dehumidifier
My GE Spectra gas oven worked fine last night. Today, the oven will not heat. The broiler and the burners work fine, as does the clean feature. But nothing when the oven is turned on.
Are you sure the cleaning process works, because usually when the oven wont work, the clean process wont work. If you are correct, then the problem is most likely the control panel not responding to the bake setting. This will require either a new touch panel or a new control circuit board.
Oct 11, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Cooktop Light / Night light
It is the control panel. You can actually just replace the circuit board on the control panel and it should fix this.
Nov 10, 2008 | GE JVM1650 1000 Watts Microwave Oven
My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
May 14, 2008 | Televison & Video
Microwave locked
Try unplugging it for 15 to 20 sec. Still won't work? Try unplugging longer.
Jan 12, 2008 | Goldstar MV-1501 Microwave Oven
Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Sep 23, 2007 | Goldstar MV-1501 Microwave Oven
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
